icubob(at)gmail.com Guest
Posted: Sun Apr 12, 2009 2:36 am Post subject: fuel tank grounding |
hi all,
a friend and i have been talking about grounding tanks. some testing had showed on his plane the anodized coating of fittings had prevented the metal fuel lines from completing the ground to a tank. he fitted all his tanks with grounding wires and the owner of an antique certified aircraft from a nearby hangar stopped by. they then went to that aircraft and checked and NO GROUND. in the past 2 yrs. i have seen a plane at my airport on fire because of static at the fuel pump. check your grounds!
bob noffs
JetPilot
Posted: Mon Apr 13, 2009 7:53 am Post subject: Re: fuel tank grounding |
| icubob(at)gmail.com wrote: | hi all,
�a friend and i have been talking about grounding tanks. some testing had showed on his plane the anodized coating of fittings had prevented the metal fuel lines from completing the ground to a tank. he fitted all his tanks with grounding wires |
On my Kitfox, I have fiberglass tanks with rubber fuel hoses, so grounding the outside of the tank itself would not do anything, it would take a wire or piece of metal going into the fuel tank to make an effective ground. Can you elaborate a little more on the grounding setup you are proposing for Kitfoxes ?
Mike
Kolb MK-III Xtra, 912-S |
Lynn Matteson
Posted: Mon Apr 13, 2009 9:13 am Post subject: fuel tank grounding |
I can offer what I did on my plane during the building. I soldered a
1/4" wide tinned and braided copper strap to the filler neck, ran it
back and across to the rear spar, and attached it to the rear spar
mounting bolt. I covered the strap with finishing tape.
Lynn Matteson
Jabiru 2200, #2062, 628.1 hrs
Sensenich 62x46
Status: flying
On Apr 13, 2009, at 11:53 AM, JetPilot wrote:
> hi all,
Mike
http://forums.matronics.com/viewtopic.php?p=238918#238918
122.19 KB |
8960 Time(s) |
117.74 KB |
8960 Time(s) |
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Guy Buchanan
Posted: Mon Apr 13, 2009 10:07 am Post subject: fuel tank grounding |
At 08:53 AM 4/13/2009, you wrote:
| Quote: | On my Kitfox, I have fiberglass tanks with rubber fuel hoses, so
Mike,
Bob Ducar, the early builder of my plane, neglected to
ground the filler necks. I therefore use a long wire with spring
clamps attached to either end to manually ground my filler neck to
the airframe whenever I fill. It's a bit of a pain, but beats having
a fire. I doubt there's really a problem because I'm willing to bet
99% of Kitfoxes don't have grounded filler necks, (Lynn's is the
first I've heard of,) and I've never heard of a filling fire in a
Kitfox. I do any anyway as a token of affection.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 300 hrs. and counting
_________________ Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
clint_bazzill(at)hotmail. Guest
Lynn Matteson
Posted: Mon Apr 13, 2009 10:34 am Post subject: fuel tank grounding |
I came up with the idea of running a strap from my filler neck to the
airframe after reading a discussion here on the list. I got a lot of
my (sometimes hair-brained) ideas as a result of reading here early
on. Of course, if someone had said that a heavy plane would handle
better, I'd probably put concrete in the tires...what do I know? : )
Speaking of a fuel-filling fire, every time I fuel up, I'm always
thinking of what I'd do "just if....." I've got a mental picture of
jumping off the stool, grabbing the extinguisher, and heroically
putting out the fire.....at least that's the mental picture. In all
probability, the 6 o'clock news would probably show a screaming,
crying, moron running away from the scene with his hair (what's left
anyway) on fire.
Lynn Matteson
Sensenich 62x46
Status: flying
On Apr 13, 2009, at 1:52 PM, Guy Buchanan wrote:
Mike,
having a fire. I doubt there's really a problem because I'm willing
to bet 99% of Kitfoxes don't have grounded filler necks, (Lynn's is
the first I've heard of,) and I've never heard of a filling fire in
a Kitfox. I do any anyway as a token of affection.
Guy Buchanan
San Diego, CA
N369LM |
MDKitfox(at)aol.com Guest
Posted: Mon Apr 13, 2009 1:54 pm Post subject: fuel tank grounding |
Lynn,
I really like what you did, but since my Fox is already covered, I just take the ground wire from the pump station and clip it to the metal filler. All we can protect is an arcing across the tank inlet anyway. Won't that work?
Rick Weiss
N39RW Series V Speedster, 912ULS
SkyStar S/N 1
Port Orange, FL
On Apr 13, 2009, at 1:02 PM, Lynn Matteson wrote:
| Quote: | I can offer what I did on my plane during the building. I soldered a 1/4" wide tinned and braided copper strap to the filler neck, ran it back and across to the rear spar, and attached it to the rear spar mounting bolt. I covered the strap with finishing tape.
