partner14
Posted: Wed Feb 25, 2009 8:09 am Post subject: List of firewall penetrations - plenum |
As with my previous response, may actual experience is down, but I listen a lot. Several people, one of the 10's in the pic I sent yesterday, have used fiberglass. You make the initial layup in the top cowl with it opbviously inverted. The transition to the top cowl was a little tricky. What I did was take a bunch of measurements and then fabricated a loop to simulate the openning of the top cowl. I also installed sheet metal on the back which I hope will eliminate the stagnent air by forcing the air down and through the cylinders. One of the shot shows mounting brackets. Any other questions, don't hesitate. Need any more pics, let me know
40636 |
