		andrew(at)nzactive.com Guest
				 Posted: Mon Feb 09, 2009 3:04 am    Post subject: A cry for help from NZ! |
				Guys, a wee problem - my damn tailwheel snapped off. The (I don't know
 the word, but the long bar that goes back the tailwheel assmembly)
 snapped clean off, flush with the tailwheel assembly. As I'm not the
 builder (I know, I know) I don't know if that is a standard RV-4 item,
 or one of the things switched out when the RV-4 is transmogrified into a
 Rocket. Cos of what seems like a lot more weight than my RV-4 ever had.
 Mine is a well built HRII, not an F1. Anyone know where I can get one of
 those bars asap? I got a ROG situation, which is even worse than an AOG
 situation   Seriously, I'd like to find that item, and get one sent
 down to NZ as soon as possible, cos the aircraft is stuck 400 miles from
 my home field till I can sort it out.
 Also, a heads-up - something to be aware of, and inspect more
 thoroughly, I guess. To be fair, I hit a rabbit hole and the tail came
 up very high before bashing down hard, stick back....but I wasn't much
 more than walking pace, maybe running pace, so no other damage done. But
 mebbe worth inspecting more thoroughly at annual time, if you fly off
 short grass strips with occasional rabbit holes in em!
 Cheers
 Andrew
  |  | - The Matronics Rocket-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		n395v
		fred.laforge(at)verizon.n Guest
				 Posted: Mon Feb 09, 2009 9:49 am    Post subject: A cry for help from NZ! |
				Andrew, Van makes 2 different tail springs that will fit your Rocket, a bent
 one (standard) and one for an after market tail wheel (better).
		lschneider39(at)cox.net Guest
				 Posted: Mon Feb 09, 2009 10:58 am    Post subject: A cry for help from NZ! |
				Hey Fred, Please elaborate on the bent tail wheel spring from Vans. I've
 installed maybe a dozen springs and they were all straight. Where is the
 bend and why? Thanks,  Larry
				 Posted: Mon Feb 09, 2009 2:10 pm    Post subject: A cry for help from NZ! |
				Its the one they normally supplied, the tail wheel fork pivots on the
 section that is bent down. Maybe they dont use them any more.
		smokyray(at)rocketmail.co Guest
				 Posted: Mon Feb 09, 2009 2:58 pm    Post subject: A cry for help from NZ! |
				The Stock RV4 (straight) tail spring works great when combined with the Aviation Products Inc. dual fork tailwheel assembly. Mine works great. Vince Frazier also has a nice tailwheel setup on his website. Check it out...
 Smokey
 HR2
 --- On Mon, 2/9/09, Larry Schneider <lschneider39(at)cox.net> wrote:
 [quote]From: Larry Schneider <lschneider39(at)cox.net>
 Subject: Re: A cry for help from NZ!
 To: rocket-list(at)matronics.com
 Date: Monday, February 9, 2009, 10:57 AM
 [quote]--> Rocket-List message posted by: "Larry Schneider"
				 Posted: Mon Feb 09, 2009 3:34 pm    Post subject: A cry for help from NZ! |
				Fred, You sure are dating yourself, I remember now, Thanks.  ))
		Lee Logan
				 Posted: Tue Feb 10, 2009 7:49 pm    Post subject: A cry for help from NZ! |
				Andrew:  We had the same thing happen to the tail spring on our RV-4.  Flew it home off the grass strip we were on at the time.  The spring held up fine by itself during takeoff and the subsequent landing at home field.  If you are going to be stuck for awhile, you might consider that.  No harm, no foul, when we did it.  YMMV, of course!
  Lee...
				 Posted: Mon Feb 16, 2009 6:37 am    Post subject: A cry for help from NZ! |
				Andrew,
   I too operate my Rocket off a short, rough turf strip with the occasional fire ant mound and gopher hole. A cub actually broke a tailspring here, not an easy task. I too replaced my original tail spring installed by the builder in 96', fortunately before it snapped off from an elongated hole and crack.  I turned my new tail spring end on a lathe slightly prior to installing the assembly to remove the taper where the assembly slides on. I also drilled two small holes rather than one large one through the spring to hold the assembly on. If your prior owner drilled a large hole or "slammed" the tailwheel down a few times, it might have stressed it. Either way, the fix will exceed your expectations.
   On my strip, I rarely three point land my Rocket in lieu of wheels landings, although I fly a three point approach and ease it up  on the mains at touchdown. My 380X150X5 Desser tires have helped immensely along with my API dual fork tailwheel. As mentioned before, Vince's heavy duty tailwheel assembly and the Bell work well too.
   Something else I really like for STOL operations is my Lift Reserve AOA indicator. It lets you fly final at "max performance" safely. My normal approach groundspeed is 57-59 knots, something I'm sure you can appreciate.
 Fair Dinkum!
 Smokey
 HR2
 Subject: Re: Rocket-List: A cry for help from NZ!
 Date: Monday, February 9, 2009, 3:32 PM
		John Bolding
				 Posted: Mon Feb 16, 2009 7:12 am    Post subject: A cry for help from NZ! |
				Rob ,and the Group.
  Several months ago I had a couple hundred of  the LRI probes molded up out of black nylon,  I sell these for $45,  shipping included.  Also have the gauges for $25 but no faces yet,   anyone interested can contact me off list.
  John Bolding    jnbolding1(at)teleshare.net (jnbolding1(at)teleshare.net)
  [quote]   ---
		smokyray(at)yahoo.com Guest
				 Posted: Mon Feb 16, 2009 7:23 am    Post subject: A cry for help from NZ! |
				Could I trade my current probe?
