sdthatcher
Joined: 13 Mar 2008 Posts: 91 Location: Port Saint Lucie
Posted: Fri Apr 17, 2009 6:03 am Post subject: Thoughts regarding Flutter |
I believe the problems that we are experiencing with the 601XL are not the result of flutter or any other single issue but instead the result of 4 specific and simultaneous factors that have caused the wing failures of our aircraft.
First, why not flutter? Because in the instances that have been reported to be flutter, the time that was required to identify the vibration and to escape from its destructiveness has been too long (more than a few seconds). My opinion is that we are seeing a simple harmonic vibration of the ailerons that, depending on the tension in the cables, can be considered as scary enough to cause real concern.
My first theory is that the problem we are seeing with the ailerons is harmonic vibration, not flutter, and is dependent on the tension of the cables. In my flight, the cables had loosened to the point that I could feel a 1-2 inch movement of the stick without any corresponding movement of the ailerons. As I went over the Valley River Mountains near Andrews, NC, I could see the ailerons start to vibrate, so I decreased the throttle and the vibration stopped. In another case locally, the pilot had loose cables and, during flights above Va, experienced severe vibration. He tested this by purposely flying into that portion of the envelope repeatedly (observing the same type of vibration each time) and then to test it again after tightening his cables. In his case, the vibration stopped above Va. I believe that depending on the combination of engine, aerodynamics and cable tension, the vibration of the ailerons could be seen as mild or severe... but not flutter. Another possible instance of severe vibration was a 601 in Georgia that experienced vibration after flying over a power plant and which required a dive to eliminate the vibration. It is known that to reduce flutter, you need to reduce airpseed and pray. But in this case the means of reducing the aileron vibration was to dive at speeds that were close to Vne. Not the usual way to stop flutter and in any case, the resulting actions took considerably longer than required to avoid desctruction from flutter. In two of the three cases mentioned, the vibration was severe enough to apparently cause movement of the wing, as stated by the pilots.
So, if the problem is just vibration how does that cause destruction of the wings? My second theory is that the wings of every aircraft that has failed to date was structurally compromised at some point in the history of the aircraft. Recently, I was talking to a gentleman here in Andrews, NC that was in the Lakeland bound 601 just a week or so before it lost its wings and was destroyed. He stated that while flying with the pilot over the mountains near here, they experienced what he described as severe turbulance. He mentioned to the pilot how really bad the turbulance was and the pilot stated that "this was nothing compared to a week earlier". Apparently the turbulance was so bad that the pilot called the experience "bone crushing". As for the Yuba City 601, the owner of that aircraft had stated that there was an indication of "smoking rivets" on the bottom of the wings. This condition usually is the result of rivets becoming loose and creating a condition that results in a decrease in structural integrity. The Yuba City aircraft also (I believe) was flying near or in mountainess areas during its history.
The third condition that must be met is looseness of the aileron cables. I believe that vibration will not occur while the cables are tight.
And the fourth criteria for these wing failures is flying above Va (maneuvering speed).
So to summarize, if these 4 conditions are met, the probability is high for the aircraft to be lost even in mild turbulance.
Once again, they are:
1. Aileron Vibrations
2. Previous structural damage to the wings.
3. Loose Aileron Cables
4. Speeds above Va
I had originally thought that the only way we could explain the loss of wings on the 601XL was from flutter, however, since 98% of the fleet has not lost its wings and yet reports continue to surface of severe vibration, loose cables, etc., it seems to me that there must be a combination of problems that occur simultaneously that result in destruction of the wings.
Anyone who has experienced severe turbulance should carefully look over their wing roots for damage and avoid flight, especially if they also have loose cables!
Scott Thatcher, N601EL
601XL with WW Corvair, 25 Hours
Just finishing first Condition Inspection
_________________ Scott Thatcher, Port Saint Lucie, FL
601XL with Corvair, Registered as E-LSA
N601EL, EAA203 140 hours and not flying currently. |
ciuro
Posted: Fri Apr 17, 2009 7:19 am Post subject: Thoughts regarding Flutter |
you should not assume anything at this time. Assumptions in aircraft accidents are usually wrong'.
