GLJSOJ1
Joined: 18 Aug 2007 Posts: 82 Location: Chesapeake, Virginia
Posted: Sat Jul 11, 2009 5:25 pm Post subject: SECOND FLIGHT |
Hi everyone
Made my second flight today after making some adjustments.
first adjustment was to re pitch the prop from 13.5 to 12 degrees.
Second adjustment was to re-check the wings and their rigging. I found now issues here that may cause a heavy left wing. Along with this as some suggested, I moved 5 gallons of fuel from the left inboard tank to the the right inboard tank. The right tank is full (12 gal) and the left tank has about 4 gallons .
third adjustment was to right up the cooling intakes by 1" X 5 " on the left side and 3/4 " x 6 " on the right side.
I rotated at about 55 KIAS and lifted of at 60 KIAS, then gained speed to 80 KIAS to climb out at abut 400 to 500 RPM. I no longer have a heavy left wing. The airplane will climb and oil temps are no longer approaching the red line. I was able to fly level at 2300 RPM and indicated 94 knots. I was able to trim it to fly hands off.
Now the real testing will begin as Learn more about my airplane
Thanks to all the offered suggestions and ideas
_________________ 601XL N676L FLYING PHASE I
CHESAPEAKE VA |
leinad
Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
Posted: Sat Jul 11, 2009 6:26 pm Post subject: Re: SECOND FLIGHT |
Thanks for the report. Sounds great!
Dan Dempsey
| GLJSOJ1 wrote: | Hi everyone
Thanks to all the offered suggestions and ideas |
_________________ Scratch building XL with Corvair Engine |
dredmoody(at)cox.net Guest
Posted: Sun Jul 12, 2009 7:41 am Post subject: SECOND FLIGHT |
Amazing how little pitch angle produces such great results isn't it? That's a very sesnitive adjustment to get right.
Ed
