naumuk(at)windstream.net Guest
Posted: Tue Mar 03, 2009 3:26 pm Post subject: Y Stick Decision |
All-
Thanks for your input. I think I'm going to go with the cut down stick.
Larry, I decided on the Y stick rather than the dual stick option long ago based on your access information. But, if everyone's holding below the Y anyway and you don't have the ears protruding, so much the better. On top of everything else, it's not like you're limiting controllability on either side. In addition, I don't need the space for my GPS- it's in the porker of a panel I finally got ready to wire. I have no illusions- my project is going to make the scales groan. As long as I can outrun a C150...
Bill Naumuk
Townville, Pa.
HDS 601MG/Corvair 95%
carlossa52(at)gmail.com Guest
Posted: Tue Mar 03, 2009 4:23 pm Post subject: Y Stick Decision |
Bill, you might want to consider a "convertible" setup:
http://mthobby.pcperfect.com/ch601/chcontrols2.htm
Cheers
Carlos
2009/3/3 Bill Naumuk <naumuk(at)windstream.net (naumuk(at)windstream.net)>
[quote] All-
Bill Naumuk
Townville, Pa.
Posted: Wed Mar 04, 2009 3:12 pm Post subject: Y Stick Decision |
Carlos-
Michel T? If so, I ran into him at the Brampford fly-in. Nice guy. Made a point of introducing himself.
Things are coming together. Pictures of my "Porker panel" attached. Even with a Dynon the bloody thing weighs 40+ lbs. the entire setup doesn't look like this because I put Naugahyde on the console and umpteen more gauges in the console upright.
Keep on keeping on...
Bill
86.71 KB |
6963 Time(s) |
188.88 KB |
6963 Time(s) |
87.39 KB |
6963 Time(s) |
Posted: Wed Mar 04, 2009 4:36 pm Post subject: Y Stick Decision |
Yep, Michel T himself. I intend to use the same approach.
The grip itself will probably be a game joystick - can you think of something that takes more punishment than that?
Some examples:
http://www.saitek.com/uk/prod/joysticks.htm
http://www.allproducts.com/ee/sanmos/joystick-l.jpg
http://www.logitech.com/index.cfm/gaming/pc_gaming/joysticks/&cl=ca,en
Thanks for the pictures - your project is starting to look like something that could fly...
I can't wait to start wok on the fuselage - but I still have to solve my space problem: I can't rivet the fuselage in my workshop (in the basement), or it won't come out.
Carlos
2009/3/4 Bill Naumuk <naumuk(at)windstream.net (naumuk(at)windstream.net)>
[quote] Carlos-
Bill
Gig Giacona
Posted: Wed Mar 04, 2009 8:39 pm Post subject: Re: Y Stick Decision |
I had a both a Saitek and Logitec joystick come apart on me when used as a game joystick. I'd never put one in a plane.
601XL Under Construction
Rickey B.
Posted: Thu Mar 05, 2009 4:25 am Post subject: Y Stick Decision |
Hey, Bill, nice looking panel! As for "Porker", it must be a York and not a Hamp…looks pretty lean to me!!
By all means, keep on keepin' on!!
Rick
ABSOLUTELY Do not archive!
Posted: Thu Mar 05, 2009 3:40 pm Post subject: Y Stick Decision |
You obviously know your hogs.
Posted: Thu Mar 05, 2009 3:42 pm Post subject: Y Stick Decision |
Carlos-
Do what one of the guys at Brampford did- build it in clecos and rivet it after it's upstairs. Take it from experience- I have more money in my garangar and tools than I have in my project.
Bill
Posted: Thu Mar 05, 2009 3:47 pm Post subject: Y Stick Decision |
I'm using a Ray Allen. No cutting corners, my main motivation is reducing
PIO. Also, I guess I am cheap. Now I only need one Ray Allen grip! (Already
in the bag)
Bill
