dvanlanen
Posted: Thu Jun 11, 2009 11:47 am Post subject: Questions On Reamers |
I need to use a 6.4mm reamer for installing the bushings in the upper and lower rudder hinge holes on my 601XL project. I am totally unfamiliar with reamers. Can anyone educate me on the following:
- Is the goal to get a tight fit of the bushing in the hole?
- Is it best to purchase a reamer with a “fixed” size, or do the adjustable reamers work OK?
- Most of the reamers I looked at online do not appear to have tapered flutes – how do you start a reamer in the hole if the flutes are not tapered?
- Is it best to turn the reamer by hand to get the best accuracy, and if so, what type of reamer do I need to get, (most reamers I found online were defined as “high-speed” or “high-speed chucking”)?
- I checked the sources mentioned in earlier posts to the list, but I cannot find a 6.4mm reamer - I can find a .252” reamer, but that is a little larger than 6.4mm – does anyone know a source for this particular size?
Thanks for your help,
Dave Van Lanen
Madison, WI
601XL Ser. # 6-6022 – tail done, wings on hold, starting fuselage [quote][b]
scottbevier
Posted: Thu Jun 11, 2009 4:21 pm Post subject: Questions On Reamers |
Dave,
The 0.2520” chucking reamer sold by MSC or McMaster-Carr is close enough. The difference is < 0.0001”
I ordered this one from McMaster-Carr. Part# 8803A482 High-Speed Steel Decimal Chucking Reamer .2520" Dia, 1-1/2" L Flute, 6" L O'all, 6 Flute. About $23.00.
Chuck it in a cordless drill, slow speed, practice on some scrap material. It works fine.
Scott Bevier
