darinh
Posted: Wed Feb 25, 2009 10:50 am Post subject: Gummed up Fuel Filter - Any Ideas??? |
Ok guys here is the skinny...about 2 months ago my engine started to run a bit rough in the higher power ranges (80% and above) but idle through 75% was good as always. Now my engine only had 25 to 30 hours on it when this started. I have been tinkering with different things trying to figure it out but was not able to find anything out of the ordinary. I have suspected my fuel system since this began and started with my finger strainers which were clean. Next my fuel goes through a 40 micron Earl's filter and it was clean so I didn't bother checking the final filter right before the engine. I then moved to the carbs and they were fine. So in a last ditch effort, I decided to completely redo my fuel system hoses and this is where I found the problem.
Here is how the fuel is routed so you can follow. Fuel from the tank goes through the finger strainers, through about 15" of -6 Aeroquip AQP hose and then through 3/8" 5052 aluminum tubing to the header tank. From the header tank through more 3/8" aluminum to the 40 micron filter then to the fuel shut off valve. From here it transitions to 1/2" Mil 6000 hose for about 6" to the pumps then 5/16" Mil 6000 hose to the final filter (shown in pic) then to the fuel pressure regulator then to the carbs.
As you can see, this final filter is completely gummed and plugged up. I can barely blow air through it. As stated earlier, my other filters (before the mil 6000 hose) were clean. So here is my diagnosis: Mil 6000 hose is deteriorating and plugging the final filter which is not allowing enough fuel for the high throttle settings. My engine is a 914 so cruise power is about 5.5 gph but full power is almost 9 gph.
Solution: Get rid of all mil 6000 hose and replace with suitable Aeroquip hose or aluminum tubing. I also see that Aircraft Spruce says specifically not to use the Mil 6000 with fuel. Just as a note, I have checked my fuel source a couple times and have not found it to contain any ethanol
| The light brown is the filter element, the dark brown is??? Hose liner maybe? |
57.7 KB |
32982 Time(s) |
_________________ Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah |
Lynn Matteson
Posted: Wed Feb 25, 2009 11:21 am Post subject: Gummed up Fuel Filter - Any Ideas??? |
I was reading your report and came to the entry "MIL 6000", and
figured that was it. Somewhere in the past I had read about this
stuff on this list, and made a mental note to not use that which came
with my kit. I went with the SAE 30R7, and it has worked without fail.
Lynn Matteson
Jabiru 2200, #2062, 605 hrs
Sensenich 62x46
Status: flying
On Feb 25, 2009, at 1:50 PM, darinh wrote:
Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah
http://forums.matronics.com/viewtopic.php?p 32068#232068
http://forums.matronics.com//files/dscf2750_large_160.jpg
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Fox5flyer Guest
Posted: Wed Feb 25, 2009 12:51 pm Post subject: Gummed up Fuel Filter - Any Ideas??? |
Correct. Lose all of the Milspec and go to the Aeroquip or good equivalent.
It may not be the ethanol, but other chemicals in auto fuel that is causing
a deterioration of the Milspec. This stuff has been happening long before
ethanol was being used.
ethanol
Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah
kitfoxsport(at)verizon.ne Guest
Posted: Wed Feb 25, 2009 2:11 pm Post subject: Gummed up Fuel Filter - Any Ideas??? |
Goodyear now makes the SAE 30R9 that has a blue inner lining made for use with Ethanol and alternative fuels. It is very flexible without kinking and has a small outer diameter. Many auto parts, such as Autozone, stores sell it by the foot. SAE 30R9 is rated for fuel injection lines.
Sent: Wednesday, February 25, 2009 11:21:05 AM
Subject: Re: Gummed up Fuel Filter - Any Ideas???
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
I was reading your report and came to the entry "MIL 6000", and figured that was it. Somewhere in the past I had read about this stuff on this list, and made a mental note to not use that which came with my kit. I went with the SAE 30R7, and it has worked without fail.
Lynn Matteson
Sensenich 62x46
Status: flying
[quote] --> Kitfox-List message posted by: "darinh" <gerns25(at)netscape.net (gerns25(at)netscape.net)>
Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah
[url=http://forums.matronics.com/viewtopic.php?p 32068#232068]http://forums.matronics.com/viewtopic.php?p 32068#232068[/url]
darinh
Posted: Wed Feb 25, 2009 2:44 pm Post subject: Re: Gummed up Fuel Filter - Any Ideas??? |
Deke,
This is my thinking as well I know I have not run ethanol but the detergents and additives may be the issue. Clint has used the Mil6000 for 1400 hours without issue but I think he runs 100LL...I could be wrong though.
