carlossa52(at)gmail.com Guest
Posted: Sun Jul 12, 2009 2:46 pm Post subject: tight fit tool (additional test + video) |
Thanks all for the replies.
Paul, does your shake as bad as this?
http://www.youtube.com/watch?v=x_R6gwzkulI
Carlos
2009/7/12 <paulrod36(at)msn.com (paulrod36(at)msn.com)>
[quote] Hi Carlos. I also got one of their drills, and it also wobbled. Had some misgivings, but in actual practice, it drilled good holes. I'd say, try it out and see how it produces. Three years or so later, I'm still using it.
Paul R.
ihab.awad(at)gmail.com Guest
Posted: Sun Jul 12, 2009 3:25 pm Post subject: tight fit tool (additional test + video) |
Hi Carlo,n
On Sun, Jul 12, 2009 at 3:44 PM, Carlos Sa<carlossa52(at)gmail.com> wrote:
Yikes! I just went out and tried mine, and it has *no* discernible
runout. That said, mine has a red plastic part (as opposed to your
yellow -- does that make a difference?); I bought it a few years ago;
and I'm using 1/4-20 threaded bits, not a collet.
Ihab
Ihab A.B. Awad, Palo Alto, CA
Posted: Sun Jul 12, 2009 4:51 pm Post subject: tight fit tool (additional test + video) |
Yes, it sucks, doesn't it. It is hard to make a hole in a predefined spot.
I don't know if a threaded bit would make any difference: the tool comes with 4 collets, and they are just about the same in "wobliness level".
Thanks for taking the time.
Carlos
do not archive.
2009/7/12 <ihab.awad(at)gmail.com (ihab.awad(at)gmail.com)>
[quote] --> Zenith-List message posted by: ihab.awad(at)gmail.com (ihab.awad(at)gmail.com)
Hi Carlo,n
On Sun, Jul 12, 2009 at 3:44 PM, Carlos Sa<carlossa52(at)gmail.com (carlossa52(at)gmail.com)> wrote:
Ihab
Posted: Sun Jul 12, 2009 10:39 pm Post subject: tight fit tool (additional test + video) |
Re my previous report on my tightfit drill: I’ve always used the threaded drills. That could account for my relative lack of wobble.
-- Craig
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Carlos Sa
Sent: Sunday, July 12, 2009 6:46 PM
Subject: Re: tight fit tool (additional test + video)
Carlos
do not archive.
Hi Carlo,n
Ihab
| Quote: | | http://www.matronics.com/Navigator?Zenith-List | 0123456789
paulrod36(at)msn.com Guest
Posted: Mon Jul 13, 2009 9:09 am Post subject: tight fit tool (additional test + video) |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Not quite that much. It almost looks like a slightly bent drill bit. How good is the hole it produces?
Paul R.
naumuk(at)windstream.net Guest
Posted: Mon Jul 13, 2009 11:11 am Post subject: tight fit tool (additional test + video) |
Carlos-
Roll the damn drill bit on a flat surface and find out if it wobbles. It doesn't look like it will. If it doesn't, you've got a collet problem.
Tommy Walker
Joined: 12 Jan 2006 Posts: 442 Location: Anniston, AL 36207
Posted: Tue Jul 14, 2009 11:42 am Post subject: Re: tight fit tool (additional test + video) |
Re: tight fit tool.
Have you guys looked at this?
http://tinyurl.com/kvdopo
or this?
http://tinyurl.com/l7hhnk
You could probably use this to build your plane and then sell it and get most of your money back. I got two of the tight fit drills and never take them out any more. I use a drill similar to the second one. Works great! and less filling.
Tommy Walker in Alabama
_________________ Tommy Walker
N25A - Anniston, AL |
Posted: Tue Jul 14, 2009 2:44 pm Post subject: tight fit tool (additional test + video) |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> It's a nice looking tool, but seems too large to get into the tight spots Mine is at the hangar, but I think it will get within 3/4" of a side wall, and needs only about 2" from back to tip of a short bit.
Paul R.
Tommy Walker
Posted: Tue Jul 14, 2009 2:52 pm Post subject: Re: tight fit tool (additional test + video) |
Yes, the one I have will get into the same places the Tight Fit drill will get. Plus, you can use it with one hand if need be.
The drill in the first link in my message was a little large. I probably shouldn't have sent that one, but it was cheaper. The second product in the second link has a head at least as small as, if not smaller than the Tight Fit drill extension.
Do Not Archive this or anything I am foolish enough to post.
[quote="paulrod36(at)msn.com"]<xml><xml><endif> It's a nice looking tool, but seems too large to get into the tight spots Mine is at the hangar, but I think it will get within 3/4" of a side wall, and needs only about 2" from back to tip of a short bit.
Paul R.
JohnDRead(at)aol.com Guest
Posted: Tue Jul 14, 2009 4:34 pm Post subject: tight fit tool (additional test + video) |
There is enough material in the TF tool head to file the corners off at a 45 degree angle, this will let you get to within 10 - 11 mm of a vertical surface. Many of you have commented that the tool is a bit wobbly, mine is to but it does not seem to affect its ability to drill.
John Read
CH701 - Elbert CO - Jabiru 3300
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
In a message dated 7/14/2009 4:45:31 P.M. Mountain Daylight Time, paulrod36(at)msn.com writes:
[quote] It's a nice looking tool, but seems too large to get into the tight spots Mine is at the hangar, but I think it will get within 3/4" of a side wall, and needs only about 2" from back to tip of a short bit.
Paul R.
Posted: Tue Jul 14, 2009 5:20 pm Post subject: tight fit tool (additional test + video) |
Using the stubby bit that came with the tool, not good: visibly oval.
I'll try to contact the vendor tomorrow, see what can be done.
They are *very* nice, but I don't know what can be done to fix my problem.
Carlos
2009/7/13 <paulrod36(at)msn.com (paulrod36(at)msn.com)>
[quote] Not quite that much. It almost looks like a slightly bent drill bit. How good is the hole it produces?
Paul R.
