jaybannist(at)cs.com Guest
Posted: Tue Mar 31, 2009 12:08 pm Post subject: Quick build fuselage |
To 601XL quick build kit builders,
I have a friend that has a 601XL quick build kit. He is concerned about how to do work inside the cockpit, such as installation of the brake cylinders, installation of the dual sticks and the like. Since I built from component kits, I can't help him much. I would like to hear any suggestions from those that have done this kind of work on a quick build fuselage. Is there any practical solution, other than hiring a midget contortionist airframe mechanic ?
Jay Bannister
Email message sent from CompuServe - visit us today at http://www.cs.com
johnd(at)data-tech.com Guest
Posted: Tue Mar 31, 2009 12:19 pm Post subject: Quick build fuselage |
Hi Jay,
I started with a 601XL QB and didn't have a problem with installing the brake cylinders, etc. Its a bit of a balancing act at times but certainly doable since the panel isn't fully riveted and can be removed. I did go with your access hatch plans for easy access to the space behind the panel which has been nice when I need to do a couple of things behind the panel.
Now my 12 year old son who's pretty thing did help out in other areas like the rear fuselage
John Davis
N601JD
Burnsville, NC
jaybannist(at)cs.com (jaybannist(at)cs.com) wrote: [quote]To 601XL quick build kit builders,
Jay Bannister
href="http://www.matronics.com/Navigator?Zenith601-List">http://www.matronics.com/Navigator?Zenith601-List
| [b]
pdn8r(at)yahoo.com Guest
Posted: Tue Mar 31, 2009 1:02 pm Post subject: Quick build fuselage |
I'm assuming he does realize that the front glare shield is only riveted temporarily with a couple rivets so as to allow you to drill them out and have easy access behind the panel etc. I haven't had any problem accessing anything.
Bill Pagan EAA Tech Counselor #4395
601XL QBK/Corvair/N565BW (RES)
--- On Tue, 3/31/09, jaybannist(at)cs.com <jaybannist(at)cs.com> wrote:
Subject: Quick build fuselage
Date: Tuesday, March 31, 2009, 4:07 PM
Jay Bannister
" rel=nofollow target=_blank>http://www.matronics.com/Navigator?Zenith601-List
jfowler120(at)verizon.net Guest
Posted: Tue Mar 31, 2009 1:12 pm Post subject: Quick build fuselage |
While we did not do a quick build the issue is the same on the kit. Cleco the upper skin in place (if at all) until you are done behind the panel. Hopefully you have slide out instrumentation -- and leave plenty of wire slack so you can do that. I made an access panel for the upper skin and cannot imagine not having it.
Karl Polifka
Posted: Tue Mar 31, 2009 1:39 pm Post subject: Quick build fuselage |
Turn it on its side.
-- Craig
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of jaybannist(at)cs.com
Sent: Tuesday, March 31, 2009 2:07 PM
Jay Bannister
| Quote: | | http://www.matronics.com/Navigator?Zenith601-List | 0123456789
Posted: Tue Mar 31, 2009 1:47 pm Post subject: Quick build fuselage |
Have you done that ?
Jay
Posted: Tue Mar 31, 2009 1:56 pm Post subject: Quick build fuselage |
No, my glare shield is removable. But without the gear on it isn’t hard. I did work on mine upside down.
-- Craig
Sent: Tuesday, March 31, 2009 3:44 PM
Subject: Re: Quick build fuselage
Jay
