Smashing tubing
jaybannist(at)cs.com
PostPosted: Sat Mar 14, 2009 3:09 pm    Post subject: Smashing tubing Reply with quote
Hey gang,
I need to flatten the ends of a 3/4" aluminum tube (1/16" wall) for a bolted connection. Should I heat the tube to flatten it, or do it cold?
Thanks - Jay Bannister
Email message sent from CompuServe - visit us today at http://www.cs.com
Gig Giacona
PostPosted: Sat Mar 14, 2009 3:55 pm    Post subject: Re: Smashing tubing Reply with quote
Jay,
I assume this is for the cross bar for the canopy? I tested on a couple of pieces I had both hot and cold and didn't see a lot of difference. I didn't like the outcome of the test and decided to go with a solid piece of AL and then drill the rear canopy tube for the solid shaft to fit into. Then drill through that and secure with a fairly small diameter bolt.
I haven't actually done this yet but I have the stuff in the hanger to do it.
W.R. "Gig" Giacona
601XL Under Construction
PostPosted: Sat Mar 14, 2009 4:52 pm    Post subject: Smashing tubing Reply with quote
Gig,
I am planning to wrap a piece of .025 around the canopy hoop for an anchor for the cross brace (like I did for the tether cable). I will only drill through the anchor piece into the hoop for one A4 rivet to keep the anchor in place. I wanted to avoid making two relatively big holes in the canopy hoop and weakening it near the fixed end of the hoop. Guess that's the structural engineer in me coming out. I will drill a slotted hole in the flattened cross brace tubing for adjustment and secure it to the anchors with AN3 bolts.
Jay
JohnDRead(at)aol.com
PostPosted: Sat Mar 14, 2009 6:04 pm    Post subject: Smashing tubing Reply with quote
Jay;
I would not do either. If you heat the tube it will lose its temper, if you just flatten it mechanically it will probably crack along the sides. I would make a filler for the ends from solid aluminum with a light interference fit into the tube, then cross drill and make your connection. do not archive.
John Read
CH701 - Elbert CO - Jabiru 3300
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
In a message dated 3/14/2009 5:09:40 P.M. Mountain Daylight Time, jaybannist(at)cs.com writes:
Hey gang,
f="http://www.matronics.com/Navigator?Zenith-List">http://www.matronics.com/Navigator?Zenith-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
Need a job? Find employment help in your area.
Ron Lendon
PostPosted: Sat Mar 14, 2009 6:31 pm    Post subject: Re: Smashing tubing Reply with quote
I would work the metal cold. If you take two pieces of hardwood and drill part way through the same diameter of the tube, they can be used as saddles to control the crush of the tube.
Clamp the blocks together and drill hole. Use blocks to support the tube while crushing in a vice.
You may need to make some adjustments for material thickness but I just wanted to illustrate the concept.
 Filesize:  7.8 KB
 Viewed:  4719 Time(s)
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
PostPosted: Sun Mar 15, 2009 5:26 am    Post subject: Smashing tubing Reply with quote
Ron & John,
Thanks for the feedback. I have enough tubing to try both ideas.
Jay Bannister
