Showplanes flap position device
woxofswa
PostPosted: Fri Apr 24, 2009 6:32 pm    Post subject: Showplanes flap position device Reply with quote
I bought the flap preposition device when I bought my fuselage kit.
As I was preparing to wire it up today, I thought of a question.
When EFIS displays show flap position, are they working off of this device or a different device, and if the latter, does that make this device redundant or are both necessary to get both pre-select function and EFIS display?
Thanks in advance.
Myron Nelson
Mesa, AZ
Flew May 10 2014
Tim Olson
PostPosted: Fri Apr 24, 2009 7:34 pm    Post subject: Showplanes flap position device Reply with quote
If you got the standard positioner like I have from Van's, made by
Showplanes, it doesn't come with a position sensor...it's just a
positioner. I haven't really missed not having a position sensor, but
you can pretty easily use a sensor for things like Mac servos and
make it display on your EFIS if that's an option. The standard
positioner has worked great for me now for 480 hours, so I'm
real satisfied with it. Adding a sensor and display would be
a pretty cheap and easy task.
Thanks in advance.
Myron Nelson
Mesa, AZ
Emp completed, legacy build fuse in progress
http://forums.matronics.com/viewtopic.php?p 41164#241164
rene(at)felker.com
PostPosted: Fri Apr 24, 2009 7:35 pm    Post subject: Showplanes flap position device Reply with quote
I had to add a sensor for flap position. Did it during my first annual.....
Rene' Felker
RV-10 N423CF Flying
801-721-6080
ScooterF15
PostPosted: Sat Apr 25, 2009 3:50 am    Post subject: Showplanes flap position device Reply with quote
This post shows a picture of my position sensor installation: http://forums.matronics.com/viewtopic.php?t=11004
-Jim
On Fri, Apr 24, 2009 at 9:32 PM, woxofswa <woxof(at)aol.com (woxof(at)aol.com)> wrote:
[quote]--> RV10-List message posted by: "woxofswa" <woxof(at)aol.com (woxof(at)aol.com)>
Thanks in advance.
Myron Nelson
Mesa, AZ
http://forums.matronics.com/viewtopic.php?p=241164#241164
t Un/Subscription,
www.matronics.com/Navigator?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
woxofswa
PostPosted: Sat Apr 25, 2009 10:28 am    Post subject: Re: Showplanes flap position device Reply with quote
Thanks guys. I was hoping that the positioner would also function as a position sensor, but I guess that would be too convenient.
Myron Nelson
Mesa, AZ
Flew May 10 2014
