wise(at)txc.net.au Guest
Posted: Sun Jun 21, 2009 11:55 am Post subject: M14P magneto |
Hi all,
Does any one have a new or near new Magneto for sale for M14P?
Am grounded .
Thanks, Chris.
jimscjs(at)mbay.net Guest
Posted: Sun Jun 21, 2009 3:19 pm Post subject: M14P magneto |
Whats the Model #
Jim
Posted: Sun Jun 21, 2009 9:27 pm Post subject: M14P magneto |
G'Day Jim,
Thanks for the reply.
All that we can find on the Mag is M9-Then a sqaure with a vertical line thru it.
This comes out of the M14P in our yak 18T.
That's all the info that the Mag has on it.
Hope that helps.
Thanks and cheers,
Chris.
Posted: Mon Jun 22, 2009 5:03 am Post subject: M14P magneto |
That would be an M9-F magneto which has a fixed timing setting of 14-16 degrees before TDC.
What have you determined to be the problem with your magneto?
Dennis
n395v
Posted: Mon Jun 22, 2009 2:30 pm Post subject: M14P magneto |
G'Day Milt,
Thanks for sendingme the link to Steve Culp's site.
I had already looked there and his Mag is dearer than all others.
I notice that you sign off with radial rocket.
A number of years back I was extremely interested in building one and sent
emails to the advertised site with never a reply.
Man, they look to be a awesome ship.
Thanks and cheers,
Chris.
Posted: Mon Jun 22, 2009 2:40 pm Post subject: M14P magneto |
G'Day Dennis,
Well the mag stuffed up about 3 hours flying time away from home base.
Ivor Peach, a friend and LAME that does all the work for Lindsay Sinclair, Redstar Aviation here in Australia, flew his 18T to where we were with his spare mag.
We sent our mag away and it came back with the opnion that the H.T rod was earthing out.
I sourced 2 new H.T. rods but in the meantime made one out of old Packard S/S High Tension lead.
We tried this in Ivors Mag and it worked perfectly.
When the new genuine H.T. rod arrived, we re installed our mag with the new H.T. rod.
Stone dead. We tried it with the H.T. lead that I made, stone dead.
So it would appear that the mag shop in Sydney did not diagnose the problem at all.
Here in Adelaide there is a retired old fart ( like me) who is a mag man.
Now being a old fart means he knows a few things.
So I am taking it to him today.
It would however be nice to have a spare mag, does not have to be reconned or new, just a spare.
Thanks and cheers,
Chris.
cjpilot710(at)aol.com Guest
Posted: Mon Jun 22, 2009 2:50 pm Post subject: M14P magneto |
In a message dated 6/22/2009 6:31:23 P.M. Eastern Daylight Time, wise(at)txc.net.au writes:
Chris,
You know you can use a mag off the HS-6 Chinese engine, if you can fine one. You time it a little differently. At one point I ran my M-14p with one Russian mag and one Chinese mag. Worked fine, until I was able to get one Russian mag back from overhauled. At one point I ran the M-14 on just Chinese mags. I honestly could not tell the difference.
Jim "Pappy" Goolsby
[quote]--> Yak-List message posted by: "Chris Wise" <wise(at)txc.net.au>
G'Day Milt,
Thanks and cheers,
Chris.
n395v
Posted: Tue Jun 23, 2009 5:00 am Post subject: Re: M14P magneto |
| Quote: | his Mag is dearer than all others.
Yep dear and proud, ain't nuthin cheap over here anymore.
You might contact George Coy at Geosoco Inc. A few years ago he had a working prototype of an electronic ignition insert for the M9 mag.
The Radial Rocket is an awesome airplane unfortunately the kit makers just aren't on top of their game when it comes to marketing and response to inquiries..
Hope you get back in the air soon.
_________________ Milt |
Posted: Tue Jun 23, 2009 10:18 am Post subject: M14P magneto |
Pappy, is this a case where the Chinese Mag had a spark advance
mechanism and used variable spark timing, and the other one (The M9) ran
FIXED spark timing?
I am not sure if that is the case or not. I know that some of these
mags run variable timing and some run fixed. Running two variables, or
running two fixed would be fine, but running an engine with one that has
variable spark timing and one that has fixed spark timing would allow
the engine to have the plugs firing at two different times in the same
cylinder and that would be a bad thing.
