Bill1200
Joined: 19 Oct 2008 Posts: 111 Location: medford oregon
Posted: Fri Apr 24, 2009 8:43 am Post subject: recommendations for repair |
Front plug #1 cylinder blew out and broke heat shield (see attachment). Looking for recommendations on repair
434.7 KB |
5157 Time(s) |
vectorwarbirds(at)AOL.COM Guest
Posted: Fri Apr 24, 2009 9:08 am Post subject: recommendations for repair |
You can use a Heli Coil or Keenserts repair kit to fix this, others as well. You must grease the tap flutes to catch the metal shaving as the tap cuts them, removing the tap several times to clean and regrease. Then install the Heil Coil or Keensert for new threads. If you bring the cylinder up of the exhaust stroke with the valve open you can then blow out any particles that might have fallen into the cylinder. Done this many times in the past.
Looks like it was either left loose or overtightened and pulled the threads out. Most people should really use a torque wrench when installing spark plugs as they just don't have the feel from years of experience.
Good luck! Easy fix really.
The Great Bunndini
Vector Warbirds USA
dougsappllc(at)gmail.com Guest
Posted: Fri Apr 24, 2009 9:18 am Post subject: recommendations for repair |
Bill,
Gary is correct on the cly fix. I may have a used heat shield, will check later today.
Doug
On Fri, Apr 24, 2009 at 9:43 AM, Bill1200 <billdykes52(at)gmail.com (billdykes52(at)gmail.com)> wrote:
Always Yakin,
Doug Sapp
Phone 509-826-4610
Fax 509-826-3644
Bill1200
Posted: Fri Apr 24, 2009 11:18 am Post subject: Re: recommendations for repair |
Thanks guys. I should have been more specific. I want to repair the shield only. The spark plug socket seems fine. I reinstalled a new plug and it tightened fine, ran the engine up to full power plug stayed in fine.
Bill1200
Posted: Fri Apr 24, 2009 11:20 am Post subject: Re: recommendations for repair |
BTW, what is the torque for the plugs
vectorwarbirds(at)aol.com Guest
Posted: Fri Apr 24, 2009 11:42 am Post subject: recommendations for repair |
Plug torque: 216 to 240 inch pounds or 18-20 foot pounds. A small inch pound torque wrench is best, they sell a nice little one at Sears. A small dab of anti-seize compound as well on the threads.
Bunndini
