Has your bubble canopy fogged up?????
Thruster87
PostPosted: Sat Apr 04, 2009 12:24 pm    Post subject: Has your bubble canopy fogged up????? Reply with quote
Has anyone experienced fogging up of your bubble canopy during flight???? Looking at putting a air supply to the front of the canopy to minimize the chance of loosing visibility. Thanks
bryanmmartin
PostPosted: Sat Apr 04, 2009 3:30 pm    Post subject: Has your bubble canopy fogged up????? Reply with quote
I've had it fog up on the ground before the engine warms up enough to
make the cabin heater effective. I have a cabin heat system that uses
hot water from the cooling system. It includes two air vents on the
dash to blow heated air on the front of the canopy. I would definitely
recommend including a windshield defogger vent in your cabin heat
system.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
Bryan Martin
do not archive.
larry(at)macsmachine.com
PostPosted: Sat Apr 04, 2009 3:33 pm    Post subject: Has your bubble canopy fogged up????? Reply with quote
Hi Alan,
I've experienced this and probably every other 601 owner has as well.
The one quickest way to clear the canopy of fog
is a microfiber towel. These will not hurt your plexi and are
recommended for cleaning and polishing the canopy. They
are found in rolled packs at Farm and Fleet and can be washed without
loosing their protective qualities.
I keep one on my back shelf for just that fog occasion. It's quicker
than anything.
http://forums.matronics.com/viewtopic.php?p 37707#237707
dredmoody(at)cox.net
PostPosted: Sun Apr 05, 2009 5:35 am    Post subject: Has your bubble canopy fogged up????? Reply with quote
I'm currently waiting on the FAA for airworthiness inspection so the only fogging I have experienced is while working inside the cabin with the canopy down. In motion, I suspect that the fresh air vents will take care of most or all fogging except for very cool / cold days. If it becomes a problem, my plan is to remove my forward top skin after marking where the canopy touches it. A couple of inches inside that line I will drill a series of 3/8" diameter holes evenly spaced to allow the electronics cooling fan to vent the warmed air up to the bubble in front. I installed a big cpu muffin fan (~ 75 cfpm) in the support from the bottom of the panel to the firewall early on. It keeps the area under the forward top skin from becoming a greenhouse-like heat dome. I figure that warm air can be put to good use as needed later on.
Ed
DaveG601XL
PostPosted: Sun Apr 05, 2009 10:03 am    Post subject: Re: Has your bubble canopy fogged up????? Reply with quote
I did some flying this winter with OAT's in the mid to upper 30's and on the ground during taxi is where I experienced canopy fogging. In-flight, I had no problems with the fog clearing up even though I only have the one hole for heat in the lower firewall. I bought a 100W 12VDC portable car de-froster unit that plugs into a cigarette lighter for taxiing. I sit it on top my panel until ready for takeoff when I un-plug and stow it. It is a very light unit and only uses the equivalent power of a landing light. Picture attached.
 Filesize:  100.51 KB
 Viewed:  10038 Time(s)
David Gallagher
Cincinnati, OH area
Thruster87
PostPosted: Sun Apr 05, 2009 12:32 pm    Post subject: Re: Has your bubble canopy fogged up????? Reply with quote
Hi DaveG601XL, I like the look of the top of your dash.Where did you source the edge rubber? and what material is the black anti-glare ?Like the sun visor for the EFIS/GPS Cheers Alan
rpf(at)wi.rr.com
PostPosted: Sun Apr 05, 2009 4:34 pm    Post subject: Has your bubble canopy fogged up????? Reply with quote
I have flown for two Wisconsin winters now and many times it's been way
below freezing and sometimes below zero. The canopy does fog up a little
bit (usually on the side, not so much in front) but I open my fresh air
vents (while I taxi and do my run up) and that keeps it to a minimum. Just
before take off I close the fresh air vents and pull on cabin heat and that
takes care of any fog that might have developed. Like Larry has mentioned,
I also carry a microfiber towel, but seldom have to use it. Like David
mentioned, I also purchased a portable car defroster but never had to use
it.
Randy Ferri
601xl/Jab3300
First flight 5/15/07
270 hours
DaveG601XL
PostPosted: Mon Apr 06, 2009 2:42 am    Post subject: Re: Has your bubble canopy fogged up????? Reply with quote
Alan,
The glare shield edging in automotive trunk seal. I actually got mine from Zenith, but I have seen the same thing sold in various on-line dealers like JC Whitney. The anti-glare paint is Rust-o-leum flat black.
David Gallagher
Cincinnati, OH area
kmccune
PostPosted: Mon Apr 06, 2009 3:29 am    Post subject: Re: Has your bubble canopy fogged up????? Reply with quote
Try this for the trim, they also have all metal and all rubber trim. This and the type Dave used, has metal in the U shaped part that covers the sheet AL. This makes it less of a cutting edge, in my way of thinking.
http://www.mcmaster.com/#trim-seals/=1bqah2
Kevin
R.W. Emerson (1803-1882)
Dorothy McCune
Tommy Walker
PostPosted: Mon Apr 06, 2009 5:58 pm    Post subject: Re: Has your bubble canopy fogged up????? Reply with quote
The good Lord knows you need some help with frogging down there in froggy bottom....
Smile
Tommy
[quote="dredmoody(at)cox.net"]I'm currently waiting on the FAA for airworthiness inspection so the only fogging I have experienced is while working inside the cabin with the canopy down. In motion, I suspect that the fresh air vents will take care of most or all fogging except for very cool / cold days. If it becomes a problem, my plan is to remove my forward top skin after marking where the canopy touches it. A couple of inches inside that line I will drill a series of 3/8" diameter holes evenly spaced to allow the electronics cooling fan to vent the warmed air up to the bubble in front. I installed a big cpu muffin fan (~ 75 cfpm) in the support from the bottom of the panel to the firewall early on. It keeps the area under the forward top skin from becoming a greenhouse-like heat dome. I figure that warm air can be put to good use as needed later on.
Ed
Tommy Walker
N25A - Anniston, AL