This actually happened with one M-14PF leading to a really difficult to
diagnose high performance problem at full throttle. Turned out to be a
mixed mag problem like described above.
Not being familiar with the Chinese mags at all, I do not know which
type of operation they use honestly. If they are fixed timing mags with
just a slightly different adjustment procedure, then heck yes... No
problem mixing them with Russian mags. But if one is a variable timing
mag, and one is a fixed timing mag, that would not be a good thing to do
other than maybe in a "GET IT HOME" kind of emergency... And to be
honest if I did that, I would fly it on one or the other mag during the
flight home and not on BOTH.
Just my 2 cents,
Mark Bitterlich
N13472(at)aol.com Guest
Posted: Tue Jun 23, 2009 11:19 am Post subject: M14P magneto |
The centrifugal advance system in the Chinese MAG and some of the Russians
appears to reach the max advance
considerably before reaching top RPM. So the timing i.e. max advance if set
correctly would be the same. It
seems the reason for the centrifugal advance was for easer starting and
smoother idle.
Tom Elliott
CJ-6A NX63727
702-595-2680
Posted: Tue Jun 23, 2009 11:20 am Post subject: M14P magneto |
Been there...done that with a M-9PF and M-9 mix. Did not run worth a crap at
full throttle!
Seems some zipperhead in the home country in a effort to make a buck ground
the bossing off the case designating it a PF mag and I got it as a M-9 mag.
Talk about headaches sorting that crap out!
Doc
Posted: Tue Jun 23, 2009 11:55 am Post subject: M14P magneto |
Tom,
The M-9F mag does not have a centrifugal advance mechanism at all. It
is a fixed mag. As Dennis Savarese pointed out: " That would be an
TDC."
Any mag that DOES have a centrifugal advance mechanism in it will vary
the point where the spark plug fires in relation to the piston position
to top dead center as it moves to the fully advanced position. Thus
during portions of the engine RPM range, the two spark plugs will be
firing at different times. There is just no way around it. So, it is
NEVER a good idea to use one mag with fixed timing and the other with
variable timing.
But, if you really wanted to do that, a person could take the variable
timing mag apart, move the advance mechanism to full advance, and then
set that mag to match the firing point of the fixed timing mag, so that
at wide open throttle, the two mags would fire the two spark plugs at
exactly the same time, this would then cure the full power problem. But
of course, then you would simply MOVE the problem to a different RPM
range where once gain as the variable spark timing .... VARIED ..... It
would no longer be synchronous with the other mag. Simply put, how do
you take two mags, one with variable spark timing and one with fixed
spark timing, and get them both to fire the spark plugs at the same time
through-out the whole RPM range.
Answer: You don't.
The problem is exacerbated by the fact that each different type of mag
comes with it's own set of written procedures on how to set the overall
timing of the mag in relation to the piston position on the master
timing cylinder. There is one set of procedures for the FIXED mag, and
ANOTHER set of procedures for the VARIABLE mag.
Like I said, if you understood the problem in advance, you could come up
with your OWN procedures that could make the two mags work more or less
together at any certain RPM, including full throttle, but never
throughout the WHOLE range.
In the case of the subject engine that had the performance problem, each
mag was timed the way each mag (individually) was SUPPOSED to be timed,
and the result was that both of them were not firing at the same time
when the engine was at maximum RPM.
There are indeed RUSSIAN MAGS that also have variable spark timing. If
you used a Russian Mag with variable mag timing, and a Chinese Mag with
variable valve timing, you still would have to consider the variable
timing rate of change and amount of change, (this is called the timing
curve) and make sure they were matched. In order to do that, you would
typically spin both units on a machine that would measure these curves,
which is exactly how we used to do it on old racing cars with variable
advance.
Starting is not an issue with these engines since a completely different
system is used with it's own coil and it's own rotor point, and the
advance is not controlled in any way by the variable mechanism.
Yes, the variable advance will give a smoother idle, and also a better
transition from low to medium power, especially during very rapid
transitions of the throttle. Both were important, but in cars, the
smooth transition was the major concern. In airplanes, you can actually
live without any of it, as long as you don't get too eager with the
throttle movement, as evidenced by the fact that the M-9F mag actually
works pretty well.