I bought some Gates Multi-fuel fuel injection hose today that I am going to use for the 5/16" lines...the other stuff is Aeroquip.
Thanks for the replies.
Series 7
914 Turbo
Kaysville, Utah
Guy Buchanan
Posted: Wed Feb 25, 2009 7:22 pm Post subject: Gummed up Fuel Filter - Any Ideas??? |
At 10:50 AM 2/25/2009, you wrote:
| Quote: | Solution: Get rid of all mil 6000 hose and replace with suitable
Sorry to say, Darin, but this is really old news which I'm sorry you
had to re-discover. I hope it still shows up in the archives. Most
guys have gone to SAE fuel injection hose, though some, like me,
still use the clear blue.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 300 hrs. and counting
_________________ Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
Lynn Matteson
Posted: Wed Feb 25, 2009 8:05 pm Post subject: Gummed up Fuel Filter - Any Ideas??? |
Is this the $12 per foot stuff? I was picking up some fuel line for
my plane a few weeks ago, and couldn't remember what the number was,
but thought it was fuel injection hose and the guy mentioned the
price, and I *quickly* remembered that it wasn't THAT stuff. : )
Lynn Matteson
Sensenich 62x46
Status: flying
On Feb 25, 2009, at 5:10 PM, Kitfox George wrote:
| Quote: | Goodyear now makes the SAE 30R9 that has a blue inner lining made
without fail.
Lynn Matteson
Sensenich 62x46
Status: flying
> Darin Hawkes
> Series 7
> 914 Turbo
> Kaysville, Utah
>_-
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3
_-
=3D --> http://www.matronics.com/contribution_-
N369LM |
clint_bazzill(at)hotmail. Guest
Posted: Thu Feb 26, 2009 10:34 am Post subject: Gummed up Fuel Filter - Any Ideas??? |
I use mostly Hi Octane Chevron except when I fly cross country. Put over 5 C000 gal of fuel through Mil 6000. After removing portions the line C it would be difficult to tell from new. I would like a piece of that bad fuel line that I keep hearing about to test.
Clint
| Quote: | Subject: Re: Gummed up Fuel Filter - Any Ideas???
Date: Wed C 25 Feb 2009 14:44:58 -0800
--> Kitfox-List message posted by: "darinh" <gerns25(at)netscape.net>
Guy C
Darin Hawkes
Series 7
914 Turbo
Kaysville C Utah
http://forums.matronics.com/viewtopic.php?p=232113#232113
&g==================
larry huntley
Posted: Thu Feb 26, 2009 11:39 am Post subject: Gummed up Fuel Filter - Any Ideas??? |
Clint,
When a local Kitfox went down in a meadow here ,the line was cut off and it had actually swollen shut. I don't know what caused it ,but it was running mogas. I have run mogas in my Tripacer for years w/ MilSpec 6000 line and have never had any problems. I wish I knew what did it. As I remember,Don Smythe did some research,but I don't know that he reached any conclusion.
Facts are :
A few pieces of 6000 have swollen shut and brought down aircraft.
A lot of aircraft have flown for many hrs on 6000 with no problem.
As far as I know,no one knows what has caused the problem.(I somehow doubt it is alcohol),but I sure wouldn't bet on it.
We know different gasolines have a variety of different additives.
I have used KwikFil for years with no problem, so will probably continue,but i wouldn't bet on that being sound practice either.
What line does anyone KNOW is good for both 100LL and mogas? I am in the process of rebuilding two different aircraft and would like to know.
Larry Huntley Kitfox4-1200 Soob, Tripacer Lyc 160,Funk B75L Lyc GO-145, Dundee,NY
_________________ Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade |
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Thu Feb 26, 2009 11:44 am Post subject: Re: Gummed up Fuel Filter - Any Ideas??? |
Service Letter #45 has a caution about oxygenated fuel deteriorating the Mil spec fuel line.
Here's the quote from that service letter.
"In addition to the tanks, the fuel lines which are used in the aircraft may be susceptible to deterioration from these fuels, including the aviation-grade MIL-spec hose which is currently supplied with the aircraft. Because of this, SkyStar does not endorse the use of any oxygenated fuels except those which have MTBE added to them."
