aslsa.rng(at)gmail.com Guest
Posted: Mon Jul 13, 2009 1:03 pm Post subject: Another alternative engine |
Flew over to Selby's, a local ultralight strip on a horse farm, this morning in the trike and met a fellow who has a Moto Guzzi engine on a Pinnochio (Bleriot look alike if you stand back a few feet. He has a Moto Guzzi engine mated to a Rotax E box. The project has been stalled because he can't get the engine to run at idle and off idle with the prop on it. Runs fine without the prop, runs fine above 4000 RPM. Anyone tried this engine on a Kolb, or anything else for that matter. Steve tells me they're popular in Europe, but they use a different gearbox.
Rick Girard
519.65 KB |
5346 Time(s) |
Posted: Mon Jul 13, 2009 1:24 pm Post subject: Another alternative engine |
centrifugal clutch
BB
On 13, Jul 2009, at 5:00 PM, Richard Girard wrote:
| Quote: | Flew over to Selby's, a local ultralight strip on a horse farm,
Rick Girard
do not archive<Guzzi engine with E drive 2.jpg>
Posted: Mon Jul 13, 2009 2:52 pm Post subject: Another alternative engine |
Bob, That was my first suggestion, but if you put a clutch in, the starter won't work.
Rick
On Mon, Jul 13, 2009 at 4:23 PM, robert bean <slyck(at)frontiernet.net (slyck(at)frontiernet.net)> wrote:
[quote]--> Kolb-List message posted by: robert bean <slyck(at)frontiernet.net (slyck(at)frontiernet.net)>
centrifugal clutch
BB
| Quote: | Flew over to Selby's, a local ultralight strip on a horse farm, this morning in the trike and met a fellow who has a Moto Guzzi engine on a Pinnochio (Bleriot look alike if you stand back a few feet. He has a Moto Guzzi engine mated to a Rotax E box. The project has been stalled because he can't get the engine to run at idle and off idle with the prop on it. Runs fine without the prop, runs fine above 4000 RPM. Anyone tried this engine on a Kolb, or anything else for that matter. Steve tells me they're popular in Europe, but they use a different gearbox.
Rick Girard
http://forums.matronics.com
le, List Admin.
Jason Omelchuck
Joined: 07 May 2009 Posts: 120 Location: Portland Oregon
Posted: Tue Jul 14, 2009 12:13 pm Post subject: Re: Another alternative engine |
Try putting a 10# flywheel on it that is directly attached to the engine (in-between the engine and rubber donut). Make sure that most of the weight is on the outer ring of the flywheel.
The BMW R100 smoothed out considerably at low RPM with a heavier flywheel.
| aslsa.rng(at)gmail.com wrote: | Flew over to Selby's, a local ultralight strip on a horse farm, this morning in the trike and met a fellow who has a Moto Guzzi engine on a Pinnochio (Bleriot look alike if you stand back a few feet. He has a Moto Guzzi engine mated to a Rotax E box. The project has been stalled because he can't get the engine to run at idle and off idle with the prop on it. Runs fine without the prop, runs fine above 4000 RPM. Anyone tried this engine on a Kolb, or anything else for that matter. Steve tells me they're popular in Europe, but they use a different gearbox.
Rick Girard
do not archive |
