rogrbal
Posted: Sat Jul 18, 2009 7:03 am Post subject: Fuel Flow - Hoskins FT 101 Fuel Flow not working |
Hoskins FT 101 Fuel Flow not working:
1. Lights stay on - all zeros
2. Unplugging connector in rear gets it working for a while, then it goes to #1 state again.
3. Resetting by doing #2 does not carry forward any fuel used between resets.
4. If reset it every time it goes to state #1, it will accumulate all the fuel used while working. Only missing that used while in state #1.
Since it always shows some power applied, I do not think this is an intermittent power problem.
Since it accumulates, I do not think this is a problem in the wire going to the battery for residual power to retain accumulated fuel.
The transducer has three wires to it, maybe one of them is the problem.
Since doing #2 always fixes it, maybe the problem is in or near this plug?
Any ideas help??
Wiring diagram is available at
http://www.instrumenttech.com/productsupport.shtml
Look in the POH for the FT101A. It shows the plug pin diagram. Although I have a 101 the only difference I can tell, is that the type reading - gallons, pounds, etc. - is user resetable vice manufacturer set.
Thanks for your ideas. Need to fix it tomorrow - Sunday 7/19/09
Roger
 Download |
| Filename: |
FT101 FuelFlow POH.pdf |
273.46 KB |
| Downloaded: |
849 Time(s) |
_________________ Thanks for the help. |
Scott Keadle
Joined: 10 Jan 2006 Posts: 31 Location: Lake Norman, North Carolina
Posted: Sun Jul 19, 2009 12:07 pm Post subject: Re: Fuel Flow - Hoskins FT 101 Fuel Flow not working |
[quote="rogrbal"]Hoskins FT 101 Fuel Flow not working:
"...Since doing #2 always fixes it, maybe the problem is in or near this plug?"
Roger,
If doing #2 always fixes it, I suggest that you not use the plug, and maybe see a gastroenterologist. Sorry, I couldn't resist.
_________________ Scott Keadle
14A, Lake Norman Airpark
N426AK RV-10, final assembly
N246SK, Giles 202, flying |
