Cmflyboy12(at)aol.com Guest
Posted: Sun Feb 15, 2009 8:04 am Post subject: what prop is the best,for a 582 |
hello,This is flyboy. I have a 582 kitfox 2 with a cgs prop I was thinking abot changing to IVO 3 Blade,any advise
Need a job? Find an employment agency near you.
manceliller(at)hotmail.co Guest
Posted: Sun Feb 15, 2009 8:13 am Post subject: what prop is the best,for a 582 |
isint it a gsc? i have a 3 blade wooden prop C it a gsc C and i like it !!! i really dont know the differance C between the 2
Date: Sun C 15 Feb 2009 11:03:16 -0500
Subject: Re: what prop is the best Cfor a 582
hello CThis is flyboy. I have a 582 kitfox 2 with a cgs prop I was thinking abot changing to IVO 3 Blade Cany advise
| Quote: | http://www.matronics.com/Navigator?Kitfox-List
ronics.com
ww.matronics.com/contribution
| Windows Live™: Keep your life in sync. See how it works. [quote][b]
Posted: Sun Feb 15, 2009 8:20 am Post subject: what prop is the best,for a 582 |
yes it is, I got it backwords.Why I ask is I,ve had a ivo 3 blade on a challenger 2 and I liked the way it adjusted.
Posted: Sun Feb 15, 2009 8:28 am Post subject: what prop is the best,for a 582 |
well i had a dog attack my plane a few years ago C and he ran into the prop C it killed the dog C and cracked my prop! i bought a new gsc C and only adjusted it once. do you play with your settings alot? p.s i just sent you some pictures of my bird
Date: Sun C 15 Feb 2009 11:19:53 -0500
yes it is C I got it backwords.Why I ask is I Cve had a ivo 3 blade on a challenger 2 and I liked the way it adjusted.
ronics.com
| Windows Live™: E-mail. Chat. Share. Get more ways to connect. See how it works.
Posted: Sun Feb 15, 2009 8:37 am Post subject: what prop is the best,for a 582 |
where do I get your pics at I,ll send you 1 of mine
68.21 KB |
9690 Time(s) |
Posted: Sun Feb 15, 2009 8:49 am Post subject: what prop is the best,for a 582 |
well im headed to the airport C to do some taxiing.......wish me luck.........good looking airplane
Date: Sun C 15 Feb 2009 11:35:39 -0500
where do I get your pics at I Cll send you 1 of mine
Windows Live™: E-mail. Chat. Share. Get more ways to connect. Check it out. [quote][b]
Cmflyboy12(at)AOL.COM Guest
Posted: Sun Feb 15, 2009 8:52 am Post subject: what prop is the best,for a 582 |
yes I have found them. That is a very,very nice plane,I love that yellow,
Posted: Sun Feb 15, 2009 8:53 am Post subject: what prop is the best,for a 582 |
Good luck stay on top of that tail wheel
Aerobatics(at)aol.com Guest
Posted: Sun Feb 15, 2009 9:40 am Post subject: what prop is the best,for a 582 |
I have a KF with an 3 blade IVO.... 582 E box
Perfection
In a message dated 2/15/2009 10:05:29 A.M. Central Standard Time, Cmflyboy12(at)aol.com writes:
| Quote: | hello,This is flyboy. I have a 582 kitfox 2 with a cgs prop I was thinking abot changing to IVO 3 Blade,any advise
f="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronics.com/Navigator?Kitfox-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
Paul A. Franz, P.E.
Posted: Sun Feb 15, 2009 10:23 am Post subject: what prop is the best,for a 582 |
On Sun, February 15, 2009 8:28 am, lance miller wrote:
| Quote: | ..... p.s i just sent you some pictures of my bird
I'd like to see them too. Probably everyone else does too!
They're very easy to post using the forum interface to this list.
<http://forums.matronics.com/viewforum.php?f=8>
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
Float Flyr
Posted: Mon Feb 16, 2009 5:04 am Post subject: what prop is the best,for a 582 |
Boy that’s a good question to get things going... sort of like asking what is the best flower, what is the best oiil or the best colour scotch brite.... let’s not go there again. Not this early in the silly season.
I have had two props on my plane so far and I have another one to put on the new 912.
The first was a three blade GSC wood prop. It was a little long for the float application and consistently picked up spray in the prop. I was continuously filling and dressing the leading edge. I think that prop had been over tightened at one time as when I set the pitch and torque down the blades to spec they would always go back to the original setting. When I found out the blades were almost fifteen years time expired I decided to go with another prop.
Enter prop #2 an UL Ivo electric IFA. At first I was a little sceptical if thei thin bladed prop would be able to pull my float plane. I needn’t have worried. It worked perfectly. Being an inch or so shorter than the GSC meant it didn’t lift the spray like the GSC so I didn’t have the problems of leading edge pitting. There are a few points about this prop.. First it is worth your time to set the limits on the prop. It takes a little longer but will be worth it in the end.
Secondly: This is a composite prop. It is not as hard a steel so you should very carefully follow the instructions on installing the prop so as not to damage the blades.
Next: The connector where the wires run into the hub I found to be weak and several times the contacts came out in flight even though the locking screws were in. Don’t ask I don’t know how. I ended up adding a couple of self tapping screws into the connectors to snug things up That worked fine.
Finally: the slip rings and brushes are prone to water damage in rain. For that reason I always kept but never used a couple of small wrenches that would enable me to turn the brush carrier away from the slip rings if I encountered any showers.
I think you will get lots of replies to this one.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Cmflyboy12(at)aol.com
Sent: Sunday, February 15, 2009 12:50 PM
Subject: Re: what prop is the best,for a 582
Need a job? Find an employment agency near you. | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Lynn Matteson
Posted: Mon Feb 16, 2009 5:31 am Post subject: what prop is the best,for a 582 |
I thought that common wisdom was to not use a wooden prop on a float-
equipped airplane. Maybe the key word here is "wisdom".
Lynn Matteson
Jabiru 2200, #2062, 605 hrs
Sensenich 62x46
New skis done and flying
On Feb 16, 2009, at 8:00 AM, Noel Loveys wrote:
| Quote: | Boy that’s a good question to get things going... sort of like
put on the new 912.
Noel
http://www.matronics.com/Navigator?Kitfox-Listhttp://
forums.matronics.comhttp://www.matronics.com/contribution
============================================================ _-
contribution_-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Float Flyr
Posted: Mon Feb 16, 2009 7:40 pm Post subject: what prop is the best,for a 582 |
I agree with you on that one but the GSC was on the plane when I got it.
Noel
Kitfox III-A
