frank.goodnight(at)att.ne Guest
Posted: Wed Apr 15, 2009 11:33 am Post subject: worn bolts |
My firestar2 has only got 75 hrs. on it. Today I took the bolts out of
the universal joint at the
rear of the wings. I was shocked to find that one of them had a ring
about 1/32 of an inch
deep worn around it. I don"t know why only one bolt was worn and the
others were ok.
Maybe it was a little to loose, they have to be loose enough for the
universal to work.
At any rate with another 75 hrs. ti would have worn enough to be
really spooky.
Anyone else have this problem? I will remove and check ALL airframe
bolts at my 100 hr. check.
Frank Goodnight
Brownsville, TX.
Posted: Wed Apr 15, 2009 11:50 am Post subject: worn bolts |
| Quote: | about 1/32 of an inch
Probably the cad plating was worn off. I'd have to go do some research to
find out how thick the cad plating is on aircraft bolts. Its on there to
lubricate and protect the bolt, self sacrificial.
I don't fold, so all my bolts are snugged up tight. If I did have to fold
each time I flew, I think I might snug up the bolts prior to flight, then
loosen them up a bit to fold.
_________________ John Hauck
Titus, Alabama |
Posted: Wed Apr 15, 2009 12:12 pm Post subject: worn bolts |
Hi John,
The wear is much deeper than the plating.I do fold every time I
fly,It's a lot of trouble
but fits my budget better than hanger rent. It's also rough on my
airplane.
Frank Goodnight
Firestar2
HKS
On Apr 15, 2009, at 2:49 PM, John Hauck wrote:
> Frank Goodnight
research to find out how thick the cad plating is on aircraft
bolts. Its on there to lubricate and protect the bolt, self
sacrificial.
to fold each time I flew, I think I might snug up the bolts prior to
flight, then loosen them up a bit to fold.
JetPilot
Posted: Wed Apr 15, 2009 12:17 pm Post subject: Re: worn bolts |
Its a real good idea to check all bolts and fittings that could wear with vibration. I put Mobil 1 Synthetic grease on all bolts and fittings that move against each other. This grease is hard to find, but its worth the effort, its far better than any other grease I have ever used. Some will say that grease will attract and hold dirt, which is true. While not perfect, my greased joints have not worn all in just over 200 hours. A greased fitting, even though not perfectly clean is far better than metal vibrating against metal. Where others have been getting wear, I do not get any.
There is the added benefit of zero corrosion in these areas also.
Mike
Kolb MK-III Xtra, 912-S |
russ(at)rkiphoto.com Guest
Posted: Wed Apr 15, 2009 12:39 pm Post subject: worn bolts |
Jetpilot
Aren't you in the Miami area?
And you have "zero corrosion" that close to salt water? And very
salty water at that. I find that hard to believe.
Russ K
On Apr 15, 2009, at 4:17 PM, JetPilot wrote:
Mike
http://forums.matronics.com/viewtopic.php?p 39346#239346
JetPilot
Posted: Wed Apr 15, 2009 1:46 pm Post subject: Re: worn bolts |
| russ(at)rkiphoto.com wrote: | Jetpilot
Russ K
Yes, zero corrosion in my greased joints. I don't know why that seems hard to believe, grease is an excellent, think corrosion preventative that is thick and does not evaporate over time like many of the light oils do. If you have doubts as to if it works or not, try it on one elevator half pivot bolt, or other high wear area, and leave the other side dry, and compare your results after the next 100 hours.
Mike
Posted: Wed Apr 15, 2009 2:10 pm Post subject: worn bolts |
Sorry, jetpilot, my mistake.
When you said you had "zero corrosion" I assumed you meant no
corrosion anywhere. Obviously there'll be no corrosion under a film
of grease.
I still recall the endless polishing by the guys who had polished-
aluminum Cessnas -- even many miles from the coast.
Russ K
On Apr 15, 2009, at 5:46 PM, JetPilot wrote:
> Jetpilot
> Russ K
> do not archive
the next 100 hours.
Mike
http://forums.matronics.com/viewtopic.php?p 39365#239365
lucien
Posted: Wed Apr 15, 2009 2:18 pm Post subject: Re: worn bolts |
| frank.goodnight(at)att.ne wrote: | My firestar2 has only got 75 hrs. on it. Today I took the bolts out of
others were ok.
universal to work.
really spooky.
Frank Goodnight
Brownsville, TX. |
I never actually pulled the bolts on mine (I hope Bob does at some point), but I did at one point pull the joint apart to troubleshoot the little bit of slop at the channel bracket where it bolts to the frame.
That whole joint is well designed (IMO), but is fairly low tech. It doesn't have to be high-tech because it's not a high speed or constantly moving joint, but it can eventually start to wear if you fold the wings a lot.
If the bolts are that worn I'd also check for slop at that channel bracket, as if it gets too bad it can change the AoA of the wing panel slightly. The original builder of my plane used shims of some kind under the channel bracket to tighten it up (he folded it all the time too).
I'd treat the bolts and the channel brackets as consumables if I folded every flight (i.e. I'd have spares on hand and would replace on a regular basis)....
LS
_________________ LS
Titan II SS |
Posted: Wed Apr 15, 2009 2:24 pm Post subject: worn bolts |
At 02:31 PM 4/15/09 -0500, you wrote:
Frank,
Steel on steel is not good. I have had a similar problem with my FireFly.
I solved it by bushing the holes. See:
http://www.thirdshift.com/jack/firefly/firefly128.html
Fly safe,
Jack B. Hart FF004
Winchester, IN
Dana
Posted: Wed Apr 15, 2009 2:28 pm Post subject: worn bolts |
At 03:49 PM 4/15/2009, John Hauck wrote:
Cad plating is at most .0005" thick, according to the MIL-Spec... Frank
said his bolts are worn 1/32" (.03125"), which is sixty times more than the
plating thickness.
-Dana
A cement mixer collided with a prison van on the highway. Motorists are
asked to be on the lookout for sixteen hardened criminals.
Dana
Posted: Wed Apr 15, 2009 2:33 pm Post subject: worn bolts |
At 06:18 PM 4/15/2009, lucien wrote:
| Quote: | That whole joint is well designed (IMO), but is fairly low tech. It
The amount of wear from folding (1/4 revolution each fold) is probably
insignificant compared to wear from vibration and changing flight loads,
unless something is way too tight or binding badly.
OTOH, the looseness required for folding allows more motion (and thus wear)
than tight bolts.
-Dana
JetPilot
Posted: Wed Apr 15, 2009 3:36 pm Post subject: Re: worn bolts |
| russ(at)rkiphoto.com wrote: | Sorry, jetpilot, my mistake.
corrosion anywhere. |
Yes, even with powder coating, the rest of the airplane requires some attention. There are some areas where I have had to remove the powder coating where it gets chipped, or for whatever reason has not sealed well, and sand off the corrosion and use Epoxy Primer. Corrosion X helps with the inside of the boom tube, and I will be putting Corrosion X it in the wing spars for the first time soon.
Fortunately, I am in an enclosed hanger which helps a lot. A Kolb left outside here would not last long
Mike
