matronics(at)bob.brennan. Guest
Posted: Tue Apr 07, 2009 11:23 am Post subject: was fuel tank venting, now airstrip talk |
Dave - I use a culti-packer behind my tractor on my airstrip and I find it
works better than the heaviest roller. In case you don't know what a
culti-packer is - mine is two rows of heavy steel disks with small knobs on
them, all rotating independently and about 8ft wide. I drag this up and down
my strip after a rain when the ground is soft, the knobs push higher spots
sideways to lower spots rather than compressing them like a roller. I've
found it's the only way to truly keep a strip level and flat, and the grass
healthy.
Bob Brennan - N717GB
ELSA Repairman, inspection rated
1991 UK Model 2 ELSA Kitfox taildragger
Rotax 582 with 3 blade prop
Wrightsville Pa
dave
Posted: Tue Apr 07, 2009 3:44 pm Post subject: Re: was fuel tank venting, now airstrip talk |
I never thought that would work that well.
Mine rolls nice with water when still wet but later on in year it always gets a bit bumpy again.
I was just out welding a bit more on it . Got to make a plate on ends of each roller tonight and load onto trailer and take to cement yard tomorrow. I think it will be about a metre total of cement that is just about 10% bigger than a yard . Once done I think likely 5000 lbs plus.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