--- On Fri, 4/17/09, s_thatcher(at)bellsouth.net <s_thatcher(at)bellsouth.net> wrote:
| Quote: | From: s_thatcher(at)bellsouth.net <s_thatcher(at)bellsouth.net>
Subject: Thoughts regarding Flutter
To: corvaircraft(at)mylist.net, zenith-list(at)matronics.com, zenith601-list(at)matronics.com, ZBAG(at)yahoogroups.com
Received: Friday, April 17, 2009, 9:55 AM
4. Speeds above Va
" target=_blank rel=nofollow>http://www.matronics.com/Navigator?Zenith601-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
| [quote][b]
Gig Giacona
Posted: Fri Apr 17, 2009 8:12 am Post subject: Re: Thoughts regarding Flutter |
Seeing as how the NTSB notice is based on assumptions as well I think the forwarding of other theories is most certainly in order.
| ciuro wrote: | you should not assume anything at this time.� Assumptions in aircraft accidents are usually wrong'.
601XL Under Construction
n85ae
Posted: Fri Apr 17, 2009 9:08 am Post subject: Re: Thoughts regarding Flutter |
Well, I don't understand how you guys think? It's beyond me.
I for a period of time, got to spend right seat time with a now retired 747
captain, who had flown C-46's in WWII over the burma trail. I always
greatly admired him, because his decision making process was crystal
clear. He would get the info, and regardless of whether it was the answer
he "wanted" or not, he simply made the decision based on safety. Never
once did I see him ever say, "well maybe ..." No, he simply accepted that
something wasn't safe and he went with it as called.
Jeff
Jeyoung65(at)aol.com Guest
Posted: Fri Apr 17, 2009 10:39 am Post subject: Thoughts regarding Flutter |
Thatcher, Can you tell the older timer what is the difference between "simple harmonic" and " flutter" ? Jerry of GA DO NOT ARCHIVE
In a message dated 4/17/2009 9:06:46 A.M. Eastern Standard Time, s_thatcher(at)bellsouth.net writes:
| Quote: | | My opinion is that we are seeing a simple harmonic vibration of the ailerons that, depending on the tension in the cables, can be considered as scary enough to cause real concern. |
Join ChristianMingle.com® FREE! Meet Christian Singles in your area. Start now!
Larry Hursh
Joined: 16 Feb 2008 Posts: 125 Location: Edwardsburg, MI (near Elkhart, IN)
Posted: Fri Apr 17, 2009 4:14 pm Post subject: Thoughts Regarding Flutter |
Sorry guys but all of this to me is nothing more than wild speculation. I am finding all the bantering to be depressing at best. It's gotten so bad for, I haven't touched a rivet or drill since all of this mess came out. I honestly don't expect anyone from Zenith Aircraft to step up and work with the NTSB willingly. Zenith has stated and restated that the problem is wing flutter. Their claim is its being caused by poorly or improperly maintained tension on the cables tensions. I think there has been a line drawn in the sand and neither the NTSB or Zenith is going to give one iota. The NTSB is forcing the issue by posting their statement publicly and asking the FAA to ground all of our aircraft until further notice. Once again, Zenith claims poor tension. Nothing gives. The next decision will most likely come from the FAA in a formal notice. If they do ground all 601's (and 650's) this will force Zenith to work with the NTSB. If Zenith refuses,
then we, the customers are left out in the cold. As I said before, I'm finding this all depressing so I am going to STOP reading all these posts and WILL search on the FAA daily for any updates or notices. I just hope the Heinz family realizes very soon, SOMETHING has to be done - even if its nothing more than to sit down with the NTSB AND the FAA and acknowledge there COULD possibly be a design issue - EVERYTHING has to be ruled out. It's our lives we are talking about here. To stand back as Zenith has done and claiming its poor maintenance is a cop out, big time. Its VERY POOR customer service. I just hope Zenith Aircraft can see this.....Of course this is all my opinion. Stepping off my soapbox now.
Larry Hursh
Edwardsburg, Michigan
Zenith CH650 (N650LM Reserved)
I hope someday I can be the person my dog thinks I am.....
_________________ Larry Hursh (N650LM Reserved)
"One rivet at a time......one day at a time.."
CH650 (Converted from CH601XL)
1/2 done with fuselage
will be Corvair Powered |
bryanmmartin
Posted: Fri Apr 17, 2009 5:06 pm Post subject: Thoughts Regarding Flutter |
Zenith doesn't have to work with the NTSB. The NTSB has absolutely no
authority in the matter. It's the FAA that has the authority, all the
NTSB can do is advise. The FAA is free to ignore that advise as they
see fit. The NTSB notice does not make any mention of the 650 so, so
far that model is in the clear. The FAA may be able to ground the S-
LSA version to the 601XL as they have a standard certificate of some
sort to go after. As far as the E-AB versions of the XL are concerned,
the FAA would have to ground each airplane on an individual basis,
because there is no type certificate to take action against. Each is
considered a one of a kind airplane and the paperwork does not even
have to contain Zenith or Zodiac or CH 601 XL, the builder can call it
anything he wants to and many builders probably have done so. The FAA
doesn't have the resources to track down every homebuilt variant of
the 601XL to make the attempt to ground them.
