zenoah
Posted: Wed Feb 18, 2009 4:11 pm Post subject: Prepping for primer |
I was told by a local paint supplier that I should spray vinegar on the
aluminum and then rinse it off with water prior to spraying self etching
primer on it. He said that is what they do on boats. Has anyone ever heard
this? Good / bad?
Steve Sims
601 HDS
Gig Giacona
Posted: Wed Feb 18, 2009 4:36 pm Post subject: Re: Prepping for primer |
Sounds like a cheap acid etching to me. I have no idea if it would work but that is what he is trying to do with the vinegar.
601XL Under Construction
Afterfxllc(at)aol.com Guest
Posted: Wed Feb 18, 2009 10:29 pm Post subject: Prepping for primer |
vinegar is a neutralizing agent and we used to use it after we cleaned our pizza ovens at our Papa Johns but I have no idea why they would use it before the etching unless it is to counter any acid based chemical residue which you shouldn't have on new aluminum.
Jeff
| Quote: | I was told by a local paint supplier that I should spray vinegar on the
this? Good / bad?
A Good Credit Score is 7001267884/aol?redir=http:%2F%2Fwww.freecreditreport.com%2Fpm%2Fdefault.aspx%3Fsc%3D668072%26hmpgID%3D62%26bcd%3DfebemailfooterNO62"> See yours in just 2 easy steps!
Gig Giacona
Posted: Thu Feb 19, 2009 6:11 am Post subject: Re: Prepping for primer |
Vinegar is an acid. From Wikipedia...
"Vinegar is an acidic liquid processed from the fermentation of ethanol in a process that yields its key ingredient, acetic acid (also called ethanoic acid). "
jimandmandy(at)yahoo.com Guest
Posted: Thu Feb 19, 2009 6:24 am Post subject: Prepping for primer |
Oven cleaners are lye which is a strong base. Vinegar is acid, so it will neutralize the lye. In the case of aluminum, it would be an additional etch. If the oxide layer is thick, then I suppose self etching primer wont work? The main thing is to get rid of skin oils and other organic barriers on the surface. I use lacquer thinner for that.
--- On Wed, 2/18/09, Afterfxllc(at)aol.com <Afterfxllc(at)aol.com> wrote:
[quote]From: Afterfxllc(at)aol.com <Afterfxllc(at)aol.com>
Subject: Re: Prepping for primer
Date: Wednesday, February 18, 2009, 10:27 PM
Jeff
this? Good / bad?
A Good Credit Score is 7001267884/aol?redir=http:%2F%2Fwww.freecreditreport.com%2Fpm%2Fdefault.aspx%3Fsc%3D668072%26hmpgID%3D62%26bcd%3DfebemailfooterNO62"> See yours in just 2 easy steps! [quote][b]
bryanmmartin
Posted: Thu Feb 19, 2009 7:44 am Post subject: Re: Prepping for primer |
The oven cleaner you used was probably a strong alkali so a wiping down with a weak acid like vinegar after cleaning makes sense. The vinegar would neutralize any residue of the lye.
[quote="Afterfxllc(at)aol.com"]vinegar is a neutralizing agent and we used to use it after we cleaned our pizza ovens at our Papa Johns but I have no idea why they would use it before the etching unless it is to counter any acid based chemical residue which you shouldn't have on new aluminum.
_________________ --
Bryan Martin
do not archive. |
z601(at)anemicaardvark.co Guest
Posted: Thu Feb 19, 2009 7:53 am Post subject: Prepping for primer |
On Wednesday 18 February 2009 18:36, Gig Giacona wrote:
I've never done this to an airplane, but I've tried it on other things, when
etchant wasn't available. It makes a cheap and readily available etchant for
aluminum, and helps get rid of grease, etc. It does seem to help the
adherance of a coat of primer or paint.
I'm leery of using non-aircraft products on aircraft, not because they
necessarily don't work, but becaue they have no long term track record of how
well they work in an aircraft environment.
Besides, my wife gets upset when I swipe the vinegar.
Do not archive.
Jim B Belcher
BS, MS Physics, Math, Computer Science
A&P/IA
Retired aerospace technical manager
Posted: Thu Feb 19, 2009 3:35 pm Post subject: Prepping for primer |
I wouldn't think Vinegar would be strong enough to etch the aluminum but Stewart Systems sells a etching wash to use before you paint. Take a piece of aluminum and stick it in some vinegar and see what happens. If you really want to etch it good just get some cat urine on it and that will do it for sure but it stinks to high heaven.
Jeff
A Good Credit Score is 700 o67884/aol?redir=http:%2F%2Fwww.freecreditreport.com%2Fpm%2Fdefault.aspx%3Fsc%3D668072%26hmpgID%3D62%26bcd%3DfebemailfooterNO62"> See yours in just 2 easy steps!