<100_1289.jpg><100_1286.jpg>
Lynn Matteson
Sensenich 62x46
Status: flying
| Quote: | --> Kitfox-List message posted by: "JetPilot" <orcabonita(at)hotmail.com (orcabonita(at)hotmail.com)>
| Quote: | �a friend and i have been talking about grounding tanks. some testing had showed on his plane the anodized coating of fittings had prevented the metal fuel lines from completing the ground to a tank. he fitted all his tanks with grounding wires
Mike
= [quote][b]
Float Flyr
Posted: Mon Apr 13, 2009 4:21 pm Post subject: fuel tank grounding |
What to do in the event of a filling fire?? I guess it all depends on how
much gas is in the plane. With only a little gas in the tanks I would think
there would be an explosion. (No more worries) If the tanks were full you
would have a fire that should be able to be put out by simply covering the
filler with the gas cap. No I don't want to try that. Best idea is to have
the extinguisher handy so you won't have to get down to get it.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Mon Apr 13, 2009 5:33 pm Post subject: Re: fuel tank grounding |
I plan to njust get away from any aircraft that is on fire with no people involved.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Lynn Matteson
Posted: Tue Apr 14, 2009 8:01 am Post subject: fuel tank grounding |
I would think so, but I'm the first guy to throw hands in the air and
surrender when it comes to electrics. I'd be absolutely certain that
grounding at the neck would be the best of all worlds, though.
Wait just a minute......maybe if there was a charge built up on the
plane, and you attach a ground to the neck, will an arc jump to the
neck? And if you've got the cap off...can't see how you'd clamp onto
it if the cap WASN'T off.....BOOM?
Lynn Matteson
Sensenich 62x46
Status: flying
On Apr 13, 2009, at 1:26 PM, Weiss Richard wrote:
| Quote: | Lynn,
Rick Weiss
SkyStar S/N 1
Port Orange, FL
> Lynn Matteson
> Kitfox IV Speedster, taildragger
> Sensenich 62x46
> Electroair direct-fire ignition system
> Status: flying
>> <orcabonita(at)hotmail.com>
>>> hi all,
>> Mike
>> http://forums.matronics.com/viewtopic.php?p 38918#238918
www.matronics.com/contribution _-
N369LM |
matronics(at)bob.brennan. Guest
Posted: Tue Apr 14, 2009 8:35 am Post subject: fuel tank grounding |
I'm good at electrics, I are a engineer. According to some published
regulations:
"All aircraft shall be fueled and defueled in accordance with the bonding
ground procedures
outlined in the applicable fire codes including NFPA 407 2-3.4. In general,
all fueling
equipment and aircraft shall be electrically bonded and grounded prior to
and during fueling
and defueling activities. All bonding connections shall be maintained until
final completion
of the fueling or defueling operation. Failure to bond correctly can easily
lead to fire and
explosion. It is incumbent on all fueling operators to be trained on proper
procedures and to
perform bonding operations correctly."
So if a fueling vehicle bonds to a ground point on your aircraft it would
behoove you to make sure any metal at the filling inlet(s) are also grounded
to that point. Otherwise KA-BOOM! (maybe). All-metal aircraft are pretty
safe, all-wood and fabric and fibreglass tanks are fairly safe, fabric with
metal spars and metal tanks etc need careful grounding.
Bob Brennan - N717GB
ELSA Repairman, inspection rated
1991 UK Model 2 ELSA Kitfox taildragger
Rotax 582 with 3 blade prop
Wrightsville Pa
Fox5flyer Guest
Posted: Tue Apr 14, 2009 9:05 am Post subject: fuel tank grounding |
Uh, Lynn, wouldn't just the act of taking off the cap with your bare hands
release any built up charge at the tank? Then again, whaddoIknow. This
whole thing seems way over blown to me.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
- Joseph Joubert
plane, and you attach a ground to the neck, will an arc jump to the neck?
And if you've got the cap off...can't see how you'd clamp onto it if the
Lynn Matteson
Sensenich 62x46
Status: flying
> Lynn,
> Won't that work?
> Rick Weiss
> SkyStar S/N 1
> Port Orange, FL
>> Lynn Matteson
>> Sensenich 62x46
>> Status: flying
>>>> hi all,
>>> Mike
>>> you could have !!!
>>> Read this topic online here:
Lynn Matteson
Posted: Tue Apr 14, 2009 1:12 pm Post subject: fuel tank grounding |
"Blown" is the operative word here.....hoping we don't hear it. : )
Lynn Matteson
Sensenich 62x46
Status: flying
On Apr 14, 2009, at 12:52 PM, fox5flyer wrote:
<fox5flyer(at)idealwifi.net>
bare hands release any built up charge at the tank? Then again,
whaddoIknow. This whole thing seems way over blown to me.
Deke Morisse
N369LM |
Guy Buchanan
Posted: Tue Apr 14, 2009 3:15 pm Post subject: fuel tank grounding |
At 05:17 PM 4/13/2009, you wrote:
| Quote: | If the tanks were full you
I once watched a guy do this with a burning can of white gas. He was
"encouraging" a camp fire and of course the fire climbed the gas to
the can. With the whole top of the can lit he casually stood there
and screwed the top back on, putting the fire out. Brave, drunk, or
stupid, (Or possibly all three!) it worked.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
