Dave(at)AirCraftersLLC.co Guest
Posted: Tue Feb 10, 2009 3:20 pm Post subject: AirCrafters Overhead Consoles--Price Reduced |
Some of you have seen our overhead console for the RV-10. It’s a nice solution to clean up the area were the windshield strut ties into the cabin top, and it provides a convenient place for a lights and coax connections if you decide to put an antenna above it.
I had a batch made and frankly they cost quite a bit more than I expected. I have several in stock, and the price is going down.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
See it here: www.aircraftersllc.com/products.htm
The new price is $75 plus shipping.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
ron.mcgann(at)baesystems. Guest
Posted: Tue Feb 10, 2009 4:08 pm Post subject: AirCrafters Overhead Consoles--Price Reduced |
On a budget?? Here is my """"Overhead Console"""". One ea blue and white LED strips switched at the box in the picture and dimmed at the panel. The led strips are mounted to an epoxy coated balsa cover that hides the RG400 to the GPS antenna. The switch box covers the brace mount screws. In the final configuration the switch box has a cover plate (over the slot) with a High intensity 'DOT' type LED (battery - independent of everything) with a diffused lens.
The Blue LEDs are not only functional - they look coool. All I need is the fluffy dice!
Not as flash as Dave's. But hey - it only cost me $20 (Ozzie) for the whole setup.
cheers,
Ron
187 final countdown.
| Quote: | From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Saylor
Sent: Wednesday, 11 February 2009 9:47 AM
Subject: AirCrafters Overhead Consoles--Price Reduced
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
"Warning:
The information contained in this email and any attached files is
confidential to BAE Systems Australia. If you are not the intended
recipient, any use, disclosure or copying of this email or any
attachments is expressly prohibited. If you have received this email
in error, please notify us immediately. VIRUS: Every care has been
taken to ensure this email and its attachments are virus free,
however, any loss or damage incurred in using this email is not the
sender's responsibility. It is your responsibility to ensure virus
checks are completed before installing any data sent in this email to
your computer."
137.28 KB |
565 Time(s) |
steveg(at)redmondair.com Guest
Posted: Wed Feb 11, 2009 7:37 am Post subject: AirCrafters Overhead Consoles--Price Reduced |
Hey guys, for a full length option on overhead console check out this link.
http://www.redmondair.com/RV-order_forms/RV10_Overhead_Console-OF.pdf
Steve
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGANN, Ron
Sent: Tuesday, February 10, 2009 4:06 PM
Subject: RE: AirCrafters Overhead Consoles--Price Reduced
cheers,
Ron
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
| Quote: | | p://www.matronics.com/Navigator?RV10-Listics.com.matronics.com/contribution | "Warning:The information contained in this email and any attached files isconfidential to BAE Systems Australia. If you are not the intendedrecipient, any use, disclosure or copying of this email or any | 01234567
jim mclaughlin
Posted: Thu Feb 19, 2009 11:41 am Post subject: Re: AirCrafters Overhead Consoles--Price Reduced |
I had decided not to do the overhead due to cost, weight and hassle, but ordered one from Dave anyway. It is really nice. An easy way to hide a GPS antenna connector and trim that area.
_________________ Jim McLaughlin
40154 |
