Another alternative engine
aslsa.rng(at)gmail.com
PostPosted: Mon Jul 13, 2009 1:03 pm    Post subject: Another alternative engine Reply with quote
Flew over to Selby's, a local ultralight strip on a horse farm, this morning in the trike and met a fellow who has a Moto Guzzi engine on a Pinnochio (Bleriot look alike if you stand back a few feet. He has a Moto Guzzi engine mated to a Rotax E box. The project has been stalled because he can't get the engine to run at idle and off idle with the prop on it. Runs fine without the prop, runs fine above 4000 RPM. Anyone tried this engine on a Kolb, or anything else for that matter. Steve tells me they're popular in Europe, but they use a different gearbox.
Rick Girard
 Filesize:  519.65 KB
 Viewed:  5380 Time(s)
slyck(at)frontiernet.net
PostPosted: Mon Jul 13, 2009 1:24 pm    Post subject: Another alternative engine Reply with quote
centrifugal clutch
BB
Rick Girard
do not archive<Guzzi engine with E drive 2.jpg>
PostPosted: Mon Jul 13, 2009 2:52 pm    Post subject: Another alternative engine Reply with quote
Bob, That was my first suggestion, but if you put a clutch in, the starter won't work.
Rick
On Mon, Jul 13, 2009 at 4:23 PM, robert bean <slyck(at)frontiernet.net (slyck(at)frontiernet.net)> wrote:
[quote]--> Kolb-List message posted by: robert bean <slyck(at)frontiernet.net (slyck(at)frontiernet.net)>
centrifugal clutch
BB
Rick Girard
http://forums.matronics.com
le, List Admin.
Jason Omelchuck
PostPosted: Tue Jul 14, 2009 12:13 pm    Post subject: Re: Another alternative engine Reply with quote
Try putting a 10# flywheel on it that is directly attached to the engine (in-between the engine and rubber donut). Make sure that most of the weight is on the outer ring of the flywheel.
The BMW R100 smoothed out considerably at low RPM with a heavier flywheel.
Rick Girard
