Emailing: Kitfox shock cord tools
larry huntley
PostPosted: Fri Mar 20, 2009 7:42 am    Post subject: Emailing: Kitfox shock cord tools Reply with quote
Hi Folks, Here are the shock cord tool pix and instructions.
The red handle tool is a (K&D??) tool from NAPA for pulling spark plug leads. The hook with a handle is homade from 1/4" steel round from the hardware store. It has a bit more hook than it seems in the photo. I have changed at least a dozen cords witht hese tools
I reach in the cabin and hook the first loop of the cord.thread it down to Mary,she pushes it back up. I pull hard as I can and send it back down.she sends it back and I hold TIGHT with the KD tool. The important thing is that you hold tight . Don't let anything slip back. Do it with the KD. send the end back down. She pulls as hard as she can and you hold while she sends it back up. You pull like heck and grab whith the tool.Repeat,repeat. Sometimes I grab the cord with the KD and PUSH down to her and hold. Last step is to push the hook down through to her and she hooks the end loop on it. If you have done well you will pull up more cord than you actually need and hook it over the knob. You will have taken a lot less than 10 minutes.
Remember,don't let any slip back.If you do you may have to unwrap the whole cord and start over again. I have often thought for the few dollars for the KD tool,it might make it easier if you had two. One to pull up with and one to push down with.
Good luck and have fun.
` Regards, Larry Huntley, 4-1200 SoobEA-81
The message is ready to be sent with the following file or link attachments:
Note: To protect against computer viruses, e-mail programs may Check your e-mail security settings to determine how attachments are handled.
 Filesize:  29.25 KB
 Viewed:  6139 Time(s)
Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade
patreilly43(at)hotmail.co
PostPosted: Fri Mar 20, 2009 8:27 am    Post subject: Emailing: Kitfox shock cord tools Reply with quote
Larry C Thanks for the pictures. I have that exact sparkplug puller tool in my tool box. I am surprised you can hold the shockcord that tight with that tool. If I ever need to redo mine I will use your method.
Pat Reilly
Mod 3 582 Rebuild
Rokford CIL
Subject: Kitfox-List: Emailing: Kitfox shock cord tools
Date: Fri C 20 Mar 2009 11:39:33 -0400
Hi Folks C   Here are the shock cord tool pix and instructions.
  I reach in the cabin and hook the first loop of the cord.thread it down to Mary Cshe pushes it back up. I pull hard as I can and send it back down.she sends it back and I hold TIGHT with the KD tool. The important thing is that you hold tight . Don't let anything slip back. Do it with the KD. send the end back down. She pulls as hard as she can and you hold while she sends it back up. You pull like heck and grab whith the tool.Repeat Crepeat. Sometimes I grab the cord with the KD and PUSH down to her and hold. Last step is to push the hook down through to her and she hooks the end loop on it. If you have done well you will pull up more cord than you actually need and hook it over the knob. You will have taken a lot less than 10 minutes.
  Remember Cdon't let any slip back.If you do you may have to unwrap the whole cord and start over again. I have often thought for the few dollars for the KD tool Cit might make it easier if you had two. One to pull up with and one to push down with.
`                                                Regards C   Larry Huntley C 4-1200 SoobEA-81
Note: To protect against computer viruses C e-mail programs may Check your e-mail security settings to determine how attachments are handled. [quote][b]
dave
PostPosted: Sun Mar 22, 2009 4:17 am    Post subject: Re: Emailing: Kitfox shock cord tools Reply with quote
Larry , I converted a Kitfox IV from floats to Bungee gear yesterday.
I gotta agree , bungess are so easy to do with out visegrips,pliers, tiewraps and all the nonsense I read about. Great tough gear too and lighter on the wallet and airplane than the newer gears out there Smile
http://rotaxaircraft.com/forum/viewtopic.php?f=8&t=87
no more than 5 minutes to do both bungees so easy -----
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
larry huntley
PostPosted: Sun Mar 22, 2009 4:39 am    Post subject: Emailing: Kitfox shock cord tools Reply with quote
Dave, What is your address? I will be driving across on the QEW in a couple
of days. Will probably be short on time ,but who knows. Sure would like to
see your gear. Larry Huntley,Dundee,NY
dave
PostPosted: Sun Mar 22, 2009 5:04 am    Post subject: Re: Emailing: Kitfox shock cord tools Reply with quote
Larry I am about 90 minutes from Hamilton.
You can type in where you at at here
http://maps.google.com/maps?source=ig&hl=en&rlz=&=&q=15123%20nine%20mile%20road&um=1&ie=UTF-8&sa=N&tab=wl
And drive right in. Let me know what day and time range so I can make sure i here. If you flying check ahead all 3 runways are usable but a few wet spots in places still. If you got King fox tires - heck land anywhere.
You coming to buy a CD -- how to put on those evil bungees in 5 minutes LOL ?
cfisher.com Kingfox Tires -- doing it the mud - get off that pavement with your bushplanes. LOL
 Filesize:  47.29 KB
 Viewed:  6097 Time(s)
larry huntley
PostPosted: Mon Mar 23, 2009 5:16 pm    Post subject: Emailing: Kitfox shock cord tools Reply with quote
Dave, You have a phone # in case I do get nearby. Leaving in the AM.
Larry
