dougsappllc(at)gmail.com Guest
Posted: Thu Jul 09, 2009 10:14 am Post subject: ANR conversion |
Has anyone out there used, or know the pros and cons of using the ANR conversion kit from http://www.anr-headsets.com/Html_folder/ANRKits.html ? $169.00 to convert to ANR.
Always Yakin,
Doug Sapp
Phone 509-826-4610
Fax 509-826-3644
vectorwarbirds(at)aol.com Guest
Posted: Thu Jul 09, 2009 10:36 am Post subject: ANR conversion |
Esteemed One!
I have done four converts with their units, two in David Clarks and two in helmets. They work great, never failed, no problems. Its been about four and five years now. Of course they are not Bose but then... They do have a slight amount of background hiss, but slight as I said. I researched this before I did the next two and found this is a common problem unless you are spending the big dollars. It has never bothered me as I am hearing voices anyway. Hopefully the pink elephants will stop talking soon.
Hope this helps!
Bunndini
One thing I did do is put a dab of silicone on the small wires on where they are soldered to the circuit boards, as I did break one off installing once. So just sercured them here and there for the future.
pfstelwagon(at)earthlink. Guest
Posted: Thu Jul 09, 2009 10:47 am Post subject: ANR conversion |
Doug,
I have seen the kits and they are not bad and appear fairly easy to install. I have talked to people who have used them and the biggest problem seems to be the quality of the original headset they converted. If it wasn't a good passive set it didn't work out to be a great ANR set. As the prices of the ANR sets are coming down somewhat and the current economic situation, it may be worth while to try and deal with your favorite supplier.
Frank Stelwagon
Posted: Thu Jul 09, 2009 10:51 am Post subject: ANR conversion |
Talk to Dennis Savarese about that. He has done that for his headset and seems to like it.
Doc
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of doug sapp
Sent: Thursday, July 09, 2009 1:14 PM
To: yak-list(at)matronics.com
Subject: ANR conversion
Always Yakin,
Doug Sapp
Phone 509-826-4610
Fax 509-826-3644 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 0123456789
david.a.rieder(at)honeywe Guest
Posted: Thu Jul 09, 2009 12:37 pm Post subject: ANR conversion |
Just checking to make sure the plate isn’t lost in the mail.
As efficient as you are I’m sure it is on it’s way. :>).
Hope all is well. What’s the next trip?
Magoo
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of vectorwarbirds(at)aol.com
Sent: Thursday, July 09, 2009 11:36 AM
Subject: Re: ANR conversion
Esteemed One!
Hope this helps!
Bunndini
jgriffint28(at)cox.net Guest
Posted: Thu Jul 09, 2009 3:39 pm Post subject: ANR conversion |
Hi Doug
I have that system in 2 helmets and a Dave Clark headset and it works great in my T-6. It's almost overkill in the CJ. I would go with the manufacturer in TX. your listed outfit is a distributor. I have gotten great service including free replacement parts from them. It is headsetsinc.com.
Jim Griffin
Posted: Thu Jul 09, 2009 5:16 pm Post subject: ANR conversion |
Works great and doesn't take very long to install the conversion. Maybe less than 2 hours if you do a really neat job. You will definitely need a "pencil" soldering iron to do it properly.
Dennis
pa3arw(at)euronet.nl Guest
Posted: Fri Jul 10, 2009 2:01 am Post subject: ANR conversion |
I have that particular anr in use for years and it works fine. This anr is also sold as an optional item when you purchase a helmet from Flight Suits, the place where I got mine.
I can recommend this anr. I also installed the little power supplies in my Yak52 and they work fine.
Fly safe!
Hans Oortman
Netherlands
RA3326K
Tel: +31 653 286022
Van: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] Namens Roger Kemp M.D.
Verzonden: donderdag 9 juli 2009 20:51
Aan: yak-list(at)matronics.com
Onderwerp: RE: ANR conversion
Doc
Always Yakin,
Doug Sapp
Phone 509-826-4610
0 [quote][b]
Posted: Fri Jul 10, 2009 1:43 pm Post subject: ANR conversion |
Thanks to all that responded with info about the ANR conversion, ordered three sets today. I may do my HGU55 later if this works out well. The Yak list is a great tool.
Thanks again,
Doug
On Fri, Jul 10, 2009 at 2:59 AM, Hans Oortman <pa3arw(at)euronet.nl (pa3arw(at)euronet.nl)> wrote:
Always Yakin,
Doug Sapp
Phone 509-826-4610
Fax 509-826-3644
mikspin
Posted: Sun Jul 12, 2009 8:13 am Post subject: Re: ANR conversion |
Hey guys,
I've been researching the different ANR options as well, and one thing I found is that if you can hold out until OSH (and providing you're there), Headsets, Inc. has a pretty decent show price.
They also mentioned to me last year that if I called within a month or so after the show and mentioned that I talked with them at OSH I could still get the discount.
Mike Hastings
kregg(at)balancemyprop.co Guest
Posted: Sun Jul 12, 2009 10:46 am Post subject: ANR conversion |
I have a new condition HGU33 size large with a headsets INC. ANR installed.
The helmet is white with dual visors. Contact me directly if interested.
Kregg
Victory Aero LLC.
2502 John Montgomery Dr.
San Jose, CA 95148
408-836-5122 Cell
www.balancemyprop.com
cd001633(at)mindspring.co Guest
Posted: Mon Jul 13, 2009 8:44 pm Post subject: ANR conversion |
I have used this ANR kit in the past (retrofitted it into my helmet) and it worked well. In the past couple of years however, I have switched to C.E.P (Communication Ear Protection) that in my experience is superior to ANR. The C.E.P is primarily used in very high noise environment such as Helicopters and includes a set of mini-transducers that are connected (in parallel) to the standard helmet earphone via a short pigtail. The transducer is embedded in a standard ear noise-protection foam plug with a tiny canal that bring the audio straight to you eardrum while blocking the damaging noise. Much simpler to hook up than ANR, no need for a power source and healthier to the ear than any ANR not to mention the bottom line of very loud, clear and noise free audio (cheaper too).
I think it's worth looking into - the manufacturer web site: www.cep-usa.com
FWIW
Sam Sax
Miami
