andrewbutler(at)ireland.c Guest
Posted: Wed Feb 25, 2009 3:10 am Post subject: ANL Sizing |
Hello,
I am installing my ANL mounting base on my firewall. I have a 60 AMP alternator and my loading chart shows a continuous load of approx. 30A with max load (landing config. lights plus flaps, fuel pump etc.) of up to 47 or 48A.
Is a 40A ANL suffient or should I install a 50A or 60A ANL?
Best regards,
Andrew.
RV71700
Galway
Ireland.
Posted: Wed Feb 25, 2009 6:19 am Post subject: ANL Sizing |
At 05:07 AM 2/25/2009, you wrote:
<andrewbutler(at)ireland.com>
Hello,
Best regards,
ANL current limiters are exceedingly robust with
respect to their ratings. See:
http://www.aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/ANL_Specs.pdf
Bussman only makes 35, 50 and 80A values in the
lower ratings at the time the data sheet was published.
Other manufacturers may have other selections in
this range. If you can put your hands on even a 35A
ANL, it will be fine for your application since it
carries 80A continuously.
( -Thomas Paine 1776- )
longg(at)pjm.com Guest
Posted: Wed Feb 25, 2009 6:39 am Post subject: ANL Sizing |
Andrew,
If you're pulling 30 amps all day long a 30 amp ANL won't even flinch and probably your best bet for that rating.