 --- On Mon, 2/16/09, John Bolding <jnbolding1(at)teleshare.net> wrote:
 [quote] From: John Bolding <jnbolding1(at)teleshare.net>
  Date: Monday, February 16, 2009, 10:12 AM
  Rob ,and the Group.
				 Posted: Fri Feb 27, 2009 12:13 pm    Post subject: A cry for help from NZ! |
				Hi Smokey! Thanks for the email, and sorry about the delay  in responding. I'm finally clearing the backlog of helpful emails I received on  the subject of my poor ole AOG Rocket, which is still AOG due to a few  logistical issues. I have been travelling out of the country, but while I was  away, a VERY kind reader on the list sent me down a tailwheel spring that he had  lying around, unused. All the way to New Zealand - it was in NZ before I was! He  wouldn't even take money. Aren't some people nice? (I'm gonna insist on the  money, of course.) So I'll be trying to get my Rocket back in the air on  Monday.
  I'm going to fit a standard RV-4 setup to get me going, but  I really like the idea of the dual fork tailwheel, and any other ruggedizing  measures I can undertake. As for the AOA indicator, that sounds GREAT. This is  one of those, um, sense over ego issues, and I think, as ever, sense should win  here. The neighbours round here are insane, so I sometimes have to land downwind  for noise abatement. Needless to say I fly slow, power-on approaches, and  usually do a tail low wheeler, with some pretty aggressive braking, cos I find  the ole Rocket doesn't brake nearly as well with the tailwheel down. Seems to  work. But having a more scientific sense of my AoA, in addition to the ususal  cues, can only be a good thing. I'll get one, for sure. Is it a biggie to  fit?
  And, last dumb question, I've broken my landing gear/engine  mount three times now, albeit in 600 hours. (Did I mention my strip exactly  flat? It makes judging the touchdown a little tricky, or maybe I just  didn't pay enough attention at pilot school   We keep welding it up, and  it keeps breaking. I'm sure Mr RV wouldn't be too happy to see what has become  of his original creation, but the fact is, the HRII makes a damn fine bush  aircraft. So long as you don't mind welding! Have you ever heard of a stronger  engine mount available anywhere???
  Andrew
    From: owner-rocket-list-server(at)matronics.com  [mailto:owner-rocket-list-server(at)matronics.com] On Behalf Of Rob  Ray
 Sent: Tuesday, February 17, 2009 3:46 AM
             Andrew,
 Fair        Dinkum!
 Smokey
 HR2
		Mytyweav(at)earthlink.net Guest
				 Posted: Fri Feb 27, 2009 12:50 pm    Post subject: A cry for help from NZ! |
				You would be well advised to get a Tailwheel assembly from Vince Frazier. Once that's in place, you might start thinking about some might fine Gussets on your Engine Mount. Stop the cracks before they appear.
  Weav
  ACTIVE NZ - Andrew wrote: [quote]         Hi Smokey! Thanks for the email, and sorry about the delay in responding. I'm finally clearing the backlog of helpful emails I received on the subject of my poor ole AOG Rocket, which is still AOG due to a few logistical issues. I have been travelling out of the country, but while I was away, a VERY kind reader on the list sent me down a tailwheel spring that he had lying around, unused. All the way to New Zealand - it was in NZ before I was! He wouldn't even take money. Aren't some people nice? (I'm gonna insist on the money, of course.) So I'll be trying to get my Rocket back in the air on Monday.
    Andrew
       From: owner-rocket-list-server(at)matronics.com (owner-rocket-list-server(at)matronics.com) [mailto:owner-rocket-list-server(at)matronics.com (owner-rocket-list-server(at)matronics.com)] On Behalf Of Rob Ray
    To: rocket-list(at)matronics.com (rocket-list(at)matronics.com)
                         Andrew,
  Fair Dinkum!
  Smokey
  HR2
  --- On Mon, 2/9/09, Larry Schneider <lschneider39(at)cox.net> (lschneider39(at)cox.net) wrote:
          [quote]From: Larry Schneider <lschneider39(at)cox.net> (lschneider39(at)cox.net)
            [quote]--> Rocket-List message posted by: "Larry Schneider" <lschneider39(at)cox.net> (lschneider39(at)cox.net)  Fred,  You sure are dating yourself, I remember now, Thanks.  )) ---
				 Posted: Sat Feb 28, 2009 5:56 am    Post subject: A cry for help from NZ! |
				G'day Andrew!
   Glad you are using your Rocket "off road" as I do. I am running a new stndard Harmon mount with gussets. I use a landing technique I used in my RV4, threepoint approach to a wheels landing stance, rolling on so to speak. Smooth touchdowns result, even with an approach speed of 65 knots, touchdown 58.As I said, I really like the API tw, clears the rocks better than any of them. My buddy russ has a strip north of Auckland, stop by. Let me know if I can help! Fair dinkum, bloody oath!
 Smokey
 HR2
 --- On Fri, 2/27/09, Fred Weaver <Mytyweav(at)earthlink.net> wrote:
 [quote] From: Fred Weaver <Mytyweav(at)earthlink.net>
  Date: Friday, February 27, 2009, 12:49 PM
  Weav
  >  Andrew
  > *From:* owner-rocket-list-server(at)matronics.com
  [mailto:owner-rocket-list-server(at)matronics.com] *On Behalf
  Of *Rob Ray
  > *Sent:* Tuesday, February 17, 2009 3:46 AM
  > *To:* rocket-list(at)matronics.com
  > *Subject:* Re: A cry for help from NZ!
  > Andrew,
  appreciate.
  > Fair Dinkum!
  > Smokey
  > HR2
  > --- On *Mon, 2/9/09, Larry Schneider
  Schneider"
  >     Fred,
  Thanks.  ))
