mike.l.west(at)hotmail.co Guest
Posted: Mon Apr 27, 2009 7:20 pm Post subject: ECU - EFI - Dual Battery Bus - Schottky Diode ? |
Hello C Hello C
Wondering if anyone has tried using dual Schottky diodes to power fuel injectors and ignition coils from two batteries ?
I'm looking for a 2 battery system with fuel injectors and ignition coils fed directly from both batteries.
If one battery fails the other battery automatically powers injectors & coils (and is isolated from bad battery by Schottky).
Any thoughts ?
Thanks C
-Mike
PDF attached
Windows Live™ SkyDrive™: Get 25 GB of free online storage. Check it out.
Description: |
 Download |
Filename: |
P51_PwrDist_Hmmm.pdf |
Filesize: |
351.21 KB |
Downloaded: |
480 Time(s) |
Peter Laurence
Posted: Tue Apr 28, 2009 4:06 am Post subject: ECU - EFI - Dual Battery Bus - Schottky Diode ? |
Mike
Check with a company called SDS. http://www.sdsefi.com/ They sell an electronic fuel injection system. One has been their RV6A for a few years.
I know that it’s narrowing pretty tightly with using a Schotty, but, can’t hurt to ask.
Peter
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mike West
Sent: Monday, April 27, 2009 11:19 PM
Subject: ECU - EFI - Dual Battery Bus - Schottky Diode ?
Hello, Hello,
Any thoughts ?
-Mike
PDF attached
dennis.glaeser(at)eds.com Guest
Posted: Tue Apr 28, 2009 10:50 am Post subject: ECU - EFI - Dual Battery Bus - Schottky Diode ? |
I'm doing that with my Subaru engine. I do have dual ignition switches,
but when both are on for takeoffs and landings, it is exactly what you
describe.
My architecture is essentially Z-19.
Dennis Glaeser
Hello
Any thoughts ?
-Mike
Eric M. Jones
Posted: Thu Apr 30, 2009 5:42 am Post subject: Re: ECU - EFI - Dual Battery Bus - Schottky Diode ? |
Perihelion Design has sold a bunch of dual Schottkys to do exactly what you want. See:
www.periheliondesign.com/downloads/powerdeuceschottkymanual.pdf
"Amateurs built the Ark, professionals built the Titanic."
--Anonymous
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
longg(at)pjm.com Guest
Posted: Fri May 01, 2009 6:10 am Post subject: ECU - EFI - Dual Battery Bus - Schottky Diode ? |
Mike,
It sounds like you are working with some kind of conversion but don’t ignore dual alternators as a solution. Jeg’s and other provide automotive solutions for dual alts. In many ways it’s easier to hook up two alternators than dual diodes, batteries, switches, cables etc. and provides redundancy that doesn’t need charging and constant monitoring. E.g. ala Z/13-8 or 20. In my experience, alternators either work or they’re broken.
If the EC3 is worth its salt, it will survive a voltage loss down to a certain value, say 5 volts (ala Lightspeed). Having the second alternator will help ensure it never gets there. If they die by not having 11-12 volts all the time, I’d buy another product. If you turn everything else off, staying alive down to 5 volts gives one ample time to find a landing spot.
Glenn
Sent: Thursday, April 30, 2009 9:15 PM
Thank you all very much for your responses.
Bob, I have your book (which I like very much) ... Where do you reckon I got the dual diode idea anyway ?
To my knowledge, there are 3 things to provide power to for electronic engine control: ECU (black box controller), fuel injectors & ignition coils. The ECU is shown in the Aeroelectric diagrams ... but not the injectors or coils.
The ECU I have is made by Real World Solutions (EC3-AA) and controls the ground side of the injectors and coils. I'm assuming they use some type of transistors/switches to turn on/off the injectors & coils. Whatever power I provide to the ECU is not used by the injectors & coils but rather for operating the internal switches in the ECU (that pulse on/off injectors & coils).
My first concern is that I have adequate voltage for the fuel injectors and the ignition coils. If the alternator dies and the batteries are at 12V then I would have ~11.5V to operate the injectors and coils (0.5V lost across Schottky diodes).
Also ... should I power the ECU at exactly the same voltage I provide to the injectors and coils? Is the ECU smart enough to recognize the voltage supplied to it and perhaps fire the injectors and coils differently based on the voltage it sees? What if my ECU was powered at 12V (thru a switch) and my injectors & coils were powered at 11.5V (thru diodes)? That is a question I will send to Real World Solutions / Rotary Aviation and post.
Yeah ... I know what you're thinkin ... we answer one question for this guy now he'll never leave us alone !
Thanks again
-Mike
Rediscover Hotmail®: Get quick friend updates right in your inbox. Check it out. Quote: | http://www.matronics.com/Navigator?AeroElectric-List | 0123456789
