al38kit
Posted: Mon Jul 13, 2009 6:08 am Post subject: EXPbus 2 |
Has anyone experience with the EXPbus 2...?
Thinking of using one in my rebuild of an Express. I plan to have a dual alternator and battery set up.
Good or bad?
Al Kittleson
MII
Posted: Mon Jul 13, 2009 6:39 am Post subject: EXPbus 2 |
At 09:08 AM 7/13/2009, you wrote:
Good or bad?
Not "bad" . . . just poor return on investment.
Goto my website and use the Google search tool
to find instances of "exp"
( -Thomas Paine 1776- )
ianxbrown
Posted: Mon Jul 13, 2009 6:52 am Post subject: EXPbus 2 |
Relatively good experience with the product. Nothing good to say about
the support. There's one good guy there but he's impossible to get a
hold of.
You need to keep the EXP2BUS squeaky clean while installing it, and make
sure you can get at it for servicing, debugging. I made both mistakes -
got a shard of aluminum across two posts and blew a component, despite
having vacuumed the area carefully. Took six weeks to resolve.
Beware that there is an undocumented over-voltage protection jumper that
can shut down the board if your alternator puts out a tad too much
voltage. You're best to deselect that option according to their support
people, if you have alternate means of over-voltage protection.
Ian Brown
Bromont
Quebec
On Mon, 2009-07-13 at 07:08 -0700, al38kit wrote:
Good or bad?
Al Kittleson
MII
http://forums.matronics.com/viewtopic.php?p 52779#252779
ianxbrown
Posted: Mon Jul 13, 2009 8:53 am Post subject: EXPbus 2 |
Actually, I recall price and simplicity of the panel as two of my main
drivers, and they've actually both held true. The current price is $299
and for that you get the functionality of ten switches and ten circuit
breakers plus a whole load of other functionality.
Van's price for pull circuit breakers is $23 each, and you get ten.
Toggle switches are about eight bucks and you get ten.
You're ahead ten bucks before you begin to talk about wire, added
functionality, etc.
If the "investment" is purely financial, it's certainly not an expensive
way to go.
Only having one breaker to check (alt) is a time saving and an added
safety factor, in my mind. I am certainly not as well versed in
aero-electrics as the typical contributors to this list, but I'm content
with the product.
Ian
On Mon, 2009-07-13 at 09:38 -0500, Robert L. Nuckolls, III wrote:
>Good or bad?
peter(at)sportingaero.com Guest
Posted: Mon Jul 13, 2009 9:29 am Post subject: EXPbus 2 |
My experience is reasonably poor. I would not use one in another aircraft. I
bought my aircraft with an Exp Bus 2 installed and have flown it for 7
years. Consider:
- Limited expansion potential. It is not possible to add additional
protected circuits as the number of "breakers" is fixed.
- Unable to implement a dual busbar system very easily - I'm sure there is a
way to do it but I haven't figured it out.
- Expensive for what it is. A fuse block is much cheaper and more versatile.
My system has still has a master relay. You really should fit the indicator
panel otherwise there is no indication if a "breaker" blows. At $350,
including a mounting bracket, it is expensive. A couple of fuse blocks will
do the same job.
- Intermittent faults. Very occasionally I have a momentary power outage
that has to be something to do with the Exp bus, although I have not been
able to find out what it is. Fault finding is difficult.
I am about to re-build my panel, the Exp Bus 2 will definitely not be flying
with me next year.
Peter
flybill2usa(at)msn.com Guest
Posted: Mon Jul 13, 2009 11:21 am Post subject: EXPbus 2 |
Ian
I bought a EXP tray from ACS about 4 years ago for $424.00 plus a little shipping. I stuck it in the panel of my RV-7 project and was going to use it when my engine supplier suggested a different way of handling my dual electrical system that I understood better and elected not to use the EXP tray which is still sitting in the hangar unused and I will sell it for $200 and ship it if you are interested.
Bill Schoen
flybill2usa(at)msn.com (flybill2usa(at)msn.com)
719 859-1424
| Quote: | Subject: Re: EXPbus 2
Date: Mon C 13 Jul 2009 12:51:05 -0400
--> AeroElectric-List message posted by: Ian <ixb(at)videotron.ca>
Actually C I recall price and simplicity of the panel as two of my main
drivers C and they've actually both held true. The current price is $299
Van's price for pull circuit breakers is $23 each C and you get ten.
You're ahead ten bucks before you begin to talk about wire C added
functionality C etc.
If the "investment" is purely financial C it's certainly not an expensive
way to go.
safety factor C in my mind. I am certainly not as well versed in
aero-electrics as the typical contributors to this list C but I'm content
with the product.
Ian
On Mon C 2009-07-13 at 09:38 -0500 C Robert L. Nuckolls C III wrote:
> --> AeroElectric-List message posted by: "Robert L. Nuckolls C III" <nuckolls.bob(at)aeroelectric.com>
> At 09:08 AM 7/13/2009 C you wrote:
> >--> AeroElectric-List message posted by: "al38kit" <alfranken(at)msn.com>
> >Good or bad?
> Bob . . .
> ( a thing wrong C gives it a superficial )
>-= --> http://www.matronics.com/Navigator?AeroElectric-List
&g=======
al38kit
Posted: Mon Jul 13, 2009 11:31 am Post subject: Re: EXPbus 2 |
Thanks for the info. I found the Panel and annunciator on Ebay and bought it for just over $200 total...I'm going to set it up on the bench and trip some circuits and see how I like it...Thanks,
Al
Ed Anderson
Posted: Mon Jul 13, 2009 1:44 pm Post subject: EXPbus 2 |
I do not have an EXP2 bus, but, I assisted a guy who purchased an RV 6A
with an EXP2 bus. They had to jump start the aircraft at every stop despite
having put in a new battery to ferry it home. It turns out somebody had
shorted out the EXP2 board apparently by permitting the B lead of an
alternator to ground while the boards master switch was on. This caused a
short from battery to ground through the board, fried the on-board relay and
heated the traces on the circuit board so hot the solder coating flowed off
of the. They then made it worst by soldering a heavy jumper across the
socket that held the on-board relay. This ensured the battery could not be
disconnected from the alternator even with the master off (that was the
basic purpose of the fried relay)which what cause the battery to drain down
whenever the engine was not running.
But, that said, anybody can abuse an electrical system. The new owner
elected to replace the board and has had no problem since. However, other's
have mentioned some of its limitations (not easy to expand). But, it might
be better choice for some folks than trying to roll their own. The price is
certainly not unreasonable for what you get. However, there have been
reports of unexpected responses that appear to be fairly rare - but get your
attention when they happened.
One of the things that would worry me a bit, is you have high current traces
exposed on the PC board - it would not take much for a aluminum chip, screw,
piece of wire, washer, etc to lay across some traces and a ground trace
releasing the magic smoke.
YMMV.
Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson(at)carolina.rr.com
http://www.andersonee.com
http://www.dmack.net/mazda/index.html
http://www.flyrotary.com/
http://members.cox.net/rogersda/rotary/configs.htm#N494BW
http://www.rotaryaviation.com/Rotorhead%20Truth.htm
_________________ Ed Anderson
Matthews, NC
eanderson@carolina.rr.com |
