Wiring 912 ULS oil pressure sensor
Mike Hoffman
PostPosted: Mon Apr 27, 2009 10:25 am    Post subject: Wiring 912 ULS oil pressure sensor Reply with quote
I have a new 100 hp 912 uls and it came with wiring to the oil pressure switch. The older engines only had one wire and the new engines now have 3 wires (black, white and red). The black is cut off and appears they are only using the Red and White.
The wiring diagrams I have do not show how to wire the new 2 wire set up to the oil pressure gage. I could guess at it but prefer not to. If I had to guess, red would go to the "S" post and the white would be added to the "-" gnd post.
Has anyone else encountered this?
Mike H
dpark748(at)hotmail.co.uk
PostPosted: Mon Apr 27, 2009 11:52 am    Post subject: Wiring 912 ULS oil pressure sensor Reply with quote
Mike C
Rotax apparently no longer use the old VDO sender and now use a Honeywell sender with red/white/black - not used/shield.
I have bought a UMA 1 1/4" gauge to match sender. White - signal/ Red - 14 volts/ Shield - to ground at the gauge.
Waiting for fuselage coming back from spraying!!!!! to fit!!!!
Regards Dave
[quote] Subject: Wiring 912 ULS oil pressure sensor
Date: Mon C 27 Apr 2009 11:25:04 -0700
--> RotaxEngines-List message posted by: "Mike Hoffman" <mhoffman9(at)tampabay.rr.com>
I have a new 100 hp 912 uls and it came with wiring to the oil pressure switch. The older engines only had one wire and the new engines now have 3 wires (black C white and red). The black is cut off and appears they are only using the Red and White.
The wiring diagrams I have do not show how to wire the new 2 wire set up to the oil pressure gage. I could guess at it but prefer not to. If I had to guess C red would go to the "S" post and the white would be added to the "-" gnd post.
Mike H
http://forums.matronics.com/viewtopic.php?p=241483#241483
Mike Hoffman
PostPosted: Tue Apr 28, 2009 1:12 am    Post subject: Re: Wiring 912 ULS oil pressure sensor Reply with quote
Thanks Dave,
I guess I now need to decide if I should replace the sender with the old VDO style or try and find a gage that matches my others.
Thanks again,
Mike H
rampil
PostPosted: Tue Apr 28, 2009 6:52 am    Post subject: Re: Wiring 912 ULS oil pressure sensor Reply with quote
Hi Mike,
Be careful of the desire to have style replace safety.
The old VDO sender was a dog which is why it was switched, big
mass on a moment arm, none too accurate either.
Best of luck with the gauge
Ira
Ira N224XS
Mike Hoffman
PostPosted: Wed Apr 29, 2009 3:02 am    Post subject: Re: Wiring 912 ULS oil pressure sensor Reply with quote
Thanks Ira, I ordered a new sender for now. Ill change it out later when I find a gage that works out. I didn't realize the old gage was a problem.
K Dilks
PostPosted: Wed Apr 29, 2009 11:00 pm    Post subject: Re: Wiring 912 ULS oil pressure sensor Reply with quote
Honey well sensor does not work on the VDO gauge.
Get the Road electronic gauge Rotax part number 956413.
956413 Oeldruckgeber technische Spezifikationen.pdf
 Filename:  956413 Oeldruckgeber technische Spezifikationen.pdf
 Filesize:  189.75 KB
 Downloaded:  971 Time(s)
Back home .................
Mike Hoffman
PostPosted: Thu Apr 30, 2009 1:38 am    Post subject: Re: Wiring 912 ULS oil pressure sensor Reply with quote
K Dilks, Thanks for the part number.
Mike H
