naumuk(at)windstream.net Guest
Posted: Tue Apr 28, 2009 9:09 am Post subject: String answer_PTT question |
All-
1. We should police ourselves. That is not Matt's job. I think we all realize that things have gotten out of hand. Ignore and refuse to respond to posts that have passed the boundary line of libel and force yourselves to return to building questions. You can't feed the fire and expect relief from the heat.
2. Headphone console complete, wiring the PTT switch. Was going to use a Ray Allen handgrip for the pilot side and a Zenith for the other. Guess what. The Ray Allen fits one of the "Horns" of a Y stick, but both the factory Zenith handgrips will only work if you cut the "Y" off. A lister sent me a picture of a Y stick cut down to a single a couple of months ago. I saved it in my "Keepers" file but damned if can't find it. If you're out there, did you modify one of the Zenith grips to work with a Ray Allen switch? Please resend picture of your installation.
3. Thanks to the fine people at Sigtronics, I was able to (Hopefully correctly) wire for a combination U174/ Standard mic/headphone jack. Beautiful helo headsets are available for 25% the price of standard, probably because of the U174 connection hassles. Schematic for an A200/SPA400 available from me on request.
Bill Naumuk
Townville, Pa.
HDS 601MG/Corvair 95%
Juan Vega Jr
Posted: Tue Apr 28, 2009 10:20 am Post subject: String answer_PTT question |
Billy
I am flying through Georgia on the 601 May 19th or 20th. Where are you as I may stop by and say Hi!
I am going to go golfing and fishing for 5 days in the Highlands and will fly in to a lower altitude field on the SC side, then rent a car.
Juan Vega
s.clive.richards(at)homec Guest
Posted: Tue Apr 28, 2009 1:32 pm Post subject: String answer_PTT question |
Bill
Copy of picture you were looking for attached plus a copy of our panel.
I am not sure of your problem, as far as I am aware the vertical tube is the same diameter as the horns. We attached a Ray Allen grip with trim & PTT switchs to LHS of Y , for the RHS we fitted a small n/o switch for ptt into the top of the plastic grip supplied & slid this onto the RHS of the Y using some lubrication with no problem. We have a intercom fitted & find the Y stick comfortable & easy to change control between pilots & for the co pilot to operate the radio .
Clive
G CBDG 601HD 290 Hrs
38.21 KB |
2491 Time(s) |
24.37 KB |
2491 Time(s) |
Posted: Tue Apr 28, 2009 2:59 pm Post subject: String answer_PTT question |
Clive-
Attached is a picture of my Y stick. To the left is the Zenith supplied grip, to the right is the Ray Allen. I'm sure you can see the step down from the main shaft of the Y to the ears, as well as the obviously oversized Zenith supplied grip. I've been putting up with crap like this for 6 years. Very few parts supplied were to plans and I wound up having to modify them to fit or make them myself from scratch.
Thanks for the single stick picture. Looks like other than a stock Ray Allen grip was used, and it sure isn't Zenith supplied.
Bill
176.12 KB |
2481 Time(s) |