Direct link to service bulletin #45. The reference to Mil spec hose is at the bottom of the last page.
http://www.kitfoxaircraft.com/support/service_letters/sl45.htm
_________________ Tom Jones
Classic IV
Ellensburg, WA |
darinh
Posted: Thu Feb 26, 2009 2:26 pm Post subject: Re: Gummed up Fuel Filter - Any Ideas??? |
Clint,
I would be happy to send you a piece of the line but please explain how you intend to test it as I am curious? I only have small sections, none long enough to install for use.
Tom,
I find it interesting that they say oxygenated fuel deteriorates Mil spec fuel line as the manufactures listed in the military spec (Gates and Thermoid) both list the line to be completely compatible with alcohol. Who are we supposed to believe? And my fuel is not oxygenated.
http://www.hbdthermoid.com/images/aviation_ducting/Aeroduct.pdf
Check out page 4...it doesn't say fuel anywhere in the description. Also, Aircraft Spruce specifically says that the Mil6000 is "Not recommended for fuel line".
http://www.aircraftspruce.com/catalog/appages/mil6000.php
At this point, I really don't care if people have used this hose successfully for a million hours...there are enough documented cases of problems that I am getting rid of it.
Series 7
914 Turbo
Kaysville, Utah |
Posted: Thu Feb 26, 2009 3:10 pm Post subject: Gummed up Fuel Filter - Any Ideas??? |
Lynn,
Sounds like the right price range for this stuff, but my local California Autozone store states the 5/16" Goodyear SAE j30r9 injector hose with the blue lining is $3.99 per foot. Notice I keep saying BLUE LINING!
I have been around for a little while but changed my email address from michaega. No that does not mean I know much. But I have been know to hit my head against the wall once in awhile for a better solution.
George
Sport Model - 914 / painting
Sent: Wednesday, February 25, 2009 8:03:50 PM
Is this the $12 per foot stuff? I was picking up some fuel line for my plane a few weeks ago, and couldn't remember what the number was, but thought it was fuel injection hose and the guy mentioned the price, and I *quickly* remembered that it wasn't THAT stuff. : )
Lynn Matteson
Sensenich 62x46
Status: flying
[quote] Goodyear now makes the SAE 30R9 that has a blue inner lining made for use with Ethanol and alternative fuels. It is very flexible without kinking and has a small outer diameter. Many auto parts, such as Autozone, stores sell it by the foot. SAE 30R9 is rated for fuel injection lines.
From: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Lynn Matteson
Sensenich 62x46
Status: flying
> Darin Hawkes
> Series 7
> 914 Turbo
> Kaysville, Utah
darinh
Posted: Thu Feb 26, 2009 3:48 pm Post subject: Re: Gummed up Fuel Filter - Any Ideas??? |
I bought some Gates fuel injection hose that is SAE30R9 spec also from a local hose supplier. It says on the hose that it is multi-fuel compatible. Here is a link to the Goodyear stuff.
http://www.goodyearep.com/ProductsDetail.aspx?id=14912
A check of Autozone's website though shows it at $12.99 for a 5/16" x 18" piece which is closer to $9.00 per foot. I paid $6 something a foot for the Gates SAE30R9 hose. $3.99 per foot is more in line with the fuel emission hose that your local shops sell. But if you can get the SAE30r9 for that price your getting a great deal.
Series 7
914 Turbo
Kaysville, Utah |
Float Flyr
Posted: Thu Feb 26, 2009 4:47 pm Post subject: Gummed up Fuel Filter - Any Ideas??? |
One of the problems may be that there are as many recipes for mogas out there as there are brands and “tests” of gas. In fact there may be more recipes as several oil companies actually change their recipes with the seasons so the gas you get in September is not be the same as what you got in July in some instances.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Larry Huntley
Sent: Thursday, February 26, 2009 4:09 PM
Subject: Re: Re: Gummed up Fuel Filter - Any Ideas???
Clint,
Facts are :
----- Original Message -----
To: Kitfox list (kitfox-list(at)matronics.com)
Sent: Thursday, February 26, 2009 1:29 PM
Subject: RE: Re: Gummed up Fuel Filter - Any Ideas???