On Apr 17, 2009, at 8:13 PM, Larry Hursh wrote:
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
Larry Hursh
Posted: Fri Apr 17, 2009 6:25 pm Post subject: Thoughts Regarding Flutter |
Bryan, don't try to fool yourself or anyone else on this list. When I originally purchased my wing kit, it came with the hinge-less ailerons and the new style fiberglass wingtips. I "converted" my fuselage kit to the 650 within the week of it being introduced at Oshkosh last year. MY WINGS ARE THE EXACT SAME WINGS AS THE 601. To "upgrade" them, I added the "L" brackets for the oil canning. I added the gussets at the first and second rib on the ailerons. THAT'S IT. The only major differences (besides the new style rudder) is the angle of the main spar center section. On the original 601 the angle was set at 9 degrees. With the 650 the main spar center section is now 7 degrees. It's for better "forward visibility". Don't try kidding anyone on here about "being in the clear" Bryan - your NOT in the clear. Its exactly the same wing with the same flaps and same ailerons because mine WAS a 601. I know. You don't, so quit trying to mislead people
about that on here. If you doubt me, call Zenith. You need the number???
Larry Hursh
bryanmmartin
Posted: Fri Apr 17, 2009 7:58 pm Post subject: Thoughts Regarding Flutter |
I'm not trying to fool anybody, all I said is the CH 650 is not
mentioned in the NTSB report. We are dealing with buearocrats here,
nomenclature is everything. If it's not specifically mentioned, it is
not included. It doesn't matter if it's physically the same.
Don't tell me what I don't know, You don't know what I don't know.
On Apr 17, 2009, at 10:24 PM, Larry Hursh wrote:
number???
Bryan Martin
N61BM, CH 601 XL,
do not archive.
Bryan Martin
do not archive. |
tonyplane(at)bellsouth.ne Guest
Posted: Fri Apr 17, 2009 8:32 pm Post subject: Thoughts regarding Flutter |
Additional thoughts, Scott
Sounds reasonable. I thought about replacing cables with push rods, but then thought that the natural freq of a rod would probably be lower than a tensioned cable and more likely to resonate.
Today as I was up enjoying the sky in my XL, I crossed mid-field and broke to down wind and it reminded my of another reconstructed crash at the crash lab at March AFB during a course I took in Aircraft Accident Investigation at USC thirty years ago.
It was an AeroCommander Twin that shed its wings.
The physical investigator instructor, (who was also my undergraduate instructor in Rotary Wing Aerodynamics years prior) related that he was requested to investigate the wing failure of another Twin Commander, I believe that occurred in Co. If I recall correctly, the Commander made a mid-field crossing and broke to down wind and had a wing structural failure which was attributed to pilot error causing the overload. The instructor related that there were also other Commanders that had had the same failure.
What he discovered (and I have the plot somewhere in my class notes, buried ?) was that the stick forces per G went NEGATIVE at about 4 Gs. Imagine the yoke coming back in your lap and the wing fails due to overload, if above Va. (There was an AD issued to require a weight in the control system to pull the stick under G loading (bob weights have been used in many aircraft control systems).
The reason I bring this up is that I still believe the XL light stick forces can easily result excessive G loading and are quite possibly the REAL reason for the wing failures. Not that light stick forces are bad, but one has to not be ham fisted above Va. (I previously related giving an older pilot a ride in my XL during a pretty turbulent day and he pushed the stick rapidly nose down such that I would have gone through the canopy without a seat belt. This happened during climb out at about 80 - 90kts and the gusty conditions had caused a pitch up.(still can not believe another pilot would have done that, but possibly his Tomahawk had a much different elevator response).
Somehow, some people jumped on the flutter bandwagon, and as another matronics "inputer" stated - "and so it was"
What really concerns me is that the NTSB might wish to make a "Science Project" (Note) over additional flutter testing of the XL. They evidently do not wish to accept the successful flutter tests already done by Zenith (see page 6 of the NTSB report).
Note:
A Science Project is where you spend all of your resources but never come up with a result that is acceptable to the government because additional tests or analytical parameters are ALWAYS required. ("You only tested (or modeled) down to -40F. We require additional testing at -65F .....and on ....and on ..and ..............").
