Matronics Email List Wiki!
Site Admin
PostPosted: Sat Apr 01, 2006 1:45 pm    Post subject: Matronics Email List Wiki! Reply with quote
Dear Listers,
I have added a new feature to the Email List Forums at Matronics called a Wiki. What's "Wiki" you ask? A Wiki is a website. You go to it and browse just like you would any other web site. The difference is, you can change it. You can put anything you want on this web site without having to be a web designer or even being the owner. You can write a new page just like writing an email message on the BBS. You don't need to send it off to anyone to install on the site. It is kind of like a Blog (weblog) in which anyone can post. Here is a great page on where the term Wiki came from and what it means in the context of a website: http://en.wikipedia.org/wiki/Wiki
So on to the new Matronics Email List Wiki... I've created this site for anyone from any of the Email Lists to use. I envision that there are a great many things that can be added to this new Wiki since there are always new and interesting tidbits of useful information traversing the Lists.
Off the main Matronics Email List Wiki page, you will find a link called "Community Portal". Here you will find more links to stubs for all the various Lists found at Matronics (and a few other links). Brian Lloyd and others from the Yak-List have already begun adding content in a number of areas. Bob Nuckolls of AeroElectric fame has added a great article on "Ageing Aircraft".
I have discussed the new Matronics Email List Wiki with Tedd McHenry and Dwight Frye of the RV Wiki Site and they have decided to merge their site over onto the new Matronics Wiki server giving everyone a single source for information on RV building and flying! This migration will begin today and you should be able to find all of the content currently found at www.rvwiki.org moved over to the Matronics Wiki within a few days.
To make edits to the Matronics Wiki, you will need to have a login account on the Matronics Wiki and I have disabled anonymous edits. This protects the Wiki site from automated spam engines and other nuisances that could compromise the data at the site.
Signing up for an account is fast and easy and begins by clicking on the "create an account or log in" link in the upper right hand corner of any page. Note that you do not have to have a login or be logged in to view any of the content.
The Matronics Email List Wiki is YOUR Wiki! It is only as useful as the content found within. The concept of the Wiki is that the people the use it and update it. If you've got an interesting procedure for doing something, MAKE A WIKI PAGE ON IT! You can even upload pictures. Saw something interesting at a flyin? MAKE A WIKI PAGE ON IT! Don't be shy, this is YOUR site to share information with others with similar interests.
Here is a users guide on using the Wiki implemented at Matronics: http://meta.wikimedia.org/wiki/Help:Contents This gives a lot of great information on how to get started editing pages.
And finally, here is the URL for the Matronics Email List Wiki:
http://wiki.matronics.com
Brian Lloyd has written an excellent introduction to Wikis on the front page. I encourage you to read it over, then drill into the "Community Portal" and HAVE FUN!!
Best regards,
brian
PostPosted: Sat Apr 01, 2006 3:57 pm    Post subject: Matronics Email List Wiki! Reply with quote
Well, Matt has finally announced it. I have been working on it and Gus
Fraiser has put the manual for the SP-91.
The original purpose was to organize the good information that flies by
on the mailing lists and give it a good, permanent home. If you recall,
I offered to organize the Jeff Linebaugh's EP series and the information
that came back from it. This is where I intend to do that.
But the real key is that anyone can add anything they think is important
or useful. For example, there is a "current events" section. If you and
some buds are going out flying tomorrow afternoon, put it on the current
events page. Then others can see and join in. You can always take it
back off again tomorrow night.
If you want information about something, put up a placeholder and then
holler. That way someone can come along and fill in something. Someone
else can come in and add more information.
Perhaps the biggest concern I have heard about this has been, "what if I
put up information and someone changes it to put up wrong information?"
Valid point. I have two responses to this:
1. people already do that on the mailing list and it just gets corrected;
2. you can go back and fix it, perhaps adding more information to
clarify why the other information was wrong.
I am hoping that people will dive in and start fleshing this out. I
would like to see it turn into the comprehensive on-line aviation
encyclopedia. And it has the advantage that, if YOU think it is
important YOU can put it up there. You don't have to convince someone
else that they should put in time to put something up there for you.
Bon apetit'!
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
Brian Lloyd
