Ken Potter
Joined: 18 Aug 2007 Posts: 85 Location: Lanark, Ontario
Posted: Fri Apr 03, 2009 2:49 pm Post subject: Master Solenoid Hot to Touch |
Hi Folks;
In preparation to take C-FJKP out of the shop and final inspection this spring I've been running the electrical system whenever I'm in the shop working--- master switch on, radio, transponder etc. running. Last weekend when I went to do an inspection before shutting down I noticed that the master solenoid was very hot to the touch. Is this normal????
_________________ Ken Potter
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario |
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Fri Apr 03, 2009 3:47 pm Post subject: Re: Master Solenoid Hot to Touch |
| Ken Potter wrote: | Hi Folks;
In preparation to take C-FJKP out of the shop and final inspection this spring I've been running the electrical system whenever I'm in the shop working--- master switch on, radio, transponder etc. running. Last weekend when I went to do an inspection before shutting down I noticed that the master solenoid was very hot to the touch. Is this normal???? |
Yes, it's normal for the master contactor to get hot. Mine gets quite hot to the touch. Just be sure it is a continuous duty type. There is an easy way to tell but I can't seem to remember it. Someone will chime in, if not I probably have it in my building log notes somewhere.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
FlyboyTR
Joined: 04 Nov 2006 Posts: 215 Location: Mobile, Alabama
Posted: Sat Apr 04, 2009 4:36 am Post subject: Re: Master Solenoid Hot to Touch |
Warm to the touch is ok. Very hot...would be a concern. If you are using an automotive solenoid (like for a starter) I wouldn’t think this would be the best choice. They are designed for intermittent use. As Tom stated…it must be for continuous use! Most RV (camping) places sell a continuous duty solenoid for about $30-$35. We had one go bad in our bus. I did the $12 (Ford style) solenoid from Auto Zone. It worked for a couple of hours…then things started melting. TOO hot! Replace it with a continuous use model from the RV store…and all is well. It does get warm…but not hot.
Travis
_________________ Travis Rayner
Mobile, AL
Skystar Vixen, N-789DF
Continental IO-240, Prince P-Tip Prop
ADI-II Autopilot
AnyWhereMap Navigation with weather
www.enotam.net (My Flying Info Website) |
Ken Potter
Posted: Sat Apr 04, 2009 9:08 am Post subject: Re: Master Solenoid Hot to Touch |
Thanks for the input.
I'll have to go back through my receipts but I'm sure that the solenoid came from Aircraft Spruce as a continuous duty model.
Cheers
Ken
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario |
Float Flyr
Posted: Sun Apr 05, 2009 10:41 am Post subject: Master Solenoid Hot to Touch |
In a word No. You have a starter solenoid rather than a power relay. Get a
12V relay ( they look the same) from and RV outlet. They use then for back
up batteries.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Fox5flyer Guest
Posted: Mon Apr 06, 2009 4:19 pm Post subject: Re: Master Solenoid Hot to Touch |
Yes, Ken. When on for an extended length of time they can get pretty hot which is why they should be mounted in an area that receives adequate ventilation. Shouldn't be anything to worry about. Even a 60 watt lightbulb will get hot after awhile.
Deke Morisse
S5
NE Michigan
Float Flyr
Posted: Mon Apr 06, 2009 5:22 pm Post subject: Master Solenoid Hot to Touch |
The relay coil shouldn't draw more than a half an amp...600 mW. They can
get warm but if they are coming anywhere close to hot then the internal
resistance isn't high enough or you have a starter solenoid. Power relays
generally after several hours of being pulled closed will only be slightly
warm to the touch. Never hot.
Noel
Kitfox III-A
Fox5flyer Guest
Posted: Tue Apr 07, 2009 3:55 am Post subject: Master Solenoid Hot to Touch |
With all due respect, Noel, not true. The standard continuous duty
contactor that we use in our airplanes pulls nearly an amp and can put out
enough heat to get quite hot, much more than "warm". Mine sure does and
it's still working after 8 years.
Below is a quote from the Aeoelectric List on Matronics. The reply is from
Bob Nuckols of the Aeroelectric Connection.
| Quote: | Hi Bob,
My principal concern has to do with the considerable heat generated
in the battery master contactor...
just wondering if there was a reasonable alternative.
How is this heat a problem? The battery contactor generally draws
about .8A after it warms up for a total power dissipation of about
12 watts. While this amount of power produces a marked temperature
rise, it's well inside ratings for the materials used in fabrication
of the contactor.
When I was selling these things, I had a couple of builders want
to return "defective" contactors because they were overheating. I
had to explain that virtually all contactors of any size (50A class
or larger) ran too hot to touch under normal conditions. This
isn't a big deal when the alternator is running . . . you generally
have the watts to spare. However, during alternator-out, battery-only
ops, this .8A would run a couple of radios! It's a good load to get
rid of. This was one of the drivers for the alternate feedpath
to the e-bus that you see in our Z-drawings.
So, if you configure the system to limit power losses due to battery
contactor heating to times when you have the power to spare, the
lowly contactor will offer you a good return on investment.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
Ken Potter
Posted: Tue Apr 07, 2009 2:47 pm Post subject: Re: Master Solenoid Hot to Touch |
Hi Folks;
Thanks to everyone for the advice. I checked my receipt and the unit. It is the continuous duty 14 - 28 volt unit sold by Aircraft Spruce. I'm running it in a 14 volt system so it would draw a few more amps and be hotter than if it was running at 28 volts. According to the aircrafts amp-meter it is drawing about 1 amp. I will however check that their isn't any extra resistance in the connections, especially to ground.
It is hot enough that I can only keep my fingers on it for 4-5 seconds when it has been on in the shop for 2 hours at 14.6 volts. This is why I've been running up all of the systems in the shop to; check for squawks before first flight later this summer.
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario |
