jfowler120(at)verizon.net Guest
Posted: Mon May 25, 2009 10:42 am Post subject: wing attachment |
We have 220 hours on our 601XL and check the wing attachment fittings about every hundred hours -- although a bit tardy this time. A partner recently noticed that there was just a bit of fore-and-aft give on the left wing. The main spar attach bolts on both wings checked good. However, the left rear attach bolt required somewhere between one and two turns to tighten firmly -- about one turn on the right wing.
I would strongly suggest checking spar attachment at least every 100 yours, particularly the rear attachment point. I am not an engineer but suspect that slight fore-and-aft movement while flying could very well lead to a catastrophic wing failure starting at the trailing edge. Sound familiar?
Karl
PatrickW
Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
Posted: Wed May 27, 2009 4:45 am Post subject: Re: wing attachment |
Perhaps some Inspector's Lacquer ("witness paint") on the nut would help provide a visual indication that could be checked during preflights.
What is working for others out there...?
- Pat
