aadamson(at)highrf.com Guest
Posted: Wed Mar 29, 2006 5:34 pm Post subject: Sorta repeat question |
I sent a note to the list looking for a little feedback, but I didn't get
any, perhaps I asked too complicated of a question so I'll try again.
In a dual alt/batt system (Z14). Can I start the airplane with the primary
switch in ALT+BATT, and the secondary switch in BATT only? By doing so
*and* leaving the cross tie switch OFF, I use the primary battery for
starting. My engine monitor and other items are on the secondary buss and
it would be running on the secondary battery only.
Then is there then any issue with switching the secondary switch into the
ALT+BATT mode to start the secondary alternator?
What kind of "inrush" problems might I have. I designed for electronic
ignition even tho phase 1 will I'll be using mags.
Thanks in advance,
Alan
