Paul A. Franz, P.E.
Posted: Tue Mar 17, 2009 8:12 am Post subject: 582 Thermostat |
On Tue, March 17, 2009 2:55 am, fox5flyer wrote:
The OMC t-stat Snake is talking about works fine--actually better because it
allows the engine to quickly come up to a better working temp, especially in
the cold country. Some people drill a 3/16 hole in it to allow air to get
through, but I forget why.
The reason for the hole is to let some coolant leak by when it is too cold to open. If
the T-stat is some distance away from the rapidly heating coolant in the engine, it
might not start opening soon enough because the coolant is still cold near the T-stat.
I think the hole size needed is more like 3/32". You only need to let it leak a few
ounces to get warm coolant up to it.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
A new taste had been acquired and a new appetite began to grow. The time
had long since arrived to crush the technical intelligentsia, which had
come to regard itself as too irreplaceable and had not gotten used to
catching instructions on the wing. In other words, we never did trust
the engineers - and from the very first years of the Revolution we saw to
it that those lackeys and servants of former capitalist bosses were kept
in line by healthy suspicion and surveillance by the workers.
-- Aleksandr I. Solzhenitsyn, "The Gulag Archipelago"
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
experimentalab(at)yahoo.c Guest
Posted: Tue Mar 17, 2009 8:47 am Post subject: 582 Thermostat |
Well NAPA has no cross-reference for that thermostat (OMC 3853799), and I can't find specs for the Rotax-specific temperature. And no joke, that Part is $138 plus S/H from California Power and Lockwood...
akflyer
Posted: Tue Mar 17, 2009 9:29 am Post subject: Re: 582 Thermostat |
hmmm. I will check tomorrow with my local napa where I got mine and see if they have changed numbers.. I will let you know.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
akflyer
Posted: Tue Mar 17, 2009 10:21 am Post subject: Re: 582 Thermostat |
http://www.boats.net/parts/detail/brp/B-3853799.html
it is for a johnson or evinrude outboard.
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
