steerr(at)bellsouth.net Guest
Posted: Wed May 13, 2009 6:44 am Post subject: Tach hookup for Stratus/Subaru |
Hello all. I recall somebody posting a note here some time ago about
how they hooked up their tach for the standard FWF kit from Zenith.
Larry has kindly sent me the drawing of his system, but he's using the
TP-45 modules and I'm not (yet). If anybody has used the standard tach
and the unmodified engine ignition from Stratus, can you please let me
know where your tach signal leads are connected? Also, did you make
your connections using the hand-written sketch Zenith supplies in their
FWF documentation?
Thanks very much.
Bill
tshankland(at)sbcglobal.n Guest
Posted: Thu May 14, 2009 8:02 am Post subject: Tach hookup for Stratus/Subaru |
Bill,
I used a standard VDO tach on my Stratus engine. The tach lead goes to
the ground side of the ignition coil. I did have some problems with an
unstable reading at around 3000 RPMs. I tracked it down to a short (2
msec) pulse that sometimes came from the system. I used the attached
circuit to tame the problem. Been flying over a year with a steady
reading tach.
Tim Shankland
Bill Steer wrote:
tach and the unmodified engine ignition from Stratus, can you please
let me know where your tach signal leads are connected? Also, did you
make your connections using the hand-written sketch Zenith supplies in
their FWF documentation?
Thanks very much.
Bill
32.87 KB |
2484 Time(s) |
bryanmmartin
Posted: Sat May 16, 2009 7:20 am Post subject: Tach hookup for Stratus/Subaru |
I have the original Stratus ignition system with the second backup
system and a VDO tach from Zenith. I bought two small signal diodes
from radio shack and hooked the tach into the negative wire from
ignition module to the coil on each system through a diode. The diodes
isolate the two ignition systems from each other but allow the signal
from either to get out to the tach. My system is set up so that only
one system will run at any time.
Here's a drawing of what I did. When I first hooked the system up, I
had the diodes in the wrong way and had to reverse them. I think I
corrected this drawing to reflect that.
On May 13, 2009, at 10:38 AM, Bill Steer wrote:
about how they hooked up their tach for the standard FWF kit from
Zenith. Larry has kindly sent me the drawing of his system, but
he's using the TP-45 modules and I'm not (yet). If anybody has used
the standard tach and the unmodified engine ignition from Stratus,
can you please let me know where your tach signal leads are
connected? Also, did you make your connections using the hand-
written sketch Zenith supplies in their FWF documentation?
Thanks very much.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
File0024.pdf |
816.13 KB |
383 Time(s) |
_________________ --
Bryan Martin
do not archive. |