Mark Bitterlich
Posted: Tue Jun 23, 2009 2:03 pm Post subject: M14P magneto |
FWIW, the Russian mag (M9-35) with variable or centrifugal advance timing is timed based on a number stamped in the boss of the mag under the top cover and cross referenced to a manufacturer's timing chart. Virtually all of the M9-35 mags are timed AFTER top dead center. Typically close to 5 degrees after TDC. Now on the other hand, the Chinese mags, which are also variable or centrifugal advance timing are also based on a number stamped in the boss of the mag under the top cover and cross referenced to a timing chart. However, these mags, after cross referencing the numbers on the mag to the chart, are timed BEFORE top dead center. Typically in the 7-8 degree range before TDC range. I would think there would be a much better chance of "reasonable" operation mixing a Chinese mag with a Russian M9-F fixed timing mag (14-16 degrees BTDC) than mixing an M9-F mag with any M9-35 mag, given the fact that the Chinese mag will probably advance to somewhere close to the 14-16 degrees BTDC when it is fully advanced.
Dennis
cjpilot710(at)AOL.COM Guest
Posted: Tue Jun 23, 2009 5:14 pm Post subject: M14P magneto |
In a message dated 6/23/2009 2:19:03 P.M. Eastern Daylight Time, mark.bitterlich(at)navy.mil writes:
Mark & all,
The last thing in the world I want to impress on anyone is that I am an expert on mags. 54 years ago, my Daddy took one look at my wrenching skills, and told me to become a pilot. "That way you won't starve to death and you will not hurt someone".
The real expert (at least the one person I take advice from) is Craig Payne. He can tell you the difference between the two mags in detail. I sure Doug & Dennis could also.
I did run my M-14p with mixed mags for a period of time, one set (the Russian) at its normal timing for the M14P and the CJ-6 mag set at a different sitting (I forget what). I do know that the Chinese mags allow you to push the start button with the mags ON, which is not a good idea with the Russian mags.
I could not really tell any difference in the way the engine ran. I perhaps put over 20 or more hours on it like that. It started fine, had normal mag drops during run-up. I could not tell any difference in during normal power sittings while in cruise. It just acted normal.
I used just Chinese mags on it for quite a while until one day when the engine started miss firing very badly while in cruise just a 7 nm from home. After some 300 hours of normal operation on that mag, when I took the cap off, I found that I could spin the rotor easily with my finger. Taking the mag apart I found that when the Chinese had overhauled the mag, they had left out the Woodruff key, that kept the gear from spinning on the shaft. Only the nut pressure was holding the gear in place and keeping its timing. After 300 hours or so, the nut finally loosened and the gear slipped. ( I made that last 7nm on one mag). Except for that missing Woodruff key, the mag is fine. It'll need to be re-timed internally of course, along with adding a Woodruff key.
I also used a mag from a 3 cylinder M-14 pump engine. The mag is built the same way but only has a 3 lobe cam. I took one of the cams from the Chinese mags and placed in that mag. Fit perfect. The only thing that I noticed was no matter careful I was at sitting up the timing I always got a 130 to 140 mag drop during run-up. None at high RPM sittings. It was smooth however. I've put it down to maybe the internal timing on the 3 Cylinder mag is a little different.
When I finally got my Russian mags over hauled ( a story in it self), I went back to them.
Quite frankly I believe these damn M-14 will run no matter what you do to them. I ran my fresh from the factory M-14 for 438 hours with no oil ring on number 3 piston! I guess it was either a Monday with a Vodka hangover or Ivan, the FNG, on the line.
Jim "Pappy" Goolsby
[quote]--> Yak-List message posted by: "Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E" <mark.bitterlich(at)navy.mil>
FIXED spark timing?
Just my 2 cents,
Mark Bitterlich
mbeach(at)hartwigs.com.au Guest
Posted: Tue Jun 23, 2009 6:15 pm Post subject: M14P magneto |
Reading the discussion on mags has been interesting but I have a question for the group has any one replaced the contact points on the CJ mags and if so where Did you get them ? Is there a automotive replacement ?
REGARDS
MICHAEL BEACH
wlannon(at)persona.ca Guest
Posted: Tue Jun 23, 2009 9:24 pm Post subject: M14P magneto |
The available magnetos are;
1. The M9 ( original Russian mag) This is an Auto advance magneto with a range of advance from 23 to 27 degs.
2. The Chinese CD5. This a licence built version of the M9 and is identical in all respects.
3. The Russian M9-25M. An auto advance mag with a range of advance settings from 23 to 27 degs.
4. The Russian M9-35M. An auto advance mag with a range of advance settings from 23 to 37 degs.
5. The Russian M9F. A fixed spark magneto, ie; NO auto advance. In this respect identical in operation to the Bendix SB9RN, SB9RN-4 or the American Bosch 9 cyl series.
