		russ(at)wernerworld.com Guest
				 Posted: Mon Feb 09, 2009 7:04 am    Post subject: Tailwheel |
				Andrew,
 That is a standard Vans tailwheel spring.  Fastest way to get one is to
 find a builder who won't need his for a while.  Snag that and get Van's
 to send him a new one.  Same one is on the RV3 thru RV7.
 When you get the new one, you will have to drill it to the hole that
 retains it in the sleeve which is up inside your tailcone.  You must do
 that without making the hole in either piece oversize.  Best thing here
 is to  put in a taper  pin, rather than the an3 bolt in the Vans
 plans.  That will require a taper reamer.  That could also be done
 later, after you get the bird home.
 Good luck!
 Russ Werner
 Park City, Utah
  |  | - The Matronics Rocket-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Rocket-List |
		Vince Frazier
				 Posted: Tue Feb 10, 2009 8:26 am    Post subject: tailwheel |
				SNIP  **********From: Rob Ray <smokyray(at)rocketmail.com>
 Subject: Re: A cry for help from NZ!
 The Stock RV4 (straight) tail spring works great when combined with the
 Aviation
 Products Inc. dual fork tailwheel assembly. Mine works great. Vince
 Frazier
 also has a nice tailwheel setup on his website. Check it out...
 Smokey
 HR2 SNIP***********************
 Andrew,
 If you have rabbit holes to watch out for, maybe you should have a look
 at the monster fork that I made for Greg Illes.  You can find it on the
 vansairforce forums, just search on monster tailwheel. I can make one
 for you if you like.
 You can see all of the other tailwheel stuff that I offer at this URL
 www.flyboyaccessories.com
 If you've still got the stock Van's tailwheel on your plane (or on the
 part that is broken off!), do yourself a huge favor and buy one of my
 tailwheels. If not mine, buy one from Doug Bell.  Either one will give
 you much better obstacle clearance and improved handling.
 I keep my stuff in stock and ready to ship.  Lots of other RV stuff in
 the store too.
 Thx,
 Vince Frazier
 Flyboy Accessories
 3965 Caborn Road
 Mount Vernon, IN 47620
 812-464-1839
  _________________ Vince Frazier
3965 Caborn Road
812-464-1839 work
812-985-7309 home
F-1H Rocket, N540VF
http://vincesrocket.com/ |
