Posted: Mon Feb 23, 2009 7:57 pm Post subject: OT - The hydraulic ram on my HF engine hoist failed |
It seems that the ram on my Harbor Freight engine hoist failed.
Suddenly, after getting my engine mounted, the ram ceased ramming.
There was no leakage. Pumping had no effect. My guess is that some
internal seal failed. I followed the directions to bleed it. After
making a bit of a mess, the ram still appears to have failed.
I don't know what to do next. Replace the ram, the whole hoist, or
repair.
I'm wondering what caused it.I left the engine hanging on the hoist for
several months (with protection but the whole weight was borne by the
ram). Is that the reason?
Advice is sought and welcome.
Bill "it sure looks great up on the wheels and with the engine on it" Watson
Posted: Tue Feb 24, 2009 12:20 am Post subject: OT - The hydraulic ram on my HF engine hoist failed |
Unscrew the 'lock' on the ram all the way out and remove the ball on the
bottom. Then look for metal shavings in the bottom that prevents the
ball from seating. For me it's been a common problem ..... from my
hoist to floor rams, and may happen more than once on the same item. If
your ram slowly leaks down over time ..... same problem. Holding
pressure over a long period of time is normal and doesn't hurt the ram
at all. What probably happened was when you let the hoist down the
hydraulic oil pushed trash from the machining through and it caught
under the ball. If you really tightened down on the 'lock' you may have
pressed the trash down into the 'well' and you'll have to dig it out.
Good luck!
Linn
Bill Mauledriver Watson wrote:
<MauleDriver(at)nc.rr.com>
repair.
for several months (with protection but the whole weight was borne by
the ram). Is that the reason?
Watson
