Lynn Matteson
Posted: Fri Jul 17, 2009 7:50 am Post subject: Air intake tube vanes and EGT's |
Fifteen months after I first built vanes into my fiberglass air
intake tube, I finally tried something different, and got success.
When I first installed the vanes into my existing homebuilt
fiberglass 90-degree intake tube, I didn't notice any improvement. I
had been fighting a high #4 cylinder EGT (1405-1425 degrees F) for
quite a while, and it seemed that no amount of rotating the carb
would change that. I had tried swapping the EGT probes but that
didn't prove anything. So today I decided to try rotating the tube so
that the vanes were at a different position relative to the carb.
This finally made the difference. Before, #4 was always the hottest
at 110 to 126 degrees hotter than #3 at 2940- 2960 rpm. Then I
decided to try...again...to rotate the carb bottom towards the hot
(left) side. I had done this in the past, but it never seemed to help
enough. Then a few days ago, I rotated it as much as the throttle
mount bracket would allow before it hit the motor mount. This got the
difference down to 45-63 degrees, with #4 still being the hottest.
But today I rotated the vaned intake tube, and man, what a
difference! Now, #3 is the hottest at 19-55 degrees hotter than #4.
The highest I now see #4 is 1318, and the highest I see #3 is 1356.
These numbers were taken at various throttle settings, around 3400'
MSL, and on 56-60 degrees OAT at altitude.
I don't know why I didn't try the tube rotation as relative to the
carb before. Right after I installed the vanes into the tube, I guess
I just thought that if it didn't change things dramatically the very
first time I attached it, nothing was changed by installing the
vanes. It just goes to show that you shouldn't give up without at
least trying something a little different. Now I will try rotating
the carb back a little bit, and see if I can get the #3 and #4 closer
together. The exhaust gas temp spread is now
between 85 -132 depending on throttle position.
Lynn Matteson
Jabiru 2200, #2062, 705.6 hrs
Sensenich 62"x46" Wood prop
Status: flying
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
wb2ssj(at)frontiernet.net Guest
Posted: Fri Jul 17, 2009 5:06 pm Post subject: Air intake tube vanes and EGT's |
Lynn, are you talking about vanes you installed in the air duct from the
airfilter to the carb, and if so do you have a picture?
Lynn Matteson
Posted: Fri Jul 17, 2009 6:21 pm Post subject: Air intake tube vanes and EGT's |
Sure do, Tex....here it is. I also have pictures of building the
vanes. The gist of it is, I cut the tube down the vertical middle,
then using two separate sheets of fiberglass, I built the vanes
inside the tube, then fiberglassed the tube halves back together.
Lynn Matteson
Jabiru 2200, #2062, 706.2 hrs
Status: flying
On Jul 17, 2009, at 9:00 PM, Tex Mantell wrote:
<wb2ssj(at)frontiernet.net>
from the airfilter to the carb, and if so do you have a picture?
370.49 KB |
2466 Time(s) |
N369LM |
