ROD END BEARING JAM NUT - Torque
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List
dthomas773(at)sbcglobal.n
PostPosted: Fri Jun 05, 2009 4:40 pm    Post subject: ROD END BEARING JAM NUT - Torque Reply with quote
What works well for this is a ratchet end wrench.
I wouldn't worry too much about torque torque value.  If really concerned you could play with a same size nut in another location with  a torque and regular wrench to get the feel of what the torque feels like.
Dennis Thomas
From: Garey Wittich <gareywittich2000(at)yahoo.com>
To: rv-list(at)matronics.com
Sent: Friday, June 5, 2009 10:26:16 AM
Subject: RV9-List: ROD END BEARING JAM NUT - Torque
For you Experts:
Installed the Rod End Bearings in the Rudder and Elevator today.  My local A & P said to tighten the Jam Nut by "Hand Tightening" the Jam Nut as far as it will go, then turn the nut between 1/4 and 1/2 turn more.
I "hand tightened" the Jam Nut (as the A & P said), but could not get it to tighten more than an additional 1/8 turn,  Because the Jam Nut is recessed (in the Spar channel), it is impossible to get a wrench "squarely" on it = any further tightening of the Nut starts to round the corners of the Nut.  Is this 1/8 turn adequate for the Jam Nut tightness, if NOT how do you turn the Nut (since it is recessed) ????
What Torque Value is required for the Jam Nut, assuming a Torque Wrench can get into the recessed area - do not see how this can be done.
ANOTHER QUESTION -
Have a "Click Type" torque wrench that starts at 20 in-lbs.  From previous posts, the FIRST 1/6 and the LAST 1/6 of the Wrench's scale are inaccurate.  So how do you measure  "LOW VALUES"  for an AN3 Nut that requires 20 - 25 in/lbs plus Friction Torque of approx 5 in/lbs = 25 to 30 on/lbs TOTAL torque ??
Appreciate your help,
Garey   Santa Monica, CA
http://foru===
- The Matronics RV9-List Email Forum -
http://www.matronics.com/Navigator?RV9-List
ianxbrown
PostPosted: Fri Jun 05, 2009 7:20 pm    Post subject: ROD END BEARING JAM NUT - Torque Reply with quote
Not sure if a ratchet end wrench is the same thing but a crows foot
wrench works too. I'd agree about the guesstimating by trying the feel
elsewhere. The rod end bearing is not going to go anywhere anyway!
Ian Brown
feels like.
Dennis Thomas
______________________________________________________________________
Subject: ROD END BEARING JAM NUT - Torque
For you Experts:
more.
done.
ANOTHER QUESTION -
http://foru===
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List All times are GMT - 8 Hours
