KeysFox
Posted: Mon Apr 06, 2009 9:18 am Post subject: Douglas Wheel source |
I need the current Douglas part number for the aluminum 8 x 6 wheels that
match the wheels that came as part of my model IV kit in the early to mid
1990s. (Three bolt holes spaced at 85 to 86 mm)
I have read several times that Douglas still sells these wheels, but when
I talk with Douglas Racing techs they can't find 8 x 6 aluminum wheels
with the proper bolt hole spacing.
I suspect I will need to use a wheel with a different 3 bolt hole spacing
pattern and have new bolt holes drilled as well as having the brake disc
mounting tabs welded on, drilled and threaded.
BJ
N154K
N626NR
443-480-1023
bjones(at)dmv.com
_________________ B Jones
N154K
443-480-1023 |
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Mon Apr 06, 2009 5:21 pm Post subject: Re: Douglas Wheel source |
BJ, I found this On Avidfoxflyers.com http://avidfoxflyers.com/index.php?topic=135.0
TJ
"The original wheels are made by Douglas and the part #is 001-01 . these are 8x6 3b-3n 3/100 , you have to drill then other 3 holes .
Also you have to weld on the lugs for the brake rotors.
For a heavier wheel use part # 001-02"
_________________ Tom Jones
Classic IV
Ellensburg, WA |
