		skidmk
  Joined: 19 Nov 2007 Posts: 171 Location: Ottawa, Ontario
				 Posted: Mon May 25, 2009 8:40 am    Post subject: spark plug gapping (new questions) |
				HI all,,
 changed my plugs at the annual this year (chinese to chinese) and we now have  a vibration at high rpms.
 In keeping with the previous discussion of vibration, I'd like to check the gaps.
 I know the gap specs (from the book), but what massive electrode tool would I use to fix them if they are out?
 I've looked at ATS and aircraft spruce for a gapper, but they are all 18mm?
 thanks
 Mike
  _________________ Mike "Skidmk" Bourget
Ottawa, Ontario |
		dougsappllc(at)gmail.com Guest
				 Posted: Mon May 25, 2009 9:46 am    Post subject: spark plug gapping (new questions) |
				Mike,In every can of Chinese DZ5 plugs there are 10 plugs, copper gasket/seals and a gapping tool, this is a go/no go "feeler gauge" type tool.  No need to buy any special tools.
 Always Yakin,
  Doug
 On Mon, May 25, 2009 at 9:40 AM, skidmk <skidmk(at)gmail.com (skidmk(at)gmail.com)> wrote:
  	  | Quote: | 	 		   --> Yak-List message posted by: "skidmk" <skidmk(at)gmail.com (skidmk(at)gmail.com)>
  HI all,,
  thanks
  Mike
  Ottawa, Ontario
  http://forums.matronics.com/viewtopic.php?p=245274#245274
  rget="_blank">http://www.matronics.com/Navigator?Yak-List
  le, List Admin.
 Always Yakin,
 Doug Sapp
 Phone 509-826-4610
 Fax 509-826-3644
				I'm pretty sure if you buy 20 Chinese spark plugs from Doug,  the sealed container with the plugs has a neat little gapping tool in it.   Check with Doug to see if this gapping tool is available  separately.
  Dennis
  [quote]   ---
		skidmk
				 Posted: Mon May 25, 2009 10:38 am    Post subject: Re: spark plug gapping (new questions) |
				Hi guys,,
 yes the go no go tool is there.  I'm not terribly familiar with its use (used to gappers), and as such didn't want to risk bending/breaking an electrode/other.
 I understand the gap tool  slides down next to the electrode to test the gap,and it should be tight, but easily slide up and down.  However if there are instances where the gap is too tight, can the tool be used to bend the plug back?
 M
Ottawa, Ontario |
				 Posted: Mon May 25, 2009 11:11 am    Post subject: spark plug gapping (new questions) |
				If it is too tight just tap it in and it will set the correct gap.
 Doug
 On Mon, May 25, 2009 at 11:38 AM, skidmk <skidmk(at)gmail.com (skidmk(at)gmail.com)> wrote:
  Hi guys,,
  M
  Ottawa, Ontario
  http://forums.matronics.com/viewtopic.php?p=245296#245296
  le, List Admin.
 Always Yakin,
 Doug Sapp
 Phone 509-826-4610
 Fax 509-826-3644
		skidmk
				 Posted: Mon May 25, 2009 4:01 pm    Post subject: Re: spark plug gapping (new questions) |
				yep did that, what if its too loose?
Ottawa, Ontario |
		wlannon(at)persona.ca Guest
				 Posted: Mon May 25, 2009 7:37 pm    Post subject: spark plug gapping (new questions) |
				Doug & Mike:
 NO!!!
 That is not a gapping tool. It is simply a gauge. Do not attempt to change
 the gap by applying any pressure to the center electrode. This can crack the
 porcelain insulator.
 Walt
		skidmk
				 Posted: Tue May 26, 2009 6:36 am    Post subject: Re: spark plug gapping (new questions) |
				Walt is there a gapping tool you can recommend?
 Mike
Ottawa, Ontario |
		Nanchang CJ6
				 Posted: Sun May 31, 2009 12:59 am    Post subject: Re: spark plug gapping (new questions) |
				Hi! We are specialized in Nanchang CJ6 aircraft parts.And we have some stocks about DZ-5 spark plugs.If you are interested in it,pls feel free to contact me!My msn is lcdzkj(at)live.cn.
  _________________ Sarah's E-mail:lcdzkj@live.cn |
