| Which BRS suits the Mark III Xtra the most? |
| Canister |
0% |
[ 0 ] |
| VLS |
100% |
[ 1 ] |
| Total Votes : 1 |
faisalasif
Posted: Thu Mar 12, 2009 1:07 pm Post subject: BRS CANISTER or VLS ?? Which one would suit Mark III Xtra?? |
BRS Canister is the oldest model and has been used on Mark III Xtra yet on BRS website, they say that:
VLS is "Built specifically for aircraft with limited interior space, the VLS (Vertical Launch System) installs on top of the wing or fuselage. Upward firing works well with pusher designed aircraft."
Mark III Xtra is a Pusher Aircraft! therefore,
your kind comments / recommendations?
Thanking in advance for your kind responses.
Faisal.
JetPilot
Posted: Fri Mar 13, 2009 12:43 pm Post subject: Re: BRS CANISTER or VLS ?? Which one would suit Mark III Xtr |
I have the VLS on my Kolb MK III Xtra, and although I have not tried it yet, it seems very good good for the airplane The fit of the VLS pack is PERFECT for the top of the MK III Xtra, I like it much better than the canister ! I will post some pictures of it in a little while so that you can see for yourself.
Kolb MK-III Xtra, 912-S |
faisalasif
Posted: Fri Mar 13, 2009 2:02 pm Post subject: Re: BRS CANISTER or VLS ?? Which one would suit Mark III Xtr |
Thanks Mike, I look forward to the pictures.
and thank you for taking time to respond.
JetPilot
Posted: Fri Mar 13, 2009 3:32 pm Post subject: Re: BRS CANISTER or VLS ?? Which one would suit Mark III Xtr |
Here are three pictures showing the BRS, the VLS pack just sits in the top of the MK III like it was built for it !
371.09 KB |
8993 Time(s) |
439.07 KB |
8993 Time(s) |
399.18 KB |
8993 Time(s) |
faisalasif
Posted: Sun Mar 15, 2009 1:15 pm Post subject: Re: BRS CANISTER or VLS ?? Which one would suit Mark III Xtr |
Thanks Mike,
Beautiful bird you have there....
Thanks for taking time to post such excellent pictures.
faisal.
