		shinden33
				 Posted: Sat May 30, 2009 4:44 am    Post subject: Yak-52 Battery Switch Sanity Check |
				All,
 Sanity Check needed.  Yak-52 battery switch terminals (on the back, not switch position):
 Top- external
 Mid - Off/ground?
 Bot- battery
 Is this correct?
 Scott
 N8252
				 Posted: Sat May 30, 2009 5:14 am    Post subject: Yak-52 Battery Switch Sanity Check |
				Scott,
  Looking at the back of the battery switch, the top section  where the buss bar is located, is the BATTERY side when you have the battery  switch in the UP position on the front.  Put your volt meter on the buss  bar, flip the battery switch to the UP position and you should read the battery  voltage.
  Dennis
  [quote]   ---
		shinden33
				 Posted: Sat May 30, 2009 5:21 am    Post subject: Re: Yak-52 Battery Switch Sanity Check |
				Thanks!
