pavel569
Posted: Thu Apr 16, 2009 12:06 pm Post subject: Main gear flex |
One building question in this "grounding" war time.
Placement of my radiator. To have Stratus Subaru as my powerplant, I'm trying to shift the water radiator as aft as possible to balance this heavier engine. I have a set of Alu pipes for using with air intake from Larry McFarland. They are 32" long and I'd like to keep the length as is. It will move the radiator way back so it will be partially under the main gear. Does anybody know how much the landing gear center section flexes down when land hard? I can move the radiator up or down by fabricating its side brackets.
Generally, is it a good idea or is it better to keep it forward, in front of the gear channel?
_________________ Pavel
CA
Zodiac 601XL
Stratus Subaru EA-81
Tail, flaps, ailerons, wings, fuselage, canopy done ...
"do not archive" |
Gig Giacona
Posted: Thu Apr 16, 2009 1:09 pm Post subject: Re: Main gear flex |
| pavel569 wrote: |
Generally, is it a good idea or is it better to keep it forward, in front of the gear channel? |
I would think so. Watch this video.
http://www.zenithair.com/video/gear_drop_test.mpeg
601XL Under Construction
Heatonhe36(at)msn.com Guest
Posted: Thu Apr 16, 2009 1:20 pm Post subject: Main gear flex |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Pavel,
Check out the gear drop test on the Zenith site: http://www.zenithair.com/video/gear_drop_test.mpeg
I have the same problem with my radiator, so I am placing it behind the main gear with the coolant tubes outboard under the gear attach brackets. I wouldn't put anything across the center of the main gear strut.
Herb
Colorado Springs, CO
Subaru EA-81 Turbo
Wiring Panel
bryanmmartin
Posted: Thu Apr 16, 2009 1:21 pm Post subject: Main gear flex |
Looks like a good three to four inches of flex there. A more efficient
location might be behind the main gear (look at a P-51 Mustang) and
you might even get away with a smaller radiator, but it would require
more plumbing.
On Apr 16, 2009, at 5:09 PM, Gig Giacona wrote:
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
Gig Giacona
Posted: Thu Apr 16, 2009 1:35 pm Post subject: Re: Main gear flex |
Not a water cooled guy but how big around are these coolant lines?
I'm thinking longer lines = more water = more weight. Weight = Bad.
pavel569
Posted: Thu Apr 16, 2009 2:30 pm Post subject: Re: Main gear flex |
Thanks for your replies, guys. I'll try to fit the radiator with all braces to find out how much clearance I can get, but I'll have to stay in front of the main gear, I guess. I want to keep it simple as much as possible. Better move the battery behind the seats or even add one more to balance the plane.
CA
Zodiac 601XL
"do not archive" |
Posted: Thu Apr 16, 2009 2:41 pm Post subject: Main gear flex |
Remember that pipes have friction. You can't just keep extending the lines
without having an impact on their flow rate. There is a formula for this
somewhere. You could do some calculations before building or built and test.
-- Craig
flyboy3847(at)onecommail. Guest
Posted: Fri Apr 17, 2009 5:41 am Post subject: Main gear flex |
Your best bet is to look at Larry McFarland's website. He's flying the same
configuration and has hundreds of hours on his HDS. I'm using the same
pipes and hoses he is and I've had good success with weight & balance so
far. I'm using the VW Diesel Rabbit Radiator (it's slightly larger),
Larry's scoop and an aluminum heater core. The water temp has never gone
over 180 degrees even at full static RPM. I think if you're going to
counterbalance the weight of the engine you might as well make the weight
useful.
Leroy Wheeler
N601LH About to certify
pavel569
Posted: Fri Apr 17, 2009 6:04 am Post subject: Re: Main gear flex |
Leroy,
I'm using the pipes and scoop and radiator louvers from Larry too. The only, but important, difference is that I'm building 601XL not HDS with solid one piece landing gear across the fuselage. However it may become an option in case they'll limit speed of XL to 97 kts or so, I'll probably switch to HDS instead.
| flyboy3847(at)onecommail. wrote: | Your best bet is to look at Larry McFarland's website. He's flying the same
useful.
Leroy Wheeler
CA
Zodiac 601XL
"do not archive" |
jmaynard
Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
Posted: Fri Apr 17, 2009 7:17 am Post subject: Main gear flex |
On Fri, Apr 17, 2009 at 09:41:16AM -0400, Leroy Wheeler wrote:
| Quote: | Your best bet is to look at Larry McFarland's website. He's flying the same
This won't help. The original poster is building an XL, and he wants to know
if he can put the radiator beneath the gear center section - and the XL gear
is entirely different from the HD/HDS main gear.
Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com
Fairmont, MN (KFRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