Each engine model derived from the original Ivchenko AI 14R has a different specification for ignition timing depending on power output, RPM and minimum specified fuel grade. This is expressed in degrees of CRANKSHAFT rotation before top dead centre.
M14P spec. is 23 +/- 1 deg.
AI 14R 30 +/- 1 "
HS6 31 +/- 1 "
HS6A 27 +/- 1 " (this may raise some questions as there are two different references - one the same as the HS6)
Of course there are many other engines in the Ivchenko series in addition to the above.
Since these are all geared engines and it is convenient to measure from the propellor shaft the measured angle is a function of the reduction gear ratio.
The corresponding angle for the M14P is therefore 23 x 0.658 or 15.13 +/- 0.7 degs.
The stock M9F mag on the M14 P is set to that specification and it is a simple matter to exactly synchronize the two mags.
Synchronizing one M9F to any of the auto advance mags is, at the very best, a crap shoot. There is simply no way to accurately measure the precise firing angle of the auto advance mag.
Each individual AA magneto has it's advance setting stamped on the housing. For the M9, CD5 and M9-25M that is usually 25 degs. BUT not necessarily. That must be checked at installation and the timing adjusted accordingly.
I do not know what the usual is for the M9-35M. It can be anywhere from 23 degs to 37degs. Therefore it is not totally accurate to state that the M9-35M is set to AFTER TDC. It may very well be but that is a function of the engine specified angle and the individual stamped setting on the mag.
I'm sure at least two questions will arise from this (if anyone is really interested).
1. What is the difference between the original M9 and the M9-25M since they have the same advance range and appear identical?
2. Why the introduction of the M9-35M with a full 10 degs. more range?
Truth is I don't know the answers. But I will speculate on the first. Maybe someone can correct me and also answer the second..
1. The auto advance mechanism is a set of fly-weights subject to movement with changing RPM. This is counter-balanced by spring pressure.
The original engines were of low max. RPM (2250/2350) while the later M14P and likely others are high RPM (2900).
I would suggest that the fly-weight/spring mechanism has been designed for different ranges of RPM.
Posted: Wed Jun 24, 2009 4:10 am Post subject: M14P magneto |
As always, Walt's explanation is perfect. One point I will make though pertaining to the M9-35 mags, every one that I have seen over the past 9 years installed on an M14 has been timed to after TDC. The numbers stamped in the boss of the mag under the cover have been "34", "35", "36" and "37". I have not seen a "33" or lower number on an M9-35 when installed on an M14. In case anyone is interested, here is the timing chart for the M9-35 mag based on the number stamped in the boss of the mag.
STAMP<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /> TIME TO
23
BTDC
24
BTDC
25
BTDC
26
BTDC
27
(1)
ATDC
29
(1)
ATDC
30
(2)
ATDC
31
(2)
ATDC
32
(3)
ATDC
33
(4)
ATDC
34
(4)
ATDC
35
(5)
ATDC
36
(5)
ATDC
37
(6)
ATDC
Dennis
barryhancock
Posted: Wed Jun 24, 2009 6:19 am Post subject: Re: M14P magneto |
Hey Milt,
What kind of real performance are you seeing with the RR? Also, when you shove both levers in the corner, what's your IAS?
Thanks!
Barry
_________________ Barry Hancock
Worldwide Warbirds, Inc.
www.worldwidewarbirds.com |
Posted: Wed Jun 24, 2009 7:35 am Post subject: M14P magneto |
Michael,No automotive points exist which will fit the Chinese CD4, CD 5 or Russian M9 series mags (that I know of). However, coil, HT rod, and points are interchangeable in all of them.
Always Yakin,
Doug
On Tue, Jun 23, 2009 at 7:08 PM, Michael Beach <mbeach(at)hartwigs.com.au (mbeach(at)hartwigs.com.au)> wrote:
REGARDS
MICHAEL BEACH
et="_blank">http://www.matronics.com/Navigator?Yak-List
tp://forums.matronics.com
Always Yakin,
Doug Sapp
Phone 509-826-4610
Fax 509-826-3644
