Altitude Encoder Readout
sandlar1(at)embarqmail.co
PostPosted: Wed Jul 08, 2009 7:56 am    Post subject: Altitude Encoder Readout Reply with quote
Don't know if this is the proper forum for this, but here goes:
Some years ago, maybe 15 or so, there was an article in Sport Aviation regarding a kit for a panel-mounted device which would give a constant display of what the encoder was sending. Since then, I haven't heard of any such instrument, except what's incorporated in the newer transponders. Does anyone on this forum know of any such self-contained instrument that could be used with the older transponders/encoders?
Larry Sharratt
klehman(at)albedo.net
PostPosted: Wed Jul 08, 2009 9:05 am    Post subject: Altitude Encoder Readout Reply with quote
Any chance you need an excuse to acquire an MRX traffic detector Wink
The MRX will display transponder code and the altitude you are
transmitting but it's around $500. A MRX plus a new bottom end
transponder made more sense to me than spending the same or more for a
more expensive transponder though. There are enough units around that
you could likely borrow one if the need is short term.
Ken
Larry Sharratt
mprather(at)spro.net
PostPosted: Wed Jul 08, 2009 9:09 am    Post subject: Altitude Encoder Readout Reply with quote
I believe the article in question starts on page 66 of the Feb 1992 issue
of Sport Aviation.. I don't know if the plans/kits are still available.
If you are an EAA member, the article can be downloaded from the Sport
Aviation website.
Matt-
Larry Sharratt
PostPosted: Thu Jul 09, 2009 5:58 am    Post subject: Altitude Encoder Readout Reply with quote
Larry Sharratt,
I purchased the kit and built it and it works great. I doubt that the kit is available now but it would not hurt to ask. The name of the company was Airpar. Contact:
Fred N Wimberly (703) 979-2483
PO Box 2755
617 21st St S
Arlington, VA 22202-2732
I still have the construction manual and parts list. However, this will not do you much good without the PROM, the "brains" of the kit. The PROM must be programmed with the gray code, not an easy task (beyond my capability). If you really want to build an Altitude Encoder Read-Out and Fred Wimberly can not help, then perhaps a knowledgeable person on the AeroElectric website can help.
Joe Gores
Joe Gores
PostPosted: Thu Jul 09, 2009 6:55 am    Post subject: Altitude Encoder Readout Reply with quote
At 08:55 AM 7/9/2009, you wrote:
Larry Sharratt,
PO Box 2755
617 21st St S
I recall seeing various display projects over the years
but was unable to "put my hands" on one quickly. There
IS an interesting product designed by a friend of mine
that reads the output of your transponder's reply burst.
See:
http://www.airsport-corp.com/
( -Thomas Paine 1776- )
lrshar
PostPosted: Tue Jul 14, 2009 9:12 am    Post subject: Altitude Encoder Readout Reply with quote
Thanks - I appreciate the replies to my question.
Just after posting the question, I inadvertently unsubscribed from the list so just read  a couple of the replies today, thus the delay in acknowledging your responses.
Thanks again.
Larry Sharratt
