		dalemed
				 Posted: Fri May 29, 2009 6:57 am    Post subject: 601 wing on 650 fuselage |
				I'd already started my 601xl wings when the 650 design was released.  I was told at that time (by the factory) that I could use the 601 wings "as is".  Now I'm hearing about attachment differences between the two.  Can anyone explain whats really going on and what I might need to rework on the wings?
 Thanks for any enlightenment!
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Dale
Zenith Zodiac CH650 |
		lwinger
				 Posted: Fri May 29, 2009 7:26 am    Post subject: 601 wing on 650 fuselage |
				No reworking of the wings is required.  The change in angle of incidence affects how you set the center spar in the fuselage as well as the vertical location of the rear attach plate.  Because it is closer to the lower longeron, it cannot be as wide as on the 601XL, therefore it is made of thicker material.
  Larry Winger
  601XL (now 650) / Corvair
  Ready for canopy
  On Fri, May 29, 2009 at 7:57 AM, dalemed <dalemed(at)gmail.com (dalemed(at)gmail.com)> wrote:
  [quote]--> Zenith601-List message posted by: "dalemed" <dalemed(at)gmail.com (dalemed(at)gmail.com)>
 Dale
 Flying Cessna 170B
 Building Zenith CH650
 http://forums.matronics.com/viewtopic.php?p=245890#245890
  s List Un/Subscription,
  www.matronics.com/Navigator?Zenith601-List" target="_blank">http://www.matronics.com/Navigator?Zenith601-List
  Matt Dralle, List Admin.
  _________________ Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger |
		bryanmmartin
				 Posted: Fri May 29, 2009 7:58 am    Post subject: 601 wing on 650 fuselage |
				I believe the 650 wings are set at a slightly different angle of
 incidence to the fuselage: the trailing edge is lower. To make the 601
 wings fit, all you should need to do is to adjust the lower flanges of
 the center spar section to the new angle and use the new, thicker rear
 attach plate.
 Bryan Martin
 N61BM, CH 601 XL,
 RAM Subaru, Stratus redrive.
  _________________ --
Bryan Martin
do not archive. |
		dalemed
				 Posted: Sat May 30, 2009 9:29 am    Post subject: Re: 601 wing on 650 fuselage |
				I think most of my confusion resulted from confusing the rear attach plate with the root doubler (6w7-2).  The root doubler is also 0.063 on the 601 wing.
 I'm much less confused now.  Thanks for the insights!
