stokesc(at)wildblue.net Guest
Posted: Mon Jul 13, 2009 7:28 pm Post subject: 582 stuck |
My 582 is stuck. I have put considerable force on the prop and it
simply will not move the engine (some movement due to the gear
box slop).
During the winter (temp appx 50 degrees) I broke in the engine using
rotax procedure. Every thing normal. No overheat or high EGT's
noted. Ran engine another half/hour checking things out. Replaced
bad EGT gage. Weather and other things kept the plane in the garage.
Began taxi testing in June. Engine starts nicely and after shutdown
hand swinging the prop can easily move the engine (temps appx 75 deg).
Then after a few taxi test of about 15 minutes, I noticed after shutdown
when hand swinging the prop it was stuck but could be easily forced
to move the engine. Temps are now appx 85 degrees. Water temp
stays at 175 deg and EGTs between 1100 and 1250 during the taxi runs.
Taxi runs are short - the runway is 2000' on grass.
Its has been raining so have not run the engine for a few days.
Now the engine is stuck! Temps appx 60 deg. Help !
Any ideas.?
Using premium car gas 91 Oct with no ethanol.
I purchased the kit and engine in 1992.
Engine has been stored as I received it. First run of engine in 2008
I have not flown airplane yet - still trying to qualify for insurance.
Cecil in North Idaho
Kitfox Md4 1050
582 grey head C box
Guy Buchanan
Posted: Mon Jul 13, 2009 9:19 pm Post subject: 582 stuck |
At 08:23 PM 7/13/2009, you wrote:
| Quote: | Now the engine is stuck! Temps appx 60 deg. Help !
Any ideas.?
Hydraulic lock? Any chance one of the cases has filled with fuel or
water or oil? Pull the exhaust at the elbow and look for fluid coming
out the exhaust port. It sounds like, at a minimum, you'll have to
pull the top end apart to check for seizure, leaks, and hydraulic lock.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 400 hrs. and counting
Deceased K-IV 1200
A glider pilot too. |
KITFOXZ(at)aol.com Guest
Posted: Tue Jul 14, 2009 12:52 am Post subject: 582 stuck |
Remove spark plugs and try to pull prop through by hand, pour small amount of Marvel Mystery Oil or common automatic transmission fluid into cylinders through spark plug holes, wait overnight, pull prop through by hand. Check compression reading, look for damage, missing tools.
In a message dated 7/14/2009 1:20:20 A.M. Eastern Daylight Time, bnn(at)nethere.com writes:
| Quote: | --> Kitfox-List message posted by: Guy Buchanan <bnn(at)nethere.com>
Any ideas.?
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 400 hrs. and counting ======================== the ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
An Excellent Credit Score is 750. See Yours in Just 2 Easy Steps!
Float Flyr
Posted: Tue Jul 14, 2009 6:49 am Post subject: 582 stuck |
Will the engine turn over easily with one plug from each cylinder removed?
Is there any sign of fuel in the impulse line?
How do the plugs look?
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
napierm(at)cisco.com Guest
Posted: Tue Jul 14, 2009 7:36 am Post subject: 582 stuck |
Hey Cecil,
It sure sounds like that engine is severely seized. I can't imagine
what could stop the prop from turning unless a piston is stuck. Since
this is a water cooled engine it can damage the piston and cylinder wall
and not show much rise in water temperature.
My engine EGT's were always very cold on the ground, never much over
1000 even at high power. In the air as the engine unloads is where the
EGT's rise to 1100. 1200 is red line.
Take the top end apart and start looking at the cylinder walls. You
should see a pretty cross-hatch pattern with no deep vertical scratches.
Also check the pistons for galling and damage. The rings should be
free. If there is damage it probably means shipping your cylinders off
to South Mississippi for work.
Good Luck,
Mark Napier
Time: 08:28:06 PM PST US
Subject: 582 stuck
box slop).
Any ideas.?
Kitfox Md4 1050
582 grey head C box
dave
Posted: Tue Jul 14, 2009 6:32 pm Post subject: Re: 582 stuck |
Did you break in with pre mix?
Has the oil level gone done in the oil injection mix bottle ?
Rather than pulling off the top end just pull the exhaust and /or Y pipe to look at cylinders. You will see scoring if there is any.
Could be hydraulic locked.... has the fuel level gone done?
That a good start
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
