psm(at)att.net Guest
Posted: Sun Jun 28, 2009 8:04 am Post subject: Flap up adjustments. |
Hi Sabrina,
I thought the flap stop issue was about the flap itself moving around
when in the up position. It sounds like you think it has something
to do with the air seal when the flaps are up. Is that the
case? Why do you feel that way? Or, is your tape on the flap gap a
matter of holding the flap firmly in place?
I found I wanted a "Press fit" between the flap and the wing rear
channel structure when the motor is stopped in the up
direction. This way the flap is very firmly held in place during
normal flight activities. Also, take note of the fact I found this
very difficult to accomplish. The adjustment is all done while
"Standing on your head" after mounting the wings to connect the two
flap torque tubes to the control arm tube. My approach was to add
another "Inner" tube bolted to one of the torque tubes, then connect
the two outer tubes together making the flaps move exactly together,
and finally using the center control arm tube to adjust the final
position along with the motor stop switches.
Paul
XL grounded
At 07:43 AM 6/28/2009, you wrote:
| Quote: | If I had a shiny airplane and I flew over a power plant and
experienced what I thought was flutter, I would land, put a long
piece of duct tape over the top of/sealing each flap gap, pull the
fuse on the flaps and then go solo over the same power plant
again. The flap stop gap nylo does little if the flap limits are
set improperly.
sabrina
Posted: Sun Jun 28, 2009 12:05 pm Post subject: Re: Flap up adjustments. |
Juan Vega Jr
Posted: Sun Jun 28, 2009 5:23 pm Post subject: Flap up adjustments. |
Sabrina,
I complete;y dissagree with your assessment. Most stops on most aircraft are actually an adjustable screw/ bolt.
The flap stop needs to be solid, and the flap motor needs top push the flap past the point of where it is touching the stop to about 2 mm past. htis locks the flap in place. any movement makes for a half _ss install and rushed. Using duct tape for the phase I is just bad advice. DO it right the first time, built it right the first time.
jUAN vEGA
sabrina
Posted: Sun Jun 28, 2009 8:14 pm Post subject: Re: Flap up adjustments. |
Posted: Sun Jun 28, 2009 8:42 pm Post subject: Flap up adjustments. |
Hi Sabrina,
I agree with everything you said about the flaps and phase 1
testing. As I remember reading in the FAA test Advisory Circular,
you should not use flaps on your first flight. That is similar to
not cycling the landing gear on your first flight if you have
retracts. It is all about doing as little as possible to make the
first flight as likely as possible to be successful and without problems.
My take on the bigger issue with Zodiac XL flaps is the question of
how they might contribute to in-flight problems. If they are not
firmly held in place during cruise flight then they could definitely
make life very interesting. Any movement and particularly any
repeated and possibly diverging oscillation would certainly cause
unwanted excitement. They have a shape and location similar to
ailerons, but you really don't want them to act at all like ailerons.
I agree with Juan's comments about forcing the flaps against the
stops with the flap motor. That should keep them out of any
interesting events in normal flight. It would be even better if you
could get them to lock in place. It seems to be a different thing
entirely when the flaps are deployed. Then the more interesting
question might be whether they present an even load or lift to the
airframe without introducing a roll component to make life more interesting.
Have fun,
Paul
XL grounded
At 09:14 PM 6/28/2009, you wrote:
| Quote: | It is clear that the German test results show that a improperly
stopped flap gap is bad news. If one is conducting Vne Phase 1
testing, duct tape over the flap gap sounds like a good idea to me,
just in case the builder did not get it correct. Not during all of
Phase 1, just for critical periods during Phase 1.
I would even say so for the maiden flight... just one less thing to go wrong.
sabrina
Posted: Sun Jun 28, 2009 9:15 pm Post subject: Re: Flap up adjustments. |
Juan Vega Jr
Posted: Mon Jun 29, 2009 6:53 am Post subject: Flap up adjustments. |
that I agree with. My point is people are building the flaps with too much play, and they think that is fine. They need to do it right the first time, or should be redone.
zenithlist(at)yahoo.com Guest
Posted: Mon Jun 29, 2009 7:43 am Post subject: Flap up adjustments. |
Sabrina,
Do you have pictures or drawings of your flap stops which do not twist flaps? I like to take a look at them.
Sent: Monday, June 29, 2009 12:15:22 AM
Subject: Re: Flap up adjustments.
--> Zenith-List message posted by: "Sabrina" <chicago2paris(at)msn.com (chicago2paris(at)msn.com)>
The solid stop XL flaps I have seen seem to have a smaller gap inboard than outboard. This appears to be from the flap motor, which is connected to the inboard portion of the flap, twisting the flap the 2mm Juan talks about. This puts a slight washout on the inboard portion of the flap.
In flight, air flow is fighting the solid stop XL flap due to this washout.
My flap stop does not load/twist the flap, it loads the spar. In flight, my flap stop is not being unloaded by air flow.
http://forums.matronics.com/viewtopic.php?p=250550#250550
sabrina
Posted: Mon Jun 29, 2009 8:07 am Post subject: Re: Flap up adjustments. |
Juan Vega Jr
Posted: Mon Jun 29, 2009 9:11 am Post subject: Flap up adjustments. |
Good idea Sabrina, however if the flap motor puls the flap 2 mm past the point where the stop arrests the outboard edge, the total twist on the flap is negligable, max .0001 of one degree. so at the speeds the 601 fly, the negative incidence is moot. good train of thought though. check the geomtry by figuring the triangle angle measurements.
Cheers,
Juan
sabrina
Posted: Mon Jun 29, 2009 9:53 am Post subject: Re: Flap up adjustments. |
Juan Vega Jr
Posted: Mon Jun 29, 2009 10:52 am Post subject: Flap up adjustments. |
no proplem, so we disagree and thats cool. It sperfectly OK to overplay something in you mind such as the trwist, anything to make you feel comfortable enough to feel like youve built a good aircraft works.
Juan
Juan Vega Jr
Its so hot here in Florida these days, that fresh road kill, is good to eat since it is freshly cooked off the avement.
sabrina
Posted: Mon Jun 29, 2009 11:16 am Post subject: Re: Flap up adjustments. |
chris Sinfield
Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
Posted: Mon Jun 29, 2009 12:47 pm Post subject: Re: Flap up adjustments. |
Hi all
If I have up 2 flap stops one at each end of the flap, would that not stop the flap twist when up??
Chrisj
Posted: Mon Jun 29, 2009 1:04 pm Post subject: Flap up adjustments. |
Hi Chris,
I'm afraid that would create one of those unintended consequences.
The flap structure is moved by a force applied to the innermost
rib. That means any tendency it has to twist under aerodynamic
forces would allow the far end to break free from the stop. My
notion of the twisting issue is the motor forces the structure to
twist as much as it can before stopping upward movement. This holds
the whole structure firmly in place.
I don't really know how important this amount of movement is. I
suppose it depends on how stiff the flap is in the first place. With
its triangular cross section I doubt it would twist much under any conditions.
Paul
XL grounded
At 01:47 PM 6/29/2009, you wrote:
| Quote: | Hi all
Chrisj
sabrina
Posted: Mon Jun 29, 2009 1:37 pm Post subject: Re: Flap up adjustments. |
Juan Vega Jr
Posted: Mon Jun 29, 2009 2:09 pm Post subject: Flap up adjustments. |
sounds good, good job.
Juan
