Is a pop rivet acceptable for a ground attachment?
rgf(at)dcn.davis.ca.us
PostPosted: Wed May 13, 2009 3:20 pm    Post subject: Is a pop rivet acceptable for a ground attachment? Reply with quote
I am grounding a gizmotron (Dynon pitot heater controller) to a wing rib
with a Fast-On Tab. I used a pop rivet to attach the Tab to the rib, but
then it occurred to me this might not be acceptable. The Tab can rotate
around the rivet, though not freely or loosely. I'm not concerned about the
mechanical properties as much as the electrical. Maybe a tighter connection
is required?
Having been wrong about almost everything electrical in the past, I thought
I'd post here and get a definitive answer.
Ralph Finch
Davis, CA
RV-9A QB-SA
PostPosted: Wed May 13, 2009 7:27 pm    Post subject: Is a pop rivet acceptable for a ground attachment? Reply with quote
is required?
I'd post here and get a definitive answer.\
What you're looking for in bringing terminal and airplane
together is a GAS TIGHT joint. This is between the terminal
face that comes into contact with the aircraft's metallic
surface.
This usually means that you've applied enough force
to DEFORM irregularities in the two surfaces and literally
squash the materials together. This is the same
process described in:
http://www.aeroelectric.com/articles/CrimpTools/crimptools.html
http://www.aeroelectric.com/articles/terminal.pdf
If you want a local grounding joint that outlasts
the rest of the airplane use 10-32 hardware to bring
terminal and airplane together. Brighten up the terminal
surface that touches the airplane. Brighten up
the airplane that touches the terminal. SMOOTH! and
SHINY! don't scuff it up with coarse abrasives.
Make up the joint with the a washer between
screw head (or nut) and the opposite side of
the terminal. Use metal locknut (MS21042-L3)
on the screw.
"Icing on the cake" is to coat one of the mating
electrical conduction surfaces with thin layer
of silicone grease before mating. Torque to
20 in-lbs.
THAT joint will not spin on the screw . . in
fact, you should tear the wire grip off the
terminal before the rest of it moves. If you
pop-riveted a nav light ground, it would probably
be okay but the higher you go in current through
the joint the more important it is to get it
gas tight. Short of soldering/welding the joint,
what I've described is the best we know how to
do.
( -Thomas Paine 1776- )
PostPosted: Wed May 13, 2009 8:46 pm    Post subject: Is a pop rivet acceptable for a ground attachment? Reply with quote
Thanks Matt and Bob. Once again you guys confirmed my suspicions that I
have much to learn.
RF
larry(at)macsmachine.com
PostPosted: Thu May 14, 2009 6:53 am    Post subject: Is a pop rivet acceptable for a ground attachment? Reply with quote
Ralph,
I used an A5 pop for securing a ring lug to ground my tanks and there
are a few hundred providing
ground from the firewall back to the batteries without any problems.
Perhaps a A5 would be better
than an A4, but that's it.
is required?
Ralph Finch
Davis, CA
RV-9A QB-SA
PostPosted: Thu May 14, 2009 8:19 pm    Post subject: Is a pop rivet acceptable for a ground attachment? Reply with quote
I replaced two ground wires using pop rivets with solid driven rivets. Much
tighter connection and it makes me feel better anyway.
hotwheels
PostPosted: Fri May 15, 2009 6:56 am    Post subject: Re: Is a pop rivet acceptable for a ground attachment? Reply with quote
I didn't see anything about pop rivet grounds in AC43.13-1B-Change1 doc... See Section 15 Grounding and Bonding. I used several plate nut grounds similar to that shown in Tables 11-15 and 11-16 (see attached).
Jay
is required?
Ralph Finch
Davis, CA
RV-9A QB-SA
Grounds.pdf
 Filename:  Grounds.pdf
 Filesize:  101.93 KB
 Downloaded:  632 Time(s)
MauleDriver(at)nc.rr.com
PostPosted: Tue May 19, 2009 2:34 pm    Post subject: Is a pop rivet acceptable for a ground attachment? Reply with quote
Bob detailed out the acceptable practice documented in AC43.13-1b part
11-190. I kept a copy of that page handy as I wired up my first few
grounds.
(sorry if someone already said this, I'm catching up on email)
Bill "back from some r&r" Watson
RV10
is required?
Ralph Finch
Davis, CA
RV-9A QB-SA