Tony Graziano
Buchanan, Tn
XL/Jab; N493TG; 483 really great hours in my XL
jaybannist(at)cs.com Guest
Posted: Sat Apr 18, 2009 6:01 am Post subject: Thoughts regarding Flutter |
Tony,
I happen to agree with you. I also think that the elevator is a more likely source of trouble than the ailerons. Even though the XL that I flew didn't seem to me to have an overly sensitive elevator, I have read and heard comments that indicates that it is troublesome to others. The NTSB letter goes into some detail about the elevator being progressively effective. It is fairly well accepted that excessive elevator input can overstress an airframe. In the case of the XL accidents, a gross elevator movement could very well have overstressed the wings and made them fail. The NTSB accident report of the Yuba accident speculated that the first thing to fail was the horizontal stabilizer, in a downward direction. It seems to me that a max down elevator could have caused that. I did not see any mention of whether the Heintz recommended elevator stop had been added to this airplane.
This makes me wonder if adding progressive resistance to fore and aft movement of the stick might make sense to defeat the progressive effectiveness of the elevator, ie: bungees or springs. what do you think?
Jay Bannister
bryanmmartin
Posted: Sat Apr 18, 2009 8:10 am Post subject: Thoughts regarding Flutter |
Another thing to consider is that the CG of the 601XL shifts rearward
as you burn off fuel. So If you make a long cross country flight in a
heavily loaded XL, you may discover that the pitch sensitivity has
increased significantly when it comes time to land. I have had this
experience myself. I was a little surprised when the plane started to
porpoise on short final. I realized what was happening and got it
settled down fairly quickly, but it did get my attention. I sure am
glad I spent the extra money for the confor-foam seats cushions. I can
spend four hours in the plane without getting greatly fatigued.
I added a bungee cord to the elevator controls to assist with nose up
trim. One of these days, I'm going to link it to the flap torque tube
to provide some automatic trim adjustment with flap deployment.
On Apr 18, 2009, at 9:58 AM, jaybannist(at)cs.com wrote:
| Quote: | Tony,
think?
Bryan Martin
N61BM, CH 601 XL,
do not archive.
Bryan Martin
do not archive. |
NYTerminat(at)aol.com Guest
Posted: Sat Apr 18, 2009 10:23 am Post subject: Thoughts regarding Flutter |
But weren't some of these accidents straight and level?
Bob Spudis
In a message dated 4/18/2009 12:10:49 P.M. Eastern Daylight Time, bryanmmartin(at)comcast.net writes:
| Quote: | --> Zenith601-List message posted by: Bryan Martin <bryanmmartin(at)comcast.net>
| Quote: | Tony,
think?
Bryan Martin
N61BM, CH 601 XL,
do not ================================================[b]
Access 350+ FREE radio stations anytime from anywhere on the web. Get the Radio Toolbar!
Posted: Sat Apr 18, 2009 11:03 am Post subject: Thoughts regarding Flutter |
| Quote: | One of these days, I'm going to link it to the flap torque tube to provide
There is a little box that does this (although you might consider it
overkill):
http://www.aircraftextras.com/
-- Craig
Posted: Sat Apr 18, 2009 3:23 pm Post subject: Thoughts regarding Flutter |
Jay,
What commonly has been done is to add a mass to the bottom of the stick assembly, usually Tungsten or depleted Uranium to save space. As you change the angle of the stick, the mass tends to pull the stick relatively straight neutral and the more G loads the more force exerted by the mass to center the stick relatively neutral, ---- the more Gs pulled, the more force it takes to hold back the stick; stick forces per G goes up. I don't know if the geometry of the XLs "stick configuration" would permit a mass addition.
The Yuba City with the stab failure in a down direction indicates UP elevator. Once the stab fails, the nose pitches violently down, and the wing fails in a relatively down direction - excessive negative Gs. In a good design, it would be a toss up as to what fails first under excessive G loading, the stab or the wing.
I believe the Yuba City wing failure speaks volumes about an overstress condition caused by stick input
Tony.
Charles3603
Posted: Mon Jun 15, 2009 8:05 am Post subject: Re: Thoughts regarding Flutter |
I think all of the problems are true. Airframe & Pilot.
I talked to a builder in Texas that told me that he was flying along, wisling
dixie, made a accidental push on the stick and the plane re-acted and he re-acted. He went on to say that someone with limited flying experience would have over-reacted and killed themselves. This plane is very responsive and fast...My suggestion to flutter is to place (2) springs in
place to make all aileron surfaces return to (0) zero position or neutral. Smile