I use mostly Hi Octane Chevron except when I fly cross country. Put over 5,000 gal of fuel through Mil 6000. After removing portions the line, it would be difficult to tell from new. I would like a piece of that bad fuel line that I keep hearing about to test.
Clint
> From: gerns25(at)netscape.net
> Date: Wed, 25 Feb 2009 14:44:58 -0800
> Guy,
> Darin Hawkes
> Series 7
> 914 Turbo
> Kaysville, Utah
> | Quote: | | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c |
- Release Date: 02/26/09 07:03:00 | 0123456789 | Quote: | | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 0 | Quote: | | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 1 | Quote: | | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 2 | Quote: | | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 3
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Thu Feb 26, 2009 4:57 pm Post subject: Gummed up Fuel Filter - Any Ideas??? |
Problem may be that it is something else in the MOGAS other than alcohol
that causes the swelling.
Noel
Kitfox III-A
Posted: Sat Feb 28, 2009 10:11 am Post subject: Gummed up Fuel Filter - Any Ideas??? |
Darin,
I believe you live in Utah
Okay, you can tell I have to much time on my hands waiting for the paint to dry. I called the Provo, UT Autzone store and if you buy the fuel line hose from their bulk roll it's $3.99 a foot. Their prepackaged stuff is expensive.
I'm done now and will say no more.
George
Sent: Thursday, February 26, 2009 3:48:56 PM
A check of Autozone's [quote][b]
Vic Baker
Joined: 11 Jan 2006 Posts: 71 Location: Carson City, Nevada
Posted: Sat Feb 28, 2009 11:18 am Post subject: Gummed up Fuel Filter - Any Ideas??? |
Just found some at our local Kragen store at $4.95 per ft. (Goodyear)
Vic Baker
S7 912S Warp
Phase 1 flight testing
Carson City, Nv
_________________ Vic Baker
Series 7
Carson City, Nevada |
lcfitt(at)sbcglobal.net Guest
Posted: Sat Feb 28, 2009 7:42 pm Post subject: Gummed up Fuel Filter - Any Ideas??? |
For what it is worth. Here in California, we have fuel specifications that
are very stringent - so much so that if we have a refinery problem, no other
state can help with the supply. However, this does not mean that all the
blends aavailable here are the same, only that they all meet the measurable
standards. I suspect that the same will hold for any mil spec certified
part. It must meet certain specifications, but I am personally convinced
that all Mil 6000 hose does not have the exact same formulation.
That one set of hose works and onother does not - at least in my mind -
means that at least two different formulations meet the specification, but
one handles mogas well and the other does not. I think there is too much
evidence that mil 6000 is not predictably satisfactory for mogas with or
without ethanol. Also keep in mind that the majority of the talk on the
list regarding Mil 6000 was long before ethanol was introduced to the
formula of mogas and as was mentioned, many posts on this subject are
available in the archives.
Lowell
darinh
Posted: Sat Feb 28, 2009 8:44 pm Post subject: Re: Gummed up Fuel Filter - Any Ideas??? |
As an update...I got all the hoses replace and the filter changed out to a new clear filter and sure enough, the engine hit 5730 rpm on a static run so all is well now. I bought myself a new gadget called a Carbmate electonic carb synchronizer that is awesome...I will post a new thread and discuss my thoughts on for anyone interested.
Series 7
914 Turbo
Kaysville, Utah |
Rich L
Posted: Wed Mar 04, 2009 4:32 pm Post subject: Re: Gummed up Fuel Filter - Any Ideas??? |
Thank you Darin for your timely posting on fuel lines. Because of you and another kitfox owner who said he changes his fuel lines every two years, I decided to change mine out. Here is what I found. I had a mix of 30R7, 6000, and Gates CS091206 C200??? From the wing tanks to the header, I had Tygon B44-4. I have 316 hours since DAR in August 07. All the lines seemed ok except for the Tygon. It was about 3/4 the size of the new Tygon I had and really brown and brittle. It actually cracked when I tried to straighten it out. I have only run 91 octane non ethanol fuel. I have replaced all the lines with Goodyear 30R9 at $5 a foot but I feel its worth it. Here is the Goodyear site with some good words on the stuff.
http://www.goodyearep.com/ProductsDetail.aspx?id=5144
Thanks for the heads up.
Rich L
Kitfox S-7, 912uls
Bonners Ferry,IDAHO
